HELP! Need a reliable plumber & electrician
Vroomtattat
Hi bros,
Any recommendations for a reliable plumber and electrician with good workmanship?
Preferably not the tok carrot head type.
Why must the 2 toilets, the kitchen sink and a couple of electrical switches start to conk out at
almost the same time? Beats me!! [confused]
Thank you for you time . . . . [thumbsup]
PM me if you want. I got a reliable contractor friend. Very reasonable price. Thanks
Thanks brudder Donut. Will try, now my kitchen tap dripping like mad . . . . 4 litres per hr [sweatdrop]
Bro, turn off the mains first. You should have a small sub-switch on your pipes which controls the water flow to your kitchen tap.
I am also experiencing a leaky kitchen tap. For past few weeks already. I still haven't found the time to buy a new tap to change.
leaking pipes in toilet for wks and getting worst.
found this thread and called Ah Soon and got
gd services, quality work and reasonable price.
thks for all bros info
Thanks brudder, I heard they got 3 months warranty or something like that.
I believe Electrician/Plumber with good workmanship means can be problem-free for ages. So charges are cheap-cheap when divided over the problem-free years [:p]
Supercharged
Anyone knows of a repairman who does gas hob repair? The knobs on mine don't pop back up. Think the springs mati liao. Thanks.
Edited by Kklim
Want to change the basin attached to Vanity Top, as the basin sink is choked.
Does anyone know if this would be a major project, because of the attached Vanity Top and wooden cabinet below?
In this regard, shd i be finding a carpenter or plumber to fix this job?
thanks, and do let me know if you have any recommendatiions?
The problem is the choke. Choke likely caused by clogged drainage. Hence nothing to do with carpentry work.
Try a simple DiY... unscrew/open bottle-trap under the basin to check for blockage.
Go hardware shop buy flexible steel tube less than $5. Insert in hole to poke poke it. Pour some boiling water if needed.
Obviously, someone throw small rubbish or pour oil products into it.
Edited by Kangadrool
Searching for a reliable contractor, interviewing them and enquire about their references all are a bit tedious in contractor selection process. Unless we complete the above we could not figure out the good workmanship. Many online portals like HireContractor.com, angies list , and home contractor search would provide list of prescreened contractors . You could find out desired contractors using these portals.
Hypersonic
I know of one who is very reliable and honest. Will never overcharge you. Can find him at 96749101, Ronnie.
I was urgently looking for an electrician that day.
Somehow after tripping my circuit breaker, couldn't reset it back.
Ronnie solved the problem for me. Only charged me transport cost of $50/60 (can't remember)
He can be a bit long winded. And he seems more of a handyman rather than a proper electrician. But seems like an honest fella so thumbs up [thumbsup]
My kitchen basin drain pipe was choked some weeks ago. That section which is below the floor level.
Had to call a plumber at 7.30pm. Of course he fleeced the hell out of me. Never even said thank you when I paid him. Was evasive when I asked some questions.
His main tool was a rubber piece attached to a flex pole which he just pumped the pipes to clear the choke.
Ronnie on my list the next time. Thanks.
Edited by Camrysfa
Learn a bit of DIY, buy some tools stand by in your store (like plunger and flexible wire for clearing sewerage choke etc) as handy man will be more and more expensive like many other services in Singapore.
You won't have to wait nor [knife] .
(except for electrical - if you don't know anything, don't touch!)
Man's hand got stuck in drainage pipe. Hope it is not due to DIY.
http://www.channelnewsasia.com/news/singapore/man-sent-to-hospital/1837918.html
SCDF was informed at 6pm that a man in his 50s had his right hand trapped in a drainage pipe in a bathroom. The man lives in a corner unit on the eighth floor of Block 517C at Jurong West Street 52.
SCDF said that it dispatched a fire engine, one Red Rhino, an ambulance as well as three supporting vehicles. It added that upon arrival at the victim’s unit, he was found lying on the toilet floor. It is not known how he ended up in the situation.
A four-hour operation was conducted to free the man and this includes drilling the toilet floor in his unit and the unit below as well as cutting the drainage pipe.
  • Praise 5
fire water in the hole!!!!!
https://www.youtube.com/watch?v=3VLIy5n1q1I
Hypersonic
He was trying to retrieve his wedding ring. Good man but bad luck
A man who was trying to retrieve his wedding ring from a toilet's drainage trap had his hand stuck for almost nine hours before the Singapore Civil Defence Force cut him free yesterday. http://str.sg/3VJ
