VellfireS 4th Gear May 14, 2013 Share May 14, 2013 NB.....which gal you're rushing to meet ah??? HAHA.. no la.. not here.. I just was tempted to chiong.. maybe sugar rush.. coz was having Magnum ice cream before that.. ↡ Advertisement Link to post Share on other sites More sharing options...
WTF 4th Gear May 14, 2013 Share May 14, 2013 HAHA.. no la.. not here.. I just was tempted to chiong.. maybe sugar rush.. coz was having Magnum ice cream before that.. not because you were 'busy' with someone in the car when driving??? Link to post Share on other sites More sharing options...
VellfireS 4th Gear May 14, 2013 Share May 14, 2013 not because you were 'busy' with someone in the car when driving??? HAHA.. that one not on HW la.. that one in secluded carpark in..... Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 14, 2013 Share May 14, 2013 heard one should not go too fast after patching tyre we heard many thing but still many thing we not yet heard A properly inspected and repaired tyre is safe to use for street driving Not for motorsport. Many people driving with injured tyre without any problem because they did not know they had a injured tyre. After the problem occurred they thought is something else caused it (like aya this tyre lousy , or I am very unlucky may be I hit something or the tyreman did not do a good repaired job etc.) Be safe, tyres are the only 4 contacts Get a Good tyre and maintain it well with proper repaired if required Link to post Share on other sites More sharing options...
TVT Supercharged June 4, 2013 Share June 4, 2013 Hi. Just found out one of my rear tyre had a metal object (probably about 2-3cm) sliced into it horizontally. I dare not remove it for fear the air will come out. Now the tyre still intact with no leakage of air... Question is : is it safe to drive to the tyre shop with such an object 'attached' to the tyre? Will it burst out half way at high speed or when it hits a hump? Or I better change to the spare ....? Link to post Share on other sites More sharing options...
VenomMX 4th Gear June 4, 2013 Share June 4, 2013 Hi. Just found out one of my rear tyre had a metal object (probably about 2-3cm) sliced into it horizontally. I dare not remove it for fear the air will come out. Now the tyre still intact with no leakage of air... Question is : is it safe to drive to the tyre shop with such an object 'attached' to the tyre? Will it burst out half way at high speed or when it hits a hump? Or I better change to the spare ....? If your tyre shop is located near to your house, can actually just drive there slowly.. Some petrol stations have the patching services too.. Good luck! :) Link to post Share on other sites More sharing options...
13177 Hypersonic June 5, 2013 Share June 5, 2013 heard one should not go too fast after patching tyre What's the reason le? Link to post Share on other sites More sharing options...
Fcw75 Hypersonic June 5, 2013 Share June 5, 2013 What's the reason le? Must have 'heard' from his friend's uncle's brother's friend la. What crap! Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 5, 2013 Share June 5, 2013 (edited) Hi. Just found out one of my rear tyre had a metal object (probably about 2-3cm) sliced into it horizontally. I dare not remove it for fear the air will come out. Now the tyre still intact with no leakage of air... Question is : is it safe to drive to the tyre shop with such an object 'attached' to the tyre? Will it burst out half way at high speed or when it hits a hump? Or I better change to the spare ....? Did you drive past TPE towards SLE near the construction area? I drove past there on Friday night. Something cut my tyre there and it burst straight away. It didn't even get stuck in my tyre, just cut and and pop, there goes my tyre. Oh ya, to answer your question, better change to spare first before driving off. Edited June 5, 2013 by Beehive3783 Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 5, 2013 Share June 5, 2013 If your tyre shop is located near to your house, can actually just drive there slowly.. Some petrol stations have the patching services too.. Good luck! :) I don't agree. Continuous driving with an embedded object may actually damage the tyre to the extent of no repair. Best to change to spare before driving off. Link to post Share on other sites More sharing options...
13177 Hypersonic June 5, 2013 Share June 5, 2013 If your tyre shop is located near to your house, can actually just drive there slowly.. Some petrol stations have the patching services too.. Good luck! :) Also must depends on how serious your tyre puncture. If too flat, quite dangerous to drive cause the tyre might burst into hole. Link to post Share on other sites More sharing options...
TVT Supercharged June 5, 2013 Share June 5, 2013 Thanks for all your replies. This morning went down with wife to evaluate the situation and manage to pull out the object with a pair of pliers, after carefully analysis what was the angle of the penetration. Find out it did not pierce 90 degree directly into the tyre but was pierce across diagonally. The object was a broken long nail, probably 5-6cm long, and cuts into the tyre outer layer, creating a hole and some gaps, but not deep enough to make the air inside leak out. Will find a tyre shop in the weekend to patch up that hole and gaps. Link to post Share on other sites More sharing options...
TVT Supercharged June 5, 2013 Share June 5, 2013 Did you drive past TPE towards SLE near the construction area? I drove past there on Friday night. Something cut my tyre there and it burst straight away. It didn't even get stuck in my tyre, just cut and and pop, there goes my tyre. Oh ya, to answer your question, better change to spare first before driving off. Oh, my wife been using the car for the past 2 days, so I don't know where she drove to... But the area I stayed in (Punggol) has lots of construction sites, so I guess the chances of me getting such a "bad luck" is pretty high... Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 5, 2013 Share June 5, 2013 Thanks for all your replies. This morning went down with wife to evaluate the situation and manage to pull out the object with a pair of pliers, after carefully analysis what was the angle of the penetration. Find out it did not pierce 90 degree directly into the tyre but was pierce across diagonally. The object was a broken long nail, probably 5-6cm long, and cuts into the tyre outer layer, creating a hole and some gaps, but not deep enough to make the air inside leak out. Will find a tyre shop in the weekend to patch up that hole and gaps. If no puncture then you probably don't need to do anything at all. Link to post Share on other sites More sharing options...
VenomMX 4th Gear June 5, 2013 Share June 5, 2013 Also must depends on how serious your tyre puncture. If too flat, quite dangerous to drive cause the tyre might burst into hole. Yup.. But he mentioned no leakage of air yet.. Link to post Share on other sites More sharing options...
Andy_khoo81 Neutral Newbie May 12, 2016 Share May 12, 2016 Guys, do not use worm type patch if going long distance esp in my case. The worm was repaired 1 year ago and as time goes, it goes thin. The weather on tar/road is hot and cold under sun and rain that day. It happened during my drive along NS highway. Gave a pop champagne sound and left rear type goes burst. again. still can see the hole. Tried repair with slime repair kit and pump air but does not work. In the end change to my spare tyre which is also temporary type. Bad luck and dangerous esp with young kids. My advice is if can just do the proper patch repair or best change to 2nd hand punctured free tyre or new tyre. Link to post Share on other sites More sharing options...
Roberttan 5th Gear May 14, 2016 Share May 14, 2016 Guys, do not use worm type patch if going long distance esp in my case. The worm was repaired 1 year ago and as time goes, it goes thin. The weather on tar/road is hot and cold under sun and rain that day. It happened during my drive along NS highway. Gave a pop champagne sound and left rear type goes burst. again. still can see the hole. Tried repair with slime repair kit and pump air but does not work. In the end change to my spare tyre which is also temporary type. Bad luck and dangerous esp with young kids. My advice is if can just do the proper patch repair or best change to 2nd hand punctured free tyre or new tyre. sorry to hear about your bad encounter with worm repair (not Patch) which is done from outside without remove from your metal rim Internal repair (separate tire from rim) is highly recommended by most Quality tire manufacturers. It seems like still many had repaired by worm or injection method without any issue To me is too late to know when you have encountered it Thanks for sharing the subject And just to share with you your option other than proper repair or change to 2nd hand punctured free tire I disagree with this 2nd option because by doing so you will neglect the Quality of the 2nd hand tires. Quality of tires is key factor when choosing a tire just MHO ↡ Advertisement Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
