MAZDA 6
Voxy28
I doubt the bulbs are different, so a D2S will probably work. That said you could certainly go ask an automotive shop, I'm certain at least one will know.
Or you could remove the bulb yourself and inspect it.
I would have removed it myself, but it includes removing the wheelwell covers (rivets, grommets and what not). If only it was doable from the engine bay, would make life much easier.
Really? Would've thought a Japanese marque like Mazda would've made something like that easy to access...
[hur]
Good luck in finding the appropriate bulb!
Mazda service told me that 1000km servicing and 5000km servicing both do not have oil change. What exactly do they do for these two servicing apart from dealing with feedback on issues regarding the new car? Thanks!
Just "molest" your car. [thumbsdown] ..oil change can be done,pay $140++. :a-t9412:
Hi Guys, can i know where can i get M6's rear exhaust ? mine is a 2006 model and i believe they call it the GG model. I think something broken inside the exhaust drum and gives me very annoying sound. It's not a good idea to get a brand new one cos it's too expensive for a less then 1 year old vehicle. Feel free to contact me @ 96359315 if any of you guys scrapping you car soon, so we can swap the exhaust, i will pay for it.
MAZDA 6 (GH) FWD only
Looking for 1 x test car to test brand new prototype shock absorbers.
Shock absorber maker renowned European brand
4 new shock absorbers for testing according to the quality requirements of the part maker.
Conditions:
Assuming the car in fit for road test condition with OE springs, mountings and bushings and suspensions all OK.
4 shock absorbers + installation cost covered
Must go for road test in Singapore
Interested please PM me.
Edited by Fels
Can anyone confirm if the 2nd generation (GH) Mazda 6's replacement main beam xenon bulbs uses D2S 35W bulbs? One of mine blew, would like to see what options I have but google generally only gives me the USA Mazda 6 sites, which may not be accurate for the SG cars.
Thanks
Hi,
Did you manage to change your main xenon bulb?
Mine just turn purplish recently.
Where you change and what's the price?
Thanks.
Hi guys,
I need to clarify on the features of the Mazda 6 variants because so far different SE tell me different things. First time I went for test drive, the SE told me that the Standard and Executive models interior all the same, only exterior different. But another SE at the motorshow said that the Executive has keyless entry but the Standard does not.
So who is correct?
Also, does the 2.0 Mazda 6 come with driver memory seat or only the 2.5 version have?
Hi guys,
So who is correct?
Yes,only Executive got Keyless Entry,as for Memory Seat,2.0 should have.
Executive got fog lights and active display and led hid
Exec model has got sensors for wipers and headlights, as well as daytime running light. Also additional 2 reverse sensors.
any one know where i can find used madza 6 parts?
need to get a 2006 mazda 6 card for signal light.
my light wiring got short circuit due to old wire.
Hi All. My GPS hang and have navigation software issue. Seem like the SD card got problem. Anyone know where the SD card and any quick fix / reload.
Exec 2.0 Pre-Facelift
Mazda mention warranty over and there a charge of $120 to check on that. =(
The SD card is on the right side below the function switch.
Try take out the sd card and install tomtom software(software inside sd card) on your pc and see if it can detect and reinstall on your sd card.
Hi can anyone advise on the recent OMV values for the 2.0L sedan Standard and Executive models? I see quite a bit of disparity online so like to verify.
