Sozo 2nd Gear March 18, 2014 Share March 18, 2014 Lately I'm experiencing some symptoms with my Honda Edix 1.7, 1) sometime Batt Light come on blinking for 5-10seconds then went off while I driving. 2) When starting the engine, it vibrates quite bad but goes off after I rev up abit or it'll goes off after awhile. Any clues? Really appreciate for your advices in advance. ↡ Advertisement Link to post Share on other sites More sharing options...
Jman888 Moderator March 18, 2014 Share March 18, 2014 Lately I'm experiencing some symptoms with my Honda Edix 1.7, 1) sometime Batt Light come on blinking for 5-10seconds then went off while I driving. 2) When starting the engine, it vibrates quite bad but goes off after I rev up abit or it'll goes off after awhile. Any clues? Really appreciate for your advices in advance. quickly go for a check up, maybe battery or alternator going to kaput Link to post Share on other sites More sharing options...
BoneStock 5th Gear March 18, 2014 Share March 18, 2014 Lately I'm experiencing some symptoms with my Honda Edix 1.7, 1) sometime Batt Light come on blinking for 5-10seconds then went off while I driving. 2) When starting the engine, it vibrates quite bad but goes off after I rev up abit or it'll goes off after awhile. Any clues? Really appreciate for your advices in advance. 1) could be due to alternator not charging. Check the belt tension, could be loose. 2) could be sparks or ignition coil related. Link to post Share on other sites More sharing options...
TVT Supercharged March 18, 2014 Share March 18, 2014 Lately I'm experiencing some symptoms with my Honda Edix 1.7, 1) sometime Batt Light come on blinking for 5-10seconds then went off while I driving. 2) When starting the engine, it vibrates quite bad but goes off after I rev up abit or it'll goes off after awhile. Any clues? Really appreciate for your advices in advance. 1) check your alternator 2) This is tricky - could be ignition coil, spark plug dirty, petrol pump petrol ??? Link to post Share on other sites More sharing options...
Knoobie Supercharged March 18, 2014 Share March 18, 2014 2) could be sparks or ignition coil related. if spark plug related, wouldn't the problem persist even after he rev up and move off? Link to post Share on other sites More sharing options...
Sozo 2nd Gear March 19, 2014 Author Share March 19, 2014 Thanks All For quick replies. Link to post Share on other sites More sharing options...
Thaiyotakamli Supersonic March 19, 2014 Share March 19, 2014 Think for no 2 throttle rpm too low? Link to post Share on other sites More sharing options...
Furrynadz 5th Gear March 19, 2014 Share March 19, 2014 num 1 : alternator not charging/wire problem num 2 : related to a/f or combustion, start with the easier checks like maf/map first Link to post Share on other sites More sharing options...
Baal Supersonic March 19, 2014 Share March 19, 2014 May want to check engine mounting also. Link to post Share on other sites More sharing options...
Jamesc Hypersonic March 19, 2014 Share March 19, 2014 When was the last time you changed your battery? Link to post Share on other sites More sharing options...
Josephsatu 1st Gear March 22, 2014 Share March 22, 2014 Engine mount kaput ↡ Advertisement Link to post Share on other sites More sharing options...
New Honda robot ASIMO is so human like
2020 5th Generation Honda City
COE Bidding – Jun 2026
Any recommended tyre shop
Total asset vs car price affordability
