Zyrofillica 1st Gear June 30, 2010 Share June 30, 2010 wah lau my jeppun 1998 pok chia also will cut off aircon,radio,internal lights before cranking. 1998 pok chia ecu as good as kia and vw leh lol~ nowadays no need to worry about such things ba, the car getting smarter. Start to worry when cars start driving themselves! ↡ Advertisement Link to post Share on other sites More sharing options...
5936 1st Gear June 30, 2010 Share June 30, 2010 Wow, 360 checklist. R u a pilot? Good habit to do all round visual check before move off, Not much extra seconds required. More smart cars around, so less work for pre-start sequence for driver. make driver easier... Link to post Share on other sites More sharing options...
BoneStock 5th Gear June 30, 2010 Share June 30, 2010 Hello! Just some doubts that you guys can help: When you start your car EVERYTIME, is it better to switch off aircon and radio first? Or just aircon enough? Or it is perfectly alright just leave them on when switiching off and starting up your car? Read somewhere that it affects the car battery or alternator or something like that.. Cheers Not necessary. Most cars ECU will only turn on aircon compressor few seconds after the engine is started. In my 25 years of driving, I have never turned off aircon or radio before starting the car...even for the old carburetted engines. Even if this has negative effects on battery it is minimal...so just enjoy driving and not worry too much. Link to post Share on other sites More sharing options...
Krado Clutched June 30, 2010 Share June 30, 2010 I start my car by... 1. open door 2. sit down, chuck stuff in back seat, put key in 3. damn, is that a parking summon or a stupid flyer? 4. get out of car to remove the trash on windscreen 5. beo beo tyres a bit to check whether those ginnas around the place got play punk at night or not 6. realize i need get kopi for my morning drive 7. take out key and cross the road to buy kopi 8. come back, open door, put key in 9. get out to chase away the cat that's still sleeping on my boot 10. get back in and crank 11. crank again because the car's lazier than me and still hasn't woken up 12. put on seat belt, turn on headlights, turn on radio, turn on aircon 13. drive straight into the jam in my carpark that's just formed because of the school next door 14. turn on handphone and go rant about peak hour jams in some forum car battery and alternator? wear and tear items lah. Huh?! I can beat you.. I.. 1. Open passenger door 2. Open glove box take pressure gauge 3. Check all 4 tires 4. Close passenger door 5. Open driver door 6. Pull bonnet release 7. Open bonnet 8. Check oil level 9. Check PS fluid level 10. Check washer bottle level 11. Find sleeping cat (don't say it will never happen, my friend found a kitten sleeping before 12. Look under car for oil leak 13. Close bonnet 14. Get in 15. Pull down driver visor 16. Flip up vanity mirror cover 17. Check reflection 18. Adjust hair style 19. Insert key 20. Turn key 21. Make sure everything off 22. Shake gearstick 23. Check mileage 24. Check fuel level 25. Check indicator 26. Turn on lights 27. Turn on hazard lights 28. Get out 29. Walk around car, ensure all lights are on 30. Get in 31. Jam brake pedal with umbrella 33. Check if third brake light is on 34. Stow umbrella 35. Check drinking water level 36. Start engine 37. On fan 38. On radio 39. Adjust air vent (by now you're damn hot) 40. On air con 41. Relax 5 minute 42. Move off How's that? Link to post Share on other sites More sharing options...
Unitek 1st Gear June 30, 2010 Share June 30, 2010 I'm curious too. when i stop my engine, radio still play. it will automatically cuts off when i open the door. I was told this is a feature but i wonder does it hurts the battery? Just to add. Some cars like my current Passat, it's ok to leave the electrical stuff on because the ECU is "smart" enough to cut the current batnt to all electrical stuff during cranking and switch them on only 2 or 3 secs after the engine has started up. But then, I still switch everything off due to habit. Link to post Share on other sites More sharing options...
Requiemdk 1st Gear June 30, 2010 Share June 30, 2010 Huh?! I can beat you.. I.. 1. Open passenger door 2. Open glove box take pressure gauge 3. Check all 4 tires 4. Close passenger door 5. Open driver door 6. Pull bonnet release 7. Open bonnet 8. Check oil level 9. Check PS fluid level 10. Check washer bottle level 11. Find sleeping cat (don't say it will never happen, my friend found a kitten sleeping before 12. Look under car for oil leak 13. Close bonnet 14. Get in 15. Pull down driver visor 16. Flip up vanity mirror cover 17. Check reflection 18. Adjust hair style 19. Insert key 20. Turn key 21. Make sure everything off 22. Shake gearstick 23. Check mileage 24. Check fuel level 25. Check indicator 26. Turn on lights 27. Turn on hazard lights 28. Get out 29. Walk around car, ensure all lights are on 30. Get in 31. Jam brake pedal with umbrella 33. Check if third brake light is on 34. Stow umbrella 35. Check drinking water level 36. Start engine 37. On fan 38. On radio 39. Adjust air vent (by now you're damn hot) 40. On air con 41. Relax 5 minute 42. Move off How's that? Why you close passenger door but never close the driver door? Dangerous leh Link to post Share on other sites More sharing options...
Silver_blade Turbocharged June 30, 2010 Share June 30, 2010 I don't switch off anything when I cut off the engine...cos modern cars will cut off electrical supply to non-essential equipments during startup. Link to post Share on other sites More sharing options...
Requiemdk 1st Gear June 30, 2010 Share June 30, 2010 Wow, 360 checklist. R u a pilot? Good habit to do all round visual check before move off, Not much extra seconds required. More smart cars around, so less work for pre-start sequence for driver. make driver easier... No, I don't drive a Saab. And yes it's surprising how many people don't at least visually check their car before getting in. It only takes a couple of seconds after all... Link to post Share on other sites More sharing options...
Jman888 Moderator June 30, 2010 Share June 30, 2010 Huh?! I can beat you.. I.. 1. Open passenger door 2. Open glove box take pressure gauge 3. Check all 4 tires 4. Close passenger door 5. Open driver door 6. Pull bonnet release 7. Open bonnet 8. Check oil level 9. Check PS fluid level 10. Check washer bottle level 11. Find sleeping cat (don't say it will never happen, my friend found a kitten sleeping before 12. Look under car for oil leak 13. Close bonnet 14. Get in 15. Pull down driver visor 16. Flip up vanity mirror cover 17. Check reflection 18. Adjust hair style 19. Insert key 20. Turn key 21. Make sure everything off 22. Shake gearstick 23. Check mileage 24. Check fuel level 25. Check indicator 26. Turn on lights 27. Turn on hazard lights 28. Get out 29. Walk around car, ensure all lights are on 30. Get in 31. Jam brake pedal with umbrella 33. Check if third brake light is on 34. Stow umbrella 35. Check drinking water level 36. Start engine 37. On fan 38. On radio 39. Adjust air vent (by now you're damn hot) 40. On air con 41. Relax 5 minute 42. Move off How's that? i got voice command, 1. door open 2. engine on 3. roll out Link to post Share on other sites More sharing options...
Grix17 Clutched June 30, 2010 Share June 30, 2010 I don't off auto headlights for a good reason....my wife may forget to on it when she drives the car...too used to auto headlights already. I think all cars should have auto headlights. I have noticed an increasing number of cars going around at night with lights OFF. The design of the dash and console (the meters are all lit) now makes it difficult for some drivers to realise the lights aren't on. Link to post Share on other sites More sharing options...
Grix17 Clutched June 30, 2010 Share June 30, 2010 I'm curious too. when i stop my engine, radio still play. it will automatically cuts off when i open the door. I was told this is a feature but i wonder does it hurts the battery? Hmm .. how about auto-folding mirrors? Will they affect battery too? Link to post Share on other sites More sharing options...
Krado Clutched June 30, 2010 Share June 30, 2010 I think all cars should have auto headlights. I have noticed an increasing number of cars going around at night with lights OFF. The design of the dash and console (the meters are all lit) now makes it difficult for some drivers to realise the lights aren't on. I configured the lighting in a way that if the dash is damn bright at night, means i never turn on lights. I always switch off the main lights when I entering carpark, leaving the pole lights on. However when I drop my friends off, sometimes I forget to switch on the main lights. Heh. Until I get to a very dark road ( a.k.a street light spoil ) Link to post Share on other sites More sharing options...
Dunno Neutral Newbie June 30, 2010 Share June 30, 2010 Those whose cars have installed a voltage and ampere meter can test it yourself. Check the voltage and current when you are cranking to see how low it drops with and without everythign turned on. If no difference, then you can do whatever you want, off or don't off. Just beware that instead of the battery, the items that got their current cut off may die faster. Even if your ECU cuts the current to the electrical stuff, it's not healthy to those equipments in the long run. It's just the same logic with any electric appliances. Do you switch them off using the power switch or you leave the power switch permanently on and use the main wall socket to off/on the appliance? There's always a reason why there's a power switch. Just like your PC. You do a proper shutdown instead of pulling the power plug. That's my own opinion. Link to post Share on other sites More sharing options...
Dunno Neutral Newbie June 30, 2010 Share June 30, 2010 I configured the lighting in a way that if the dash is damn bright at night, means i never turn on lights. I always switch off the main lights when I entering carpark, leaving the pole lights on. However when I drop my friends off, sometimes I forget to switch on the main lights. Heh. Until I get to a very dark road ( a.k.a street light spoil ) when I was driving cars without auto headlights, I always switch on the main headlights when I enter any sheltered car park. This is to enable the beam to shine ahead so that other drivers will know in advance that you are approaching, especially during turns where there are blind spots. The other car can see your lights shining against the wall. Link to post Share on other sites More sharing options...
Mandan Neutral Newbie June 30, 2010 Share June 30, 2010 Huh?! I can beat you.. I.. 1. Open passenger door 2. Open glove box take pressure gauge 3. Check all 4 tires 4. Close passenger door 5. Open driver door 6. Pull bonnet release 7. Open bonnet 8. Check oil level 9. Check PS fluid level 10. Check washer bottle level 11. Find sleeping cat (don't say it will never happen, my friend found a kitten sleeping before 12. Look under car for oil leak 13. Close bonnet 14. Get in 15. Pull down driver visor 16. Flip up vanity mirror cover 17. Check reflection 18. Adjust hair style 19. Insert key 20. Turn key 21. Make sure everything off 22. Shake gearstick 23. Check mileage 24. Check fuel level 25. Check indicator 26. Turn on lights 27. Turn on hazard lights 28. Get out 29. Walk around car, ensure all lights are on 30. Get in 31. Jam brake pedal with umbrella 33. Check if third brake light is on 34. Stow umbrella 35. Check drinking water level 36. Start engine 37. On fan 38. On radio 39. Adjust air vent (by now you're damn hot) 40. On air con 41. Relax 5 minute 42. Move off How's that? u sure u shake gear stick or your..... Link to post Share on other sites More sharing options...
Fedex67 Neutral Newbie June 30, 2010 Share June 30, 2010 hi all, I just came back from Malaysia and realised that my maid forget to off the internal lights in the car. I cant start my car this morning. This is not the first time. I have to call AA to jump start my car and it cost hundreds of dollars. Does anyone know if there is any alternatives? Rgds John Link to post Share on other sites More sharing options...
RadX Moderator June 30, 2010 Share June 30, 2010 hi all, I just came back from Malaysia and realised that my maid forget to off the internal lights in the car. I cant start my car this morning. This is not the first time. I have to call AA to jump start my car and it cost hundreds of dollars. Does anyone know if there is any alternatives? Rgds John change the maid eh AA where got charge you hundreds dollars wan?? free leh?? Link to post Share on other sites More sharing options...
Swiftee Clutched July 1, 2010 Share July 1, 2010 hi all, I just came back from Malaysia and realised that my maid forget to off the internal lights in the car. I cant start my car this morning. This is not the first time. I have to call AA to jump start my car and it cost hundreds of dollars. Does anyone know if there is any alternatives? Rgds John AA if u member is FREE. If u DBS card holder better no need member call STAR is also FREE. ↡ Advertisement Link to post Share on other sites More sharing options...
Xiaomi EV is Coming
Xiaomi EV is Coming
New Age Polish --> Chevrolet Portfolio
COE Bidding – Mar 2025
