Kb27 Supersonic May 21, 2020 Share May 21, 2020 5 hours ago, boonhat_91 said: I also looked around some local online hardware stores and it seems that the T-fitting you pictured is impossible to find!😫 When I was doing some plumbing, I find online very difficult to order, bcuz the numbers or specs don't seem to match anything. Try to find a wall mount joint to install a tap, vomit blood. Then I walk to the local hardware shop and they are there. It's not expensive either. Too bad, have to wait till they are open after the CB. ↡ Advertisement 1 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 21, 2020 Share May 21, 2020 (edited) 1 hour ago, boonhat_91 said: Thanks again for your input! I found this on shopee and looks like #2 or #4 is the one I want. From my visual agaration it looks like the difference is that #2 has smaller internal diameter of the male outlets compared to #4. Based on my understanding this would affect output pressure, which I guess is just a matter of personal preference? For the little difference in internal diameters, the pressure will not be affected at all. The copper pipe inner diameter is even smaller and that's the real restriction, if any. Hard to find #4 locally, they will sell you #1 plus a female female adaptor. I managed to find only the stainless steel one. Edited May 21, 2020 by Volvobrick 2 Link to post Share on other sites More sharing options...
Gunzy 4th Gear May 21, 2020 Share May 21, 2020 (edited) 3 hours ago, boonhat_91 said: Thanks again for your input! I found this on shopee and looks like #2 or #4 is the one I want. From my visual agaration it looks like the difference is that #2 has smaller internal diameter of the male outlets compared to #4. Based on my understanding this would affect output pressure, which I guess is just a matter of personal preference? from your pic of your on/off valve location, it should be able to accommodate either #2 or #4 easily depending on your preference...the female part is fixed type so there's a chance the fitting angle might not end up in a favorable postion when tightened, if you can find a movable type will be the best... actually the ID should be the same as it's based on G1/2" standard, that's the problem with online shopping as picture might be deceiving, anyhow if there's any difference, it shouldn't be big enough to have noticeable effect based on the picture...instead, do note the flexible hose ID, i came across difference size last time and it affected my bidet spray pressure Edited May 21, 2020 by Gunzy 1 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear May 21, 2020 Share May 21, 2020 2 hours ago, Gunzy said: from your pic of your on/off valve location, it should be able to accommodate either #2 or #4 easily depending on your preference...the female part is fixed type so there's a chance the fitting angle might not end up in a favorable postion when tightened, if you can find a movable type will be the best... actually the ID should be the same as it's based on G1/2" standard, that's the problem with online shopping as picture might be deceiving, anyhow if there's any difference, it shouldn't be big enough to have noticeable effect based on the picture...instead, do note the flexible hose ID, i came across difference size last time and it affected my bidet spray pressure Wah thanks! Still got pic of water in mid air some more 😄 1 Link to post Share on other sites More sharing options...
Gunzy 4th Gear May 21, 2020 Share May 21, 2020 3 hours ago, boonhat_91 said: Wah thanks! Still got pic of water in mid air some more 😄 Lol, found the pic in my watsapp which i took for my friend to show the difference in water pressure due to the ID of the flexible hose Link to post Share on other sites More sharing options...
Kb27 Supersonic May 22, 2020 Share May 22, 2020 I find this useful When you say, 1/2".. it is the nominal diameter. The thicker the pipe or hose, the smaller the internal diameter and the faster the water flows. 1 Link to post Share on other sites More sharing options...
boonhat_91 6th Gear July 25, 2020 Share July 25, 2020 On 5/19/2020 at 3:16 PM, boonhat_91 said: Hi all, hoping to get some advice from more experienced folks here. CB got me inspired to do some home improvement and one of them is to install a toilet spray hose. I ordered a set online which includes the 3-way valve pictured here. My questions are below: Spoiler I did some agar measurement and it seems that A and B are both 3/4 inch in total diameter, however B has the smaller internal diameter. Does this mean that technically both A or B could fit the same female fitting? Except that A has more thread than B. My ideal plan is to disconnect at C and place the valve there - i.e. C female to cistern will now attach to one of B, other B will attach the spray hose, and A will somehow connect to C male. Since A is also male, I would need some sort of female-female adapter right? However, A is longer than C male, so what kind of adapter am I looking for? Given that A is quite long, what would happen if I connected A at E? I think there would be excess thread - is that a problem? Procrastinated a bit, but finally got down to installing the spray hose. The steps are easy, but the execution much harder than I expected. For one, the T-fitting at max tightness, one of the outlet is facing the wall 🤦♂️ Tried to spam sealing tape to 'alter' the ending position and it seems to help. With everything done, still seems to be some minor leaking though. Back to the drawing board... 1 Link to post Share on other sites More sharing options...
Kenlohwh Neutral Newbie November 14, 2020 Share November 14, 2020 (edited) My bathroom's faucet is dripping and I want to replace it. The faucet is at shown in the attachment 20201115_002711.jpg. I would like to replace it with SHOWY-1459. Is the Showy's mount standard the same as my old faucet's, so I can mount the Showy onto the PVC pipe the same way as the old faucet's? Edited November 14, 2020 by Kenlohwh Link to post Share on other sites More sharing options...
Volvobrick Hypersonic November 15, 2020 Share November 15, 2020 All standard diameter. Just twist out and twist the new one in. If lazy don't even need to shut off the mains, just open the new tap first to reduce the pressure. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 15, 2020 Share November 15, 2020 (edited) 1 hour ago, Volvobrick said: All standard diameter. Just twist out and twist the new one in. If lazy don't even need to shut off the mains, just open the new tap first to reduce the pressure. I hate this type of twist in. Need the correct amount of thread sealer. Too much and it’s a pain in the ass to screw in and align it, too little and it leaks. Overshot in the alignment and turn counter clockwise and it leaks. not sure how you manage it with water gushing out if you don’t shut off. Edited November 15, 2020 by Mkl22 2 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic November 15, 2020 Share November 15, 2020 31 minutes ago, Mkl22 said: I hate this type of twist in. Need the correct amount of thread sealer. Too much and it’s a pain in the ass to screw in and align it, too little and it leaks. Overshot in the alignment and turn counter clockwise and it leaks. not sure how you manage it with water gushing out if you don’t shut off. Wear birth suit and apply shampoo body soap then do the Turning...won't waste too much water while at it😁 1 3 Link to post Share on other sites More sharing options...
Didu Turbocharged November 15, 2020 Share November 15, 2020 43 minutes ago, mersaylee said: Wear birth suit and apply shampoo body soap then do the Turning...won't waste too much water while at it😁 ...and remember to wear goggles so that soap don't get in your eyes while you work. 2 Link to post Share on other sites More sharing options...
mersaylee Hypersonic November 15, 2020 Share November 15, 2020 1 minute ago, Didu said: ...and remember to wear goggles so that soap don't get in your eyes while you work. Birth suit doesn't include accessories... 😁 2 Link to post Share on other sites More sharing options...
therock Supersonic November 15, 2020 Share November 15, 2020 (edited) Does anyone know a good plumber? i gotta change out this leaky tap.. are all the pipe diameters the same size? Thanks 🙏 Edited November 15, 2020 by therock Link to post Share on other sites More sharing options...
Kb27 Supersonic November 15, 2020 Share November 15, 2020 22 minutes ago, therock said: Does anyone know a good plumber? i gotta change out this leaky tap.. are all the pipe diameters the same size? Thanks 🙏 It looks like a standard 1/2" tap, available everywhere. The leak is due to the washer. If you can shut off the mains, you can DIY, by twisting it counter-clockwise. But you will need ptfe (teflon) tape on the thread. The tape need to go in the same direction where the tap is threaded in or it will be pushed out. 3 Link to post Share on other sites More sharing options...
Mustank Hypersonic November 15, 2020 Share November 15, 2020 (edited) 17 hours ago, Kenlohwh said: My bathroom's faucet is dripping and I want to replace it. The faucet is at shown in the attachment 20201115_002711.jpg. I would like to replace it with SHOWY-1459. Is the Showy's mount standard the same as my old faucet's, so I can mount the Showy onto the PVC pipe the same way as the old faucet's? Yes. But you might face installation problems because you are not as experienced a lot of times it seems a simple twist and replace. Your white pvc joint might give way when you are removing your old tap when putting in the new tap, and over tighten, that pvc joint will give way also but you don’t do you don’t gain the experience Edited November 15, 2020 by Mustank 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic November 15, 2020 Share November 15, 2020 Now you have scared him! I have not come across PVC joints giving way when changing the tap. Don't worry, but stop when hearing a cracking sound! 2 Link to post Share on other sites More sharing options...
therock Supersonic November 15, 2020 Share November 15, 2020 2 hours ago, Kb27 said: It looks like a standard 1/2" tap, available everywhere. The leak is due to the washer. If you can shut off the mains, you can DIY, by twisting it counter-clockwise. But you will need ptfe (teflon) tape on the thread. The tape need to go in the same direction where the tap is threaded in or it will be pushed out. Thanks 🙏 the tap looks rusty so I will probably change it too I’ll have to buy a big wrench ? ↡ Advertisement Link to post Share on other sites More sharing options...
HELP! Need a reliable plumber & electrician
PlumbingHub Plumbers - Since 1984
Help! I Need A Plumber !
Plumber to recommend
