Pisces69 6th Gear June 22, 2007 Share June 22, 2007 cars cannot tune one la. unless you have an after market ECU. any mech that says he tune is the biggest BS king. Too general of a statement.... Carburattor engine can be tuned, even I sometime fiddle with the idling rpm or adjust the rpm when air-con kicks-in. ======================= Aiyah bro, don't ask newbie to fiddle with his engine. Wait he adjust wrongly then engine kaput. Our cars using carb so can play a little lah. Their cars all using ECU leh. ↡ Advertisement Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 22, 2007 Share June 22, 2007 hi, All I did was to inform the guy that my fuel consumption was bad and he replied that he will do some tuning. Upon completion, the job statement indicated a certain "consult tuning". My case was that FC for 1k & 5k servicing was pretty good @ 15km/l. However, after the 10k servicing the FC dropped to around 13, 14km/l. So I just reflect to the service centre about the case during servicing. If there is no such thing as engine tuning, then it must be the oil i used (10W30) at 20k that helped my fc. still in my 1st tank after servicing last week. travelled 500km and indicator at last quarter. so maybe this tank can travel close to 600km. (70% HW) Will continue to monitor. Cheers. Did you managed to see how your mechanic tune your engine? For mine (old engine) I understand that by adjusting (turn) the distributor which is located at one side of the engine near the valves train, it can advanced or retard the timing.....not sure does this works on newer engines.... ===================== U trying to make him itchy issit??? Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 22, 2007 Share June 22, 2007 u should go getz club and ask them.. anyway i have stopped using Shell Helix many years ago. Mobil 1 also not often..using them are a waste of good $$. too much better oil at lower prices. search around engine oil discussion in this forum and u will get what i mean. ======================== Link to post Share on other sites More sharing options...
Slowmo Clutched June 22, 2007 Share June 22, 2007 hi guys just reading up through the thread. wonder if any getz owners here on shell helix / mobile syn engine oil? any recommendations? thanks! FYI, KMC uses shell oils if you service with them. If i did not remember reading the manual wrongly, you should be looking at somewhere between 0-5w30-40 range. Link to post Share on other sites More sharing options...
Blackhouse Neutral Newbie June 23, 2007 Share June 23, 2007 Bro, Thanks for the reply first. But my car oredi after 1K service. Now mileage is ard 1500km. do you mind to tell when the fully run-in will be completed? My 1st tank (36 liter) after 1K only run 374km, FC=10.4km/l (20% HW). Now my 2nd tank run 146km (50% HW), the needle is pointing at 62.5%. If continue like that, in the end I can only get ard 10.8km/l. I don't know how other Latio could declare those nice looking FC. For my case, Latio really sucks! . Very regret to choose Latio, should buy Sunny or even Korea car. (no offend to Korea car owner). Can ask TCM change to the 10W30 for my car? Link to post Share on other sites More sharing options...
Archon 2nd Gear June 23, 2007 Author Share June 23, 2007 Many factors contribute to the FC reading. give it another few months as the engine oil smooth out. You should better reading then. Link to post Share on other sites More sharing options...
Blackhouse Neutral Newbie June 23, 2007 Share June 23, 2007 can anyone recommend any good engine oil for FC for latio Hi Bro, Do you mind to share your Latio FC & Mileage? Since you are looking for good engine oil? Jus wonder whether you are suffering from the same FC problem as me? Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 24, 2007 Share June 24, 2007 (edited) Normally after 10K km is fully run-in. Wait till then & check your FC again. Another thing is your tyre pressure, type of tyre, alignment, wheel balancing, brakes & wheel bearings. All these also have an effect on your FC. If after run-in u still have lousy FC, maybe u can have these things checked too. Edited June 24, 2007 by Pisces69 Link to post Share on other sites More sharing options...
Octopus 3rd Gear June 26, 2007 Share June 26, 2007 hi, All I did was to inform the guy that my fuel consumption was bad and he replied that he will do some tuning. Upon completion, the job statement indicated a certain "consult tuning". My case was that FC for 1k & 5k servicing was pretty good @ 15km/l. However, after the 10k servicing the FC dropped to around 13, 14km/l. So I just reflect to the service centre about the case during servicing. If there is no such thing as engine tuning, then it must be the oil i used (10W30) at 20k that helped my fc. still in my 1st tank after servicing last week. travelled 500km and indicator at last quarter. so maybe this tank can travel close to 600km. (70% HW) Will continue to monitor. Cheers. Did you managed to see how your mechanic tune your engine? For mine (old engine) I understand that by adjusting (turn) the distributor which is located at one side of the engine near the valves train, it can advanced or retard the timing.....not sure does this works on newer engines.... ===================== U trying to make him itchy issit??? No lah, just curious if new engines can be tuned that way.... Link to post Share on other sites More sharing options...
Eyke Supercharged June 26, 2007 Share June 26, 2007 check your manual to see what's the minimum weight oil your car can use. it should be w30 or even w20. using the lower weight will give a bit more power and slightly better fuel consumption. Link to post Share on other sites More sharing options...
Soild79 Neutral Newbie June 26, 2007 Share June 26, 2007 I not having any better FC also ... around 11 to 12km/l thinking of changing engine oil also to 30w Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 27, 2007 Share June 27, 2007 Link to post Share on other sites More sharing options...
Depmode Neutral Newbie July 4, 2007 Share July 4, 2007 Hi all My kia cerato is due for 40k svc soon. will be a major svc as need to chge these: engine oil oil filter gear oil fuel filter spark plugs air filter brake fluid coolant any idea where to get engine oil and gear oil of reasonable quality and price ? thanks. Link to post Share on other sites More sharing options...
Rickoes Neutral Newbie July 4, 2007 Share July 4, 2007 hi, I just done my 10k svc for Rio 06 outside workshop using OWS oil and OWS double Iridium spark plug. Now car feel very light and engine rev not so rough. FC seem like same, need to monitor further. Link to post Share on other sites More sharing options...
Orixy 2nd Gear July 6, 2007 Share July 6, 2007 guys, like to ask if there's any issue with using Mobil-1 5w30 mix with 5w40? Same brand but different viscosity boleh? Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear July 6, 2007 Share July 6, 2007 Boleh, u get 5W-35 lor. Link to post Share on other sites More sharing options...
Orixy 2nd Gear July 6, 2007 Share July 6, 2007 (edited) k tks! cos got 2 quarts of 5w30 left and my engine need abt 3L so need to buy another quart so tot of getting 0w40 to 'balance up' the less viscous 5w30. :) Edited July 6, 2007 by Orixy Link to post Share on other sites More sharing options...
Hogster Neutral Newbie July 6, 2007 Share July 6, 2007 Call Min Ghee Auto at 62960808. They are the stocklist for Kia and Hyundai. ↡ Advertisement Link to post Share on other sites More sharing options...
SCHNELL Engine Oil 5W40
