Vextan 1st Gear April 4, 2009 Share April 4, 2009 How often should do wheel alignment, and where are the places known to do them ? What are the tell tale signs that a car is out of alignment ? Pls advise, thanks. ↡ Advertisement Link to post Share on other sites More sharing options...
Kyojin 1st Gear April 4, 2009 Share April 4, 2009 Google is your friend. search: wheel alignment how long search: wheel alignment symptoms where? Stamford Tyres is reasonable and service has been good. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic April 4, 2009 Share April 4, 2009 Check the tyres. If one side of a tyre is worn out, then it's time for wheel alignment. Can try Kenny wheel alignment or Riverview. Both at level 4 AMK Autopoint. Link to post Share on other sites More sharing options...
Route Clutched April 4, 2009 Share April 4, 2009 if can, do in jb.. rm15 - 20 for alignment... Link to post Share on other sites More sharing options...
Orangepineapple Clutched April 4, 2009 Share April 4, 2009 i just did mine coz fail inspection 40 bucks at riverview AMK autopoint. Link to post Share on other sites More sharing options...
Hcblue99 Neutral Newbie April 4, 2009 Share April 4, 2009 i just did mine coz fail inspection 40 bucks at riverview AMK autopoint. Didn't know inspection got check alignment. Link to post Share on other sites More sharing options...
Yeobh 4th Gear April 4, 2009 Share April 4, 2009 (edited) The correct name for wheel alignment test in Inspection Centre is know as Side Slip Test. This process test the car ability to keep straight ahead when travelling over a distant of 1km. Once the car starts to pull either to the right or left and exceed the limit of 5mm/km the car has fail a major test. The owner must rectify the fault before going for a re-test Edited April 4, 2009 by Yeobh Link to post Share on other sites More sharing options...
Orangepineapple Clutched April 5, 2009 Share April 5, 2009 ya i also din know... so did not check first before sending for inspection.. haiz waste my time must go for re-test however, when i went for the re-test, they did not actually put my car in the checking machine... just drive thru like that as if they know in advance it would pass. hmmmmmm i was quite mystified by this Link to post Share on other sites More sharing options...
S4vtec 3rd Gear April 5, 2009 Share April 5, 2009 the side slip test is done by driving pass a moveable plate on the floor . not done by putting it on a machine... Link to post Share on other sites More sharing options...
Sky_vinz Clutched April 30, 2009 Share April 30, 2009 Hi guys, need some advice.. Went to a shop in the evening to do 'Balancing/Alignment & High Speed Balancing' for my Lancer Cs3, and requested to adjust my camber angle. The camber angle was adjusted as: Front Left 1.2 Front Right 1.1 Rear Left 1.0 Rear Right 1.0 Almost similar adjustments were done previously in another reputable shop few mths back. However on my way home, I can easily feel the car veering towards the left whenever I free hand. Also, the steering wheel steers towards the left when going thru road strips. This happened even after I went to check my air pressure for all tyres. It is weird, as I did not encounter this yday. Any particular reason? Thanks in advance. Appreciated. Link to post Share on other sites More sharing options...
Darkblue 1st Gear April 30, 2009 Share April 30, 2009 Toe ? For FF Front Toe in -Highway cruising Front Toe out - Cornering Rear best Toe Left/Right - 0 / 0 Link to post Share on other sites More sharing options...
Hamburger Hypersonic April 30, 2009 Share April 30, 2009 Google is your friend. search: wheel alignment how long search: wheel alignment symptoms where? Stamford Tyres is reasonable and service has been good. its e last pl i wuld go....for mi tat is Link to post Share on other sites More sharing options...
Nhrisuzu 1st Gear April 30, 2009 Share April 30, 2009 correct me if i am wrong people.. it might be due to road camber.. our roads are slanted to the left for drainage purpose.. but dunearn rd/bt timah is to the right.. and maybe some other roads too.. Link to post Share on other sites More sharing options...
Sky_vinz Clutched April 30, 2009 Share April 30, 2009 Nhrisuzu: Tried driving on streets and also expressways just now. All same results -> veers towards the left.. Link to post Share on other sites More sharing options...
Sha_va Neutral Newbie April 30, 2009 Share April 30, 2009 is it coz of the tyres? tyre punctured will sway also... Link to post Share on other sites More sharing options...
Sky_vinz Clutched May 1, 2009 Share May 1, 2009 Sha_va: Erm nope, currently all in gd condition. Link to post Share on other sites More sharing options...
MadDog70 2nd Gear May 1, 2009 Share May 1, 2009 (edited) Do wheel alignment only if 1) your car is not moving straight, either shifting left or right tremendously. If slightly to the left is ok because Singapore roads are constructed bias to the left (if you notice). 2) you change new set of tires. Info on wheel alignment http://www.familycar.com/alignment.htm Edited May 1, 2009 by MadDog70 Link to post Share on other sites More sharing options...
Furrynadz 5th Gear May 1, 2009 Share May 1, 2009 (edited) there is no such thing as bias to any side on our roads its shoddy construction everywhere the only slope that exists is into the coffers u know where Edited May 1, 2009 by Furrynadz ↡ Advertisement Link to post Share on other sites More sharing options...
Wheel bolts and Wheel spacer
Wheel Spacer Installation DIY
Wheel Spacer, where to buy?
Wheel Hubs
Wheel Hubs
Paddle shifters - fixed to wheel or column?
Planetary alignment
Planetary alignment
Wheel spacers - the real truth...
