MacDuck 1st Gear December 21, 2012 Share December 21, 2012 (edited) Hello everyone, My current set of tyres (14 months old) have clocked 12000+ km and I just went for first round of rotation/balancing this morning. Was informed by mechanic that both front tyres are showing inner wear, thread outside still still looks very good. Mechanic told me its more of a tracking (toe) issue than alignment since the wear is happening on both tyres? Appreciate your inputs, thank you. Edited December 21, 2012 by MacDuck ↡ Advertisement Link to post Share on other sites More sharing options...
Beehive3783 Twincharged December 21, 2012 Share December 21, 2012 Hello everyone, My current set of tyres (14 months old) have clocked 12000+ km and I just went for first round of rotation/balancing this morning. Was informed by mechanic that both front tyres are showing inner wear, thread outside still still looks very good. Mechanic told me its more of a tracking (toe) issue than alignment since the wear is happening on both tyres? Appreciate your inputs, thank you. You need to do alignment. Toe is also part of the alignment settings, as is camber. Link to post Share on other sites More sharing options...
macrosszero Turbocharged December 21, 2012 Share December 21, 2012 You have too much negative camber. Based on your driving pattern/habit you don't corner hard or fast enough to use the outer edge, so set your camber closer to 0 degrees ie close to vertical). Link to post Share on other sites More sharing options...
Kb27 Supersonic December 21, 2012 Share December 21, 2012 It's usually toe problem. Go for wheel alignment and you'll find out. Link to post Share on other sites More sharing options...
Hamburger Hypersonic December 21, 2012 Share December 21, 2012 mech talk rock sia.... not alignment issue but toe...... its like....isn't fingers part of hand. Link to post Share on other sites More sharing options...
MacDuck 1st Gear December 26, 2012 Author Share December 26, 2012 Hi guys, Was recommended Kenny at AMK AutoPoint for alignment service but his slots are full and does not accept walk-in customers. Appreciate if you guys can recommend other good workshops that can get my alignment issue sorted out. Thanks . Link to post Share on other sites More sharing options...
Kianbeng Clutched December 26, 2012 Share December 26, 2012 Hi guys, Was recommended Kenny at AMK AutoPoint for alignment service but his slots are full and does not accept walk-in customers. Appreciate if you guys can recommend other good workshops that can get my alignment issue sorted out. Thanks . Huh got so full until can reject customers? Do they just charge $20 and so the queue is very long? If it's a toe problem, then you would see feathered tyres. From the angle of your pictures, I can't tell if it's feathered. Usually the grooves will show 1 side sharp, 1 side rounded. If you have a sloping wear, then it's a camber issue. Some cars have adjustable camber, some don't and you will have to either buy the adjustable camber nut. I think it cost like $10-30? each and usually are not included in the alignment charge. Link to post Share on other sites More sharing options...
Kenomi 2nd Gear December 26, 2012 Share December 26, 2012 camber nut need to be changed and realigned , not the wheel alignment. Link to post Share on other sites More sharing options...
Naughty9795 2nd Gear December 26, 2012 Share December 26, 2012 You can try Stamford Tyre at Lock Yang, did mine there when I failed my inspection. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 26, 2012 Share December 26, 2012 Go to any shop that has a side slip tester, the mech should be able to slightly make small adjustment on the toe angle and by doing so the wheels will have zero lateral movements. Link to post Share on other sites More sharing options...
MacDuck 1st Gear December 30, 2012 Author Share December 30, 2012 Thanks for the inputs. Mechanic adjusted "toe" for both front wheels. Was told both wheels were pointing outwards hence the rapid wear on the inside. Link to post Share on other sites More sharing options...
Yeobh 4th Gear December 30, 2012 Share December 30, 2012 So now it will be less wear per km, good for the pocket Link to post Share on other sites More sharing options...
Jasonjst 3rd Gear December 30, 2012 Share December 30, 2012 Hello everyone, My current set of tyres (14 months old) have clocked 12000+ km and I just went for first round of rotation/balancing this morning. Was informed by mechanic that both front tyres are showing inner wear, thread outside still still looks very good. Mechanic told me its more of a tracking (toe) issue than alignment since the wear is happening on both tyres? Appreciate your inputs, thank you. Is not a problem right ? Positive chamber is good for cornering and more stable wont turn turtle so easily. Link to post Share on other sites More sharing options...
Jessicagrey Neutral Newbie January 10, 2013 Share January 10, 2013 Nice Thread Related to Car Tyres. Thanks for sharing this . Link to post Share on other sites More sharing options...
I-love-singapore January 10, 2013 Share January 10, 2013 Is not a problem right ? Positive chamber is good for cornering and more stable wont turn turtle so easily. is a problem when u do not corner hard enough premature wear Link to post Share on other sites More sharing options...
Jumpmanz 5th Gear January 12, 2013 Share January 12, 2013 ↡ Advertisement Link to post Share on other sites More sharing options...
Michelin Primacy 5 Energy
Pirelli P Zero PZ5
Pirelli P Zero PZ5
Petlas Or Giti?
Petlas Or Giti?
