Battery indicator, what can be wrong?
Windwaver
Fluid low can be indication of leak.
If you have drum brakes, chances are the brake piston can be leaky.
Another reason why bfluid drop is cos the brake pads or drum shoes wear n fluid wil drop. [nod]
This is the most easiest and cheapest ways to check the car battery and alternator working condition.
The battery may still fail because of, e.g. load.
Ya that's wat my mechanic said over the phone
But I can't go down tdy , very rush
Tmr I flying
Jus top up with dot 4 to Max n monitor from there
Cos year start I jus replace all new pad n piston
Maybe that x top up fluid n slowly subside that's y now slightly Abv min
Hope there's no leak
If I come back n level drop, that's it
Did u chk n cfm yr handbook yr car can use Dot 4?????????? [:/]
Yes of coz.
But pad wear normally is not that serious enough to cause fluid to drop below and triggering the light.
I have many experience with serious loss of fluid and none of them related to pad wear. [:p]
Even when my pad was totally worn down and grinding the rotor, it did not have the brake light coming out...but that's another situation...and totally my fault.
My used car no hand book
But my fren dtiving old ek civic n my Ws mech I calk say get dot 4
Seeing it's small amount think it's ok ba
Ha ha
What will be the effect??
Till now the warning light nb come up
I will see tmr morning one last x
Yes of coz.
Hahaha. Ya the warning light is more to warn of leaks cos usually when u change pads/shoes, u wil also chk n flush n top-up the brake fluid.
But I ever had my pads wear down n the brake warning light did come on to warn me to top-up the brakefluid.
Ha ha
Dot 4 also hv 2 types if Im not mistaken. Synthetic n mineral.
U cannot mix. If u use one type n wan to change to the other, u need to do a through flush of the system first.
U can try to Google on brake fluids especially Dot 4 for more info.
The 12Volt car meter is just a metering indicator reads the car battery cell performing status, loading and charging source is from alternator amperage regulated by appropriate loading discharge capacity, over-loading would cause damage to the car battery if this regulator fail.
Yes of coz.
My brake fluid ever dropped in some levels due to the wear of the brake pads/drums.
Ha ha
Usually I won't encourage top up of brake fluid.
I would advocate change out the old fluid totally and add new fluid in.
Considering your urgent circumstances, this is probably the best option.
My mech actually say top up to drive down to Ws
But I see the timing n my work
I top up n leave it till I'm back
Sometimes things are jus coincidence
Ha ha
My rides usually seldom brrwakdown
Got once took leave go hdb choose flat with wife n son
Radiator burst knn
Stay at Ws few hours
Ha ha
Radiator burst knn
U never take care of yr car hor. [rolleyes]
Assuming starting off with full brake fluid and new pads, my experience is that the wear down of pads down to the "change" time, will drop the fluid level, but usually not enough to trigger the brake lamp.
So when someone sees the brake lamp and the handbrake is off, they should not merely top up brake fluid and be happy.
A check for leaks is needed.
Topping up brake level could be just covering up the problem.
Leaks drop the fluid fairly quickly.
It can come from the joints, drum brake pistons, master brake cylinder or others.
Supercharged
He might have many other "rides" to take care of....so can't cope!
We should be understanding lah... [:p]
Correct. When it happened to mine, my workshop checked thoroughly the entire brake system and noted that there was no leakage or faulty parts but only the wear portion of the pads. This was verified again before they gave an affirmative answer to change what was needed to be changed.
Simi la
If I nb take care of my ride
How to save $ on repairs ha ha
This time time really have to gamble Liao la
Ha ha
Ya when u return, chk if yr car can take the Dot 4 u put in first. If cannot, u need to flush the whole brake fluid out.
Anyway I think u never done that b4, right? Well then its about time. [laugh]
Brakefluid if left too long wil absorb moisture n cause it to b ineffective like poor pedal feel or spongy. Also the moisture can cause the metal components to rust then leak.
Ya now he go overseas to ride horse n maybe bicycle. Come back sure got back pain. [laugh][laugh][laugh]
