Tweakmax2 Neutral Newbie August 27, 2012 Share August 27, 2012 Air con is set to fan mode and not cool air. Meaning it is blowing normal temp air. ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic August 27, 2012 Share August 27, 2012 Air con is set to fan mode and not cool air. Meaning it is blowing normal temp air. Yes,sure save fuel,but must also close your windows. Link to post Share on other sites More sharing options...
5936 1st Gear August 27, 2012 Share August 27, 2012 Yes. Can save fuel. Longer duration will show the difference even more. Save even more during hot afternoon weather. Link to post Share on other sites More sharing options...
Kerwen 6th Gear August 27, 2012 Share August 27, 2012 imo, doesn't save much. It's the driving style that save the most. Link to post Share on other sites More sharing options...
Deckbuild 6th Gear August 27, 2012 Share August 27, 2012 Given same driving style, you will feel you car have more "power" when u off the aircon. If u don't use that power, petrol is saved. Saved the most during acceleration. Cruising with air con doesn't make much difference. Link to post Share on other sites More sharing options...
Dezouk Clutched August 27, 2012 Share August 27, 2012 Imho won't save much. U may just lose all the 'saving' when an instance step of throttle to overtake someone haha Link to post Share on other sites More sharing options...
Kangadrool Supersonic August 27, 2012 Share August 27, 2012 (edited) Air con is set to fan mode and not cool air. Meaning it is blowing normal temp air. The air coming out is actually warm, warmer than surrounding air. On cool night, you may wanna try opening the windows with 1 cm gap and switch the aircon vent to non-recirculating mode. Without aircon, you can feel the immediate power (if you're driving anything below 2L engine). Edited August 27, 2012 by Kangadrool Link to post Share on other sites More sharing options...
Tianmo Hypersonic August 27, 2012 Share August 27, 2012 for me aircon off can do two things............better power and save fuel............I ever try driving without aircon and the different is about 10%...........even with windows half down..........but i don't do it often........only if i am driving alone at night......... :D Link to post Share on other sites More sharing options...
Paddie 3rd Gear August 27, 2012 Share August 27, 2012 Turning off aircon compressor can easily save 10% fuel, more if it's a small engine lower power car like Nissan March etc. Link to post Share on other sites More sharing options...
Blue850r Clutched August 27, 2012 Share August 27, 2012 Air con is set to fan mode and not cool air. Meaning it is blowing normal temp air. Yes you can surely save fuel as the compreesor load on the engine is gone. Link to post Share on other sites More sharing options...
KaKiLang 4th Gear August 27, 2012 Share August 27, 2012 Air con is set to fan mode and not cool air. Meaning it is blowing normal temp air. I find not using aircon, wind down windows, Lam Pa Pa Lun, in our hot weather??? Even in the night, wind down windows, the wind drag will eat up the 10% saved. Link to post Share on other sites More sharing options...
Typhoonz 4th Gear August 28, 2012 Share August 28, 2012 Air con is set to fan mode and not cool air. Meaning it is blowing normal temp air. Won't save much but why torture yourself driving in our weather? Unless you are driving in the early mornings which then again will take even longer to see any savings... Link to post Share on other sites More sharing options...
Joajas Neutral Newbie August 28, 2012 Share August 28, 2012 (edited) definitely can save some petrol, was doing this for the pass 2 months. I only turn on the aircon when there is someone else in the car, thats roughly 20% of the time for one tank of petrol. Compared to previously where the aircon is always on, I am hitting an extra of about 50km to 60km per tank of petrol. Btw, the times when i drive are usually in the morning between 8 to 9 and evenings after 530pm, so weather and heat is usually not an issue. **Window is always up, nvr wind down because of the dust and exhaust fumes. Edited August 28, 2012 by Joajas Link to post Share on other sites More sharing options...
Timesup Neutral Newbie August 28, 2012 Share August 28, 2012 Wont buying a hybrid solve all problems 24.4km per litre Link to post Share on other sites More sharing options...
Kwanheng 1st Gear August 28, 2012 Share August 28, 2012 save it, ts driving must enjoy, no aircon only make your smell like motor oil. Link to post Share on other sites More sharing options...
Nitro Neutral Newbie August 28, 2012 Share August 28, 2012 Exactly, why make driving so miserable when the savings are only minimal...open windows increases drag, back to square one. LPPL Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged August 28, 2012 Share August 28, 2012 definitely can save some petrol, was doing this for the pass 2 months. I only turn on the aircon when there is someone else in the car, thats roughly 20% of the time for one tank of petrol. Compared to previously where the aircon is always on, I am hitting an extra of about 50km to 60km per tank of petrol. Btw, the times when i drive are usually in the morning between 8 to 9 and evenings after 530pm, so weather and heat is usually not an issue. **Window is always up, nvr wind down because of the dust and exhaust fumes. 50-60km extra mileage sounds good, what's what's total mileage it can get u? Example is with aircon, yr car can do 350km, without aircon, it does 400km.. then its really alot of difference. If with aircon on, yr car mileage is 500km, without aircon, its 550km, then not so significant Link to post Share on other sites More sharing options...
Jerrcik 1st Gear August 28, 2012 Share August 28, 2012 Wont buying a hybrid solve all problems 24.4km per litre na....the only "hybrid" worth driving is the Lexus RX450......sweet m o t h e r f u c k e r car...... ↡ Advertisement Link to post Share on other sites More sharing options...
Income tax Evasion
Income tax Evasion
Where to mod fuel needle?
