cckboy 2nd Gear August 22, 2019 Share August 22, 2019 Polish based on the condition of the paintwork. If you see fine scratches and swirl marks all over your car, regardless of age, then might be a good idea to polish. Remember polishing actually removes a top layer of clearcoat to get rid of the scratches. If you polish too much, then eventually you will run out of clearcoat and start polishing off the paint itself (which is bad). Really depends on how well your upkeep is or not. I clean my 6 month old car every week and apply a new layer of wax on every other week. When I got the car I put 3 layers of wax on it (with curing time in between). To date, I have minimal scratch or swirl marks - so no need to polish. If your friend polished the car when there were no scratches or swirls, then he's wasting energy and shortening the lifespan of the paintwork. If its because you just want the exercise, then there are some polishes without 'cut' AND just a glaze to fill the scratches. Something like meguiars ultimate polish. Or you could just polish someone else's car. I saw a maid clean a new E-class at my Condo. Made me cry. Was using dishwashing liquid to clean the car and to dry the car down she just used newspaper. Bro, may I know what wax brand you are using? I liked to use Osren sealant for my previous car, but it's not common everywhere. Would like to seek alternative. ↡ Advertisement Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear August 22, 2019 Share August 22, 2019 (edited) During the collection, my SE advised to use the normal car shampoo (without any wax) will do. Reason is because the car came with the brila coating already, hence any waxing content may reduce or strip the effectiveness of the brila coating. I'm currently using autoglym ( PH Neutral) car shampoo from autobacs. Sounds like the Brila coating is not very durable, one wash and off it goes? Edited August 22, 2019 by andrewyewkc Link to post Share on other sites More sharing options...
aztreonam 1st Gear August 22, 2019 Share August 22, 2019 Sounds like the Brila coating is not very durable, one wash and off it goes?Brila is an inorganic compound that can only be removed totally using a special removal agent, or naturally worn off by weather elements. Wax in shampoo only makes the car looks smudged as the wax has no paint to adhere to. Again, wax can still be removed by shampoo if accidentally applied on brila. 1 Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear August 22, 2019 Share August 22, 2019 Brila is an inorganic compound that can only be removed totally using a special removal agent, or naturally worn off by weather elements. Wax in shampoo only makes the car looks smudged as the wax has no paint to adhere to. Again, wax can still be removed by shampoo if accidentally applied on brila. Thanks for the clarification. Link to post Share on other sites More sharing options...
GTO-1 5th Gear August 22, 2019 Share August 22, 2019 Bro, may I know what wax brand you are using? I liked to use Osren sealant for my previous car, but it's not common everywhere. Would like to seek alternative.I'm using meguiars nxt wax. It's fully synthetic, but works well on a red car, easy to apply and quick to dry and clean off. I also actually use meguiars hybrid ceramic wax which I layer top of the NXT wax. It's water activated and pretty easy to apply. Just apply it as part of my routine to dry the car. 1 Link to post Share on other sites More sharing options...
Skywire01 1st Gear August 22, 2019 Share August 22, 2019 Sounds like the Brila coating is not very durable, one wash and off it goes?Never said it was just one wash or how many washes. But its just something that SE advised to use normal shampoo will do. Link to post Share on other sites More sharing options...
MI6 Clutched August 22, 2019 Share August 22, 2019 Yes my SE also advise just use water or shampoo without wax, so I'm quite confused when some of u guys are using shampoo with wax content. Anyway thanks for all the advise. Right now am only using washing with just water about twice a week. Was trying to get advice on when to start applying or recoat Brila again. Anyway still do not know the difference between wax n polish. Or is there a difference? Link to post Share on other sites More sharing options...
Skywire01 1st Gear August 22, 2019 Share August 22, 2019 Yes my SE also advise just use water or shampoo without wax, so I'm quite confused when some of u guys are using shampoo with wax content. Anyway thanks for all the advise. Right now am only using washing with just water about twice a week. Was trying to get advice on when to start applying or recoat Brila again. Anyway still do not know the difference between wax n polish. Or is there a difference? IMO, using just water is not good enough to wash off the dirt. It might even make things worse. Just imagine - if the surface stil have dirt after water washing and then you use a cloth to wipe across the surface...you may end up "scratching" the top level of coating. Anyway it's just my layman terms and my own thoughts. Link to post Share on other sites More sharing options...
Davidklt Supercharged August 22, 2019 Share August 22, 2019 Anyway, its just a car. Who cares? Does not do anything for you or your car. IMO, using just water is not good enough to wash off the dirt. It might even make things worse.Just imagine - if the surface stil have dirt after water washing and then you use a cloth to wipe across the surface...you may end up "scratching" the top level of coating.Anyway it's just my layman terms and my own thoughts. Link to post Share on other sites More sharing options...
andrewyewkc 5th Gear August 23, 2019 Share August 23, 2019 IMO, using just water is not good enough to wash off the dirt. It might even make things worse. Just imagine - if the surface stil have dirt after water washing and then you use a cloth to wipe across the surface...you may end up "scratching" the top level of coating. Anyway it's just my layman terms and my own thoughts. Agree, washing with just water is not advisable as it may not dissolve any organic residues. A detergent or surfactant is necessary. Link to post Share on other sites More sharing options...
Patwong 3rd Gear August 23, 2019 Share August 23, 2019 Own car for over 1.5years from new. Sales lady mentioned just use water wash will do due to coating. I seldom wash car on own, not in my daily routine, but new car so 'on' a bit. Due to coating, there is this "pebble" effect and the dirt and dust on car body was visibly. Can wipe off easily with damp cloth. Tried own wash but not also went car wash at petrol kiosk. The pebble effect wear off after 6 mths (I think). And dirt less visibly (silver car). Now, only wash at petrol kiosk. Above for people that just want clean car, not "kim kim" car. 1 Link to post Share on other sites More sharing options...
cckboy 2nd Gear August 23, 2019 Share August 23, 2019 (edited) I'm using meguiars nxt wax. It's fully synthetic, but works well on a red car, easy to apply and quick to dry and clean off. I also actually use meguiars hybrid ceramic wax which I layer top of the NXT wax. It's water activated and pretty easy to apply. Just apply it as part of my routine to dry the car. Thanks bro! I'll give it a try Edited August 23, 2019 by cckboy Link to post Share on other sites More sharing options...
MI6 Clutched August 23, 2019 Share August 23, 2019 Another question, is the majority of u guys using 98 or 95 petrol? Been using 98 since day one, am thinking of switching to 95... any advice? Trying to save some $..... Link to post Share on other sites More sharing options...
Skywire01 1st Gear August 23, 2019 Share August 23, 2019 (edited) Another question, is the majority of u guys using 98 or 95 petrol? Been using 98 since day one, am thinking of switching to 95... any advice? Trying to save some $..... Using 95 ron from day 1. Edited August 23, 2019 by Skywire01 Link to post Share on other sites More sharing options...
ER-3682 Twincharged August 23, 2019 Share August 23, 2019 Another question, is the majority of u guys using 98 or 95 petrol? Been using 98 since day one, am thinking of switching to 95... any advice? Trying to save some $..... 98 for the best performance because of High Compression. Link to post Share on other sites More sharing options...
Skywire01 1st Gear August 26, 2019 Share August 26, 2019 Hi. Anyone install TPMS with external sensors? Any feedback and recommendations? Link to post Share on other sites More sharing options...
josephywj 1st Gear August 26, 2019 Share August 26, 2019 On 8/23/2019 at 9:52 PM, Skywire01 said: Using 95 ron from day 1. I'm also on SPC ron 95 since day 1. Been great for me. 50-50 urban/city. Getting at least 8L/100km 🙂 I feel not worth paying for 98 as the FC wasnt fantastic, tried it twice. Link to post Share on other sites More sharing options...
josephywj 1st Gear August 26, 2019 Share August 26, 2019 On 8/22/2019 at 10:24 PM, MI6 said: Yes my SE also advise just use water or shampoo without wax, so I'm quite confused when some of u guys are using shampoo with wax content. Anyway thanks for all the advise. Right now am only using washing with just water about twice a week. Was trying to get advice on when to start applying or recoat Brila again. Anyway still do not know the difference between wax n polish. Or is there a difference? I'm using this SONAX gloss shampoo, brila ppl said it ain't the best but pass. I think brila coating sucks, it gets hairline scratches very easily. But it's free, I'll definitely not get it again after 6mths. ↡ Advertisement Link to post Share on other sites More sharing options...
Mazda FC3S RX-7
Mazda FC3S RX-7
2021 5th Generation Mercedes Benz C-Class (W206)
Nissan N7
Nissan N7
2025 Mazda 6e
2025 Mazda 6e
2026 Mazda EZ-60 / CX-6e
