Tanlouis Neutral Newbie September 5, 2007 Share September 5, 2007 Hi... need your help on this matter. My friend told me that a bmw 320i is an all-wheel drive but i seem to recall it being a rear wheel drive so a bit confused. can anyone of you enlighten me on this? thanks so much. ↡ Advertisement Link to post Share on other sites More sharing options...
Vratenza Supersonic September 5, 2007 Share September 5, 2007 who is your friend? it's RWD. period. Link to post Share on other sites More sharing options...
Ara84 2nd Gear September 6, 2007 Share September 6, 2007 one way to tell whether a bmw is awd it shud haf the X behind the numbers. example wud be like 328XI or 535XI. I'm nt sure if they offer 4 cylinder engines as awd. Link to post Share on other sites More sharing options...
Nus24 Neutral Newbie September 6, 2007 Share September 6, 2007 (edited) Firstly....are you talking about Singapore context? Is this friend of yours talking about his experience of BMW in USA or Europe or Finland? The only BMW 3 series in Singapore got 4WD could be a special import. Edited September 6, 2007 by Nus24 Link to post Share on other sites More sharing options...
Ahbengdriver 6th Gear September 6, 2007 Share September 6, 2007 What BMW is more famous for is their RWD cars. Most of their cars are RWD. However, they also make 4WD cars, which as someone already said has an "X" in the badge. So a 330Xi for example is a 330i with 4 wheel drive system. Link to post Share on other sites More sharing options...
Voxy28 3rd Gear September 7, 2007 Share September 7, 2007 Or the X3... Link to post Share on other sites More sharing options...
Tanlouis Neutral Newbie September 8, 2007 Author Share September 8, 2007 Thank you guys for answering my doubt. By the way, my friend's talking abt his experience in Singapore. Link to post Share on other sites More sharing options...
Ashyellow Neutral Newbie July 18, 2010 Share July 18, 2010 Can anyone tell me the weight of the rim for 320i the cureent model 16inch and is it advisable to change to 19 inch M rim? Link to post Share on other sites More sharing options...
Elviskoh Neutral Newbie July 18, 2010 Share July 18, 2010 BMW only famous for RWD cars. Whenever talk about 4WD, most people will probably think of Audi Quattro.. Link to post Share on other sites More sharing options...
Ladykillerz 4th Gear July 18, 2010 Share July 18, 2010 Can anyone tell me the weight of the rim for 320i the cureent model 16inch and is it advisable to change to 19 inch M rim? for the rim weight, i am not sure. 320i is able to feed in 19inch rim. advisable or not, it is depending on the driver. i would recommend at least 323i or higher for that set of 19inch.. Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 19, 2010 Share July 19, 2010 for the rim weight, i am not sure. 320i is able to feed in 19inch rim. advisable or not, it is depending on the driver. i would recommend at least 323i or higher for that set of 19inch.. 19" definitely can fit. Aesthetically, it is swee. The best combo for 320 is definitely 17" light weight rim like Volk Racing. It will improve butt feel. Link to post Share on other sites More sharing options...
Mockngbrd Supersonic July 19, 2010 Share July 19, 2010 4WD? wow... time to go rallying Link to post Share on other sites More sharing options...
Ashyellow Neutral Newbie July 19, 2010 Share July 19, 2010 oic cos now i looking at a set of 19 M rims quite cheap But Performance motor advise me not to Says will affect my performance And all my friends say my pick-up will be greatly affected too Link to post Share on other sites More sharing options...
Cheesepiekia 5th Gear July 19, 2010 Share July 19, 2010 19" too big for 320i to handle, pick up sure kena affect. 17" should be the best for 320i. Link to post Share on other sites More sharing options...
Zyx Neutral Newbie July 19, 2010 Share July 19, 2010 light weight or forged types 17" rims. swee! Link to post Share on other sites More sharing options...
The_Bear Turbocharged July 19, 2010 Share July 19, 2010 Can anyone tell me the weight of the rim for 320i the cureent model 16inch and is it advisable to change to 19 inch M rim? dunno the wt of the original rim but they are on run flat and pretty much spoils the ride. Anyway, they look too small. 19" are way to big for 320 and creates too much drag and road noise. You get this constant Wong-wong-wong that drives you nut. I suspect they haf an advese effect on the suspension too. 18" are the best compromise and ditch the run flats if you are not going Malaysia often. Link to post Share on other sites More sharing options...
Firehorse 1st Gear July 19, 2010 Share July 19, 2010 I replaced my stock 16" with RFT to 18" with CSC3 225/40/18 No change in FC, didn't feel any sluggishness. Link to post Share on other sites More sharing options...
Redplanet Clutched July 19, 2010 Share July 19, 2010 I replaced my stock 16" with RFT to 18" with CSC3 225/40/18 No change in FC, didn't feel any sluggishness. Sure? If it's true, then ...wow... ↡ Advertisement Link to post Share on other sites More sharing options...
Math Question
Math Question
BMW 320i ED or Volvo S60 T5
Question on Transfer of Car Ownership
BMW E93 320i Cabriolet
Question for Car Servicing
COE renewal question
Question of polyclinics
