Tianmo Hypersonic July 13, 2010 Share July 13, 2010 It's a one-man task if you have the right tools. For shops that are primitive in out look without brake bleeder and auto fulid refiller will require one mech, one assistant and the boss acting as operation director ( with eye power so to say ). But if it is DIY, I think chances are don't have so many tools leh, I called up stamford tyres, even they are using the 2 man 1 pump 1 collect method leh. Was just thinking maybe can do a buddy buddy DIY, so 2 car can change together. ↡ Advertisement Link to post Share on other sites More sharing options...
Yeobh 4th Gear July 13, 2010 Share July 13, 2010 Brake bleeders have been in the market since I started selling in the late 1970's. With ABS Brake system,without such tools, brake bleeding can never be 100% air bubble free. That's why many cars owners in Spore always complaint of "soft brakes". Link to post Share on other sites More sharing options...
Yuan 6th Gear July 13, 2010 Share July 13, 2010 all right man. Better flush my brake fluid during the next servicing as my car is more than 3 years old. Whats the market rate for flushing brake fluid? It should not be too expensive with the fluid supplied from workshop and the labour charges. Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 13, 2010 Share July 13, 2010 yup, not that ex actually. stamford is charging only $35. Just that they are also using the old system. maybe I just go there and get it done, easier! Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 13, 2010 Author Share July 13, 2010 (edited) bro, how are you going to change the fluid alone? ================= I'll b doing it at my mechs ws. We prob do it together & maybe the power steering fluid as well, if he has the time. Edited July 13, 2010 by Pisces69 Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 13, 2010 Author Share July 13, 2010 I offer to help, so that I can learn how to DIY change the brake fluid leh =============== U r welcome to come & see how we do it but I also still not sure when I wil do it. Maybe after my regular EO service in a month or two only. I usually check with my mech when he free after I have got all the necessary oils & parts. Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 13, 2010 Author Share July 13, 2010 It's a one-man task if you have the right tools. For shops that are primitive in out look without brake bleeder and auto fulid refiller will require one mech, one assistant and the boss acting as operation director. =============== Hahaha. So in bad times I only see the boss as redundant & sud b the 1st to go. Link to post Share on other sites More sharing options...
Tianmo Hypersonic July 13, 2010 Share July 13, 2010 =============== U r welcome to come & see how we do it but I also still not sure when I wil do it. Maybe after my regular EO service in a month or two only. I usually check with my mech when he free after I have got all the necessary oils & parts. yup interested leh. Please keep me posted when you changing, I will come and take a look.................and hopfully can be of help or at least can buy coffee! Link to post Share on other sites More sharing options...
Pisces69 6th Gear July 13, 2010 Author Share July 13, 2010 yup interested leh. Please keep me posted when you changing, I will come and take a look.................and hopfully can be of help or at least can buy coffee! =============== Hahaha. No need to buy coffee lah. Anyway when I busy doing the car, I no time to drink coffee also. Only hope I can remember to call u when I going to do it cos might b in a couple of months time. I getting a little old so memory not so good leh plus I usually just do it once I am free & my mech also got time. So can b a "last minute" kind of thing but I sure wil contact u if I remember. Anyway its a simple job. Just connect the drain tube to nipple & 1 person pump the brakes & the other just keep filling the reservoir to make sure no air goes in. Do 1 brake at a time so just repeat 4 times & its done. Link to post Share on other sites More sharing options...
Beehive3783 Twincharged August 14, 2010 Share August 14, 2010 ============= OK thanks for the warning. BTW what is the ill effects of using Dot 5 & what causes it? ok late reply.. dot5 contains something that dot3 and dot4 doesn't have.. and this ingredient will corrode your brake system if it is not designed to take dot5 Link to post Share on other sites More sharing options...
Pisces69 6th Gear August 14, 2010 Author Share August 14, 2010 ok late reply.. dot5 contains something that dot3 and dot4 doesn't have.. and this ingredient will corrode your brake system if it is not designed to take dot5 ============== Ya thanks. I found out already. I wil stick to Original brake fluid or at least Dot 3 or 4. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Changing halogen to LED
Brake Pads
Brake Pads
How close to wear indicators before changing tires?
Brake squeak every morning
