Quantum 5th Gear September 9, 2012 Share September 9, 2012 Hi All, I tried to change the ERP IU position on the front windscreen, it fixed too high and blocking a part of view but it seems quite difficult to move it, can anyone advise? ↡ Advertisement Link to post Share on other sites More sharing options...
Paddie 3rd Gear September 9, 2012 Share September 9, 2012 Just twist off the original bracket. Then either use the heavy duty 3M double sided tape to stick back, or get a new bracket from one of those window tinting shops. They usually keep stock. Link to post Share on other sites More sharing options...
Ishiwgao 3rd Gear September 9, 2012 Share September 9, 2012 is it legal to shift IU to the center of the windscreen instead of driver side? Link to post Share on other sites More sharing options...
ER-3682 Supersonic September 9, 2012 Share September 9, 2012 is it legal to shift IU to the center of the windscreen instead of driver side? No,many sports cars did that,as long as the gantry can detect the I.U. & get $$$ from your cashcard...it is fine. Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched September 9, 2012 Share September 9, 2012 Malaysia IU is wireless. I think they can put anywhere across the dash board. Link to post Share on other sites More sharing options...
TVT Supercharged September 9, 2012 Share September 9, 2012 Malaysia IU is wireless. I think they can put anywhere across the dash board. Malaysia got IU ??? Do you mean they also have ERP there? Link to post Share on other sites More sharing options...
TVT Supercharged September 9, 2012 Share September 9, 2012 No,many sports cars did that,as long as the gantry can detect the I.U. & get $$$ from your cashcard...it is fine. That is true. My friend has a IU not even attached to the windscreen. When he needs it he bring out put on the dashboard, plug into the 12V power socket and insert the cash card...and it works! Link to post Share on other sites More sharing options...
Quantum 5th Gear September 9, 2012 Author Share September 9, 2012 Just twist off the original bracket. Then either use the heavy duty 3M double sided tape to stick back, or get a new bracket from one of those window tinting shops. They usually keep stock. I thought IU inspection center got some special tool to move it, is it free? Link to post Share on other sites More sharing options...
Tianmo Hypersonic September 9, 2012 Share September 9, 2012 Malaysia IU is wireless. I think they can put anywhere across the dash board. you mean the SmartTAG is it???.......... Link to post Share on other sites More sharing options...
Gabriel 1st Gear September 9, 2012 Share September 9, 2012 taxis also in the center is it legal to shift IU to the center of the windscreen instead of driver side? Link to post Share on other sites More sharing options...
Quantum 5th Gear September 9, 2012 Author Share September 9, 2012 No,many sports cars did that,as long as the gantry can detect the I.U. & get $$$ from your cashcard...it is fine. the system so smart mah? I thought can install anywhere Link to post Share on other sites More sharing options...
Elfenstar 3rd Gear September 9, 2012 Share September 9, 2012 Hi All, I tried to change the ERP IU position on the front windscreen, it fixed too high and blocking a part of view but it seems quite difficult to move it, can anyone advise? Remove the IU from the holder. Use a heat gun/hair drier on the outside of the windscreen till that section gets really hot then pry the IU holder out. Heat the double sided tape on the holder till hot, then stick it where you want to position your IU. Re-insert the IU into the holder. Link to post Share on other sites More sharing options...
Kelvingoh45 Clutched September 9, 2012 Share September 9, 2012 What is it ar? Purpose? Link to post Share on other sites More sharing options...
Steptronic Supercharged September 9, 2012 Share September 9, 2012 Hi All, I tried to change the ERP IU position on the front windscreen, it fixed too high and blocking a part of view but it seems quite difficult to move it, can anyone advise? One issue could be: The sun film should be cut out around the IU unit. I remember I had a problem with my Cefiro's IU detection and the agent arranged to cut the film around that area. I try to see if it is cut out in my present car, I am not able to see any cutting. May be IU technology improved! Link to post Share on other sites More sharing options...
Highmount Clutched September 9, 2012 Share September 9, 2012 That is true. My friend has a IU not even attached to the windscreen. When he needs it he bring out put on the dashboard, plug into the 12V power socket and insert the cash card...and it works! Interesting. Appreciate if you could share which shop does this. Link to post Share on other sites More sharing options...
Silver_blade Turbocharged September 9, 2012 Share September 9, 2012 One issue could be: The sun film should be cut out around the IU unit. I remember I had a problem with my Cefiro's IU detection and the agent arranged to cut the film around that area. I try to see if it is cut out in my present car, I am not able to see any cutting. May be IU technology improved! Not the IU's tech has improved but the material of the solar film. My guess is your previous car had solar film that contain metal eg. higher grade V-kool. Link to post Share on other sites More sharing options...
Steptronic Supercharged September 9, 2012 Share September 9, 2012 Not the IU's tech has improved but the material of the solar film. My guess is your previous car had solar film that contain metal eg. higher grade V-kool. Possibly Films have improved. Incidentally, I just checked my friend's new Nissan Murano, it is cut there. Does TCM uses inferior films?! Link to post Share on other sites More sharing options...
Silver_blade Turbocharged September 9, 2012 Share September 9, 2012 (edited) Should be higher grade ones. I find those metallic-type eg high grade v-kool that require cutting are better and more effective but expensive. Those that are factory-fitted (not more S'pore) are metallic type....so the only position allow any kind of sensors, signal transmitter/receiver, etc are the dotted area on the top. Edited September 9, 2012 by Silver_blade ↡ Advertisement Link to post Share on other sites More sharing options...
NEW 3 Door Double Decker Buses OTR soon
Why do people not move back in the bus/ recommendations
Charging car on the move with solar panel, feasible?
NTUC Enterprise to buy Kopitiam in move to keep cooked food
Thread Merge/Split/Move primer
Torque on the Move - Receive $140 worth of goodies! Vroom!
How to move to public sector?
Torque On The Move tickets giveaway!
