Beehive3783 Twincharged June 30, 2010 Share June 30, 2010 Acherly, bro Limiter is correct. Brake fluid will not improve your braking distance or performance. Change of brake fluid annually is to remove the moisture from the fluid due to our common start stop traffic conditions in Singapore. It is your tires and brake pads that stop your car. Invest in those. But you must also know that brake fluid, if not changed regularly, will affect your braking performance. Your brake fluid's boiling temperature will be lowered, hence you will experience brake fade/cooked brakes faster than when you just changed your brake fluid. ↡ Advertisement Link to post Share on other sites More sharing options...
Watwheels Supersonic June 30, 2010 Share June 30, 2010 (edited) ================ Can tell what brand u used (Dot 4) & where u buy? Thanks. I got it flush and replaced at Autobac Ubi. They let me choose from their range of products. I chose Liqui Moly. They hold quite a few of well known brands from DOT4 to 5.1. Labour 20bucks plus they let me choose the brake fluid. I even get to watch the mechanic work on my car at the aircon waiting lounge. I did the power steering fluid flush at the same time. Edited June 30, 2010 by Watwheels Link to post Share on other sites More sharing options...
Kangadrool Supersonic June 30, 2010 Share June 30, 2010 ================ Last time my old Corona I did a flush using Lockheed Dot 5. I did a ATF flush there long ago & they used some unknown brand of ATF & a short while later my autobox started to give me trouble. Actually there is no need to flush ATF. Just changing it annually according to the factory's specs will do. Don't even think of changing better grade ATF. If the specs say "DIII" , strictly use DIII. Think flushing will just give the ATF system a "SHOCK". [laugh] Link to post Share on other sites More sharing options...
Tetra77 Neutral Newbie June 30, 2010 Share June 30, 2010 But you must also know that brake fluid, if not changed regularly, will affect your braking performance. Your brake fluid's boiling temperature will be lowered, hence you will experience brake fade/cooked brakes faster than when you just changed your brake fluid. Yo Bro Beehive3783, you managed to flush your brakes and clutch properly yet? Link to post Share on other sites More sharing options...
Yuan 6th Gear June 30, 2010 Share June 30, 2010 But you must also know that brake fluid, if not changed regularly, will affect your braking performance. Your brake fluid's boiling temperature will be lowered, hence you will experience brake fade/cooked brakes faster than when you just changed your brake fluid. Yup. You are right. Link to post Share on other sites More sharing options...
Puteh Clutched June 30, 2010 Share June 30, 2010 Thanks guys, very informative tread. Before this, I thought all brake fluid were the same! Link to post Share on other sites More sharing options...
Kb27 Supersonic June 30, 2010 Share June 30, 2010 Even between brands, I think there's a difference in quality during manufacturing. Brake fluid is cheap enough for me to stay with the big brands like ATE and avoid unknown local/MY brands. Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 30, 2010 Share June 30, 2010 Yo Bro Beehive3783, you managed to flush your brakes and clutch properly yet? hi bro , i heck care liao.. next year will do a proper one.. and so far brakes and clutch are ok.. no issues so far. Link to post Share on other sites More sharing options...
Tetra77 Neutral Newbie June 30, 2010 Share June 30, 2010 hi bro , i heck care liao.. next year will do a proper one.. and so far brakes and clutch are ok.. no issues so far. Yeah, don't waste the new ATE SL.6 brake fluid, at least a partial change is better than no change Next time find those workshop that has a vacuum machine to flush the brake fluid Link to post Share on other sites More sharing options...
Tetra77 Neutral Newbie June 30, 2010 Share June 30, 2010 Hi guys, I have done a ATE Super Blue Racing brake fluid Group Buy in Clubhyundai recently. I have checked with my supplier from overseas and they have ready-stock now. I can get the stock in at $17 per 1L can, with payment on collection during meetup. Anybody interested? Link to post Share on other sites More sharing options...
Beehive3783 Twincharged June 30, 2010 Share June 30, 2010 Hi guys, I have done a ATE Super Blue Racing brake fluid Group Buy in Clubhyundai recently. I have checked with my supplier from overseas and they have ready-stock now. I can get the stock in at $17 per 1L can, with payment on collection during meetup. Anybody interested? Wah liew.. now got stock.. too bad la.. wait for me to finish my 2+ cans of SL.6 first.. Anyway hor please post your sales in marketplace http://www.mycarforum.com/index.php?autocom=classified Link to post Share on other sites More sharing options...
Limiter Neutral Newbie June 30, 2010 Share June 30, 2010 If i am not wrong, DOT 5 is used on heavy vehicle like class 4 and 5 mostly. Link to post Share on other sites More sharing options...
TortoiseRacer Clutched June 30, 2010 Share June 30, 2010 If i am not wrong, DOT 5 is used on heavy vehicle like class 4 and 5 mostly. errrmm.. DOT 5 not used for racing cars one meh? For normal street cars, DOT 3, 4, 5.1 is ok. Link to post Share on other sites More sharing options...
Yeobh 4th Gear June 30, 2010 Share June 30, 2010 Originally formulated for the army vehicles. Link to post Share on other sites More sharing options...
TortoiseRacer Clutched June 30, 2010 Share June 30, 2010 Originally formulated for the army vehicles. oooh.. didn't know that.. Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 30, 2010 Author Share June 30, 2010 DOT5 will cause problems if your car's braking system is not designed to take DOT5. Don't risk it! Either DOT3 or DOT4 will do. ============= OK thanks for the warning. BTW what is the ill effects of using Dot 5 & what causes it? Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 30, 2010 Author Share June 30, 2010 Acherly, bro Limiter is correct. Brake fluid will not improve your braking distance or performance. Change of brake fluid annually is to remove the moisture from the fluid due to our common start stop traffic conditions in Singapore. It is your tires and brake pads that stop your car. Invest in those. ============ Ya I just read from Beehive & Yeobh that I cannot use Dot 5. Lucky I checked it out b4 I had it changed. Guess I'll just use Dot 3 or 4 then. Link to post Share on other sites More sharing options...
Pisces69 6th Gear June 30, 2010 Author Share June 30, 2010 I got it flush and replaced at Autobac Ubi. They let me choose from their range of products. I chose Liqui Moly. They hold quite a few of well known brands from DOT4 to 5.1. Labour 20bucks plus they let me choose the brake fluid. I even get to watch the mechanic work on my car at the aircon waiting lounge. I did the power steering fluid flush at the same time. ============ OK thanks. Now I know more about brake fluid so can change with confidence. ↡ Advertisement Link to post Share on other sites More sharing options...
Changing of Spark Plugs
Changing halogen to LED
Brake Pads
Brake Pads
How close to wear indicators before changing tires?
Brake squeak every morning
