Pisces69 6th Gear May 19, 2014 Share May 19, 2014 Let me share my misfortune. May 13,I changed my compressor as it was producing "grinding" sound when it kicks in. As a p plater and a newbie, i just nodded my head. $550 Damage Apr 14, air-conditioning not cold, went to check and found out cooling coil leaked. Car still left 4 yrs plus, so changed. Damage is $450. 2 weeks later, not cold again, went back same wksp, denied that it's faulty coil as it's still under warranty. Diagnosed it's broken air intake valve nipple (same as needle thingy which you see when u uncap to pump air into your types. Damage is $30. May 14, not cold and leaked gas again!! Went to same and other wksp to confirm that my 1yr old compress body is leaking!! LL, change again. Damage is $535. Ppl always say put aside 2-3k to replace faulty parts when u purchase used car. How true is that.. Nowadays, whenever I go servicing, my hands will shake.. hahaha. Where u go to do yr AC??? Many AC shops r crooks n incompentent. They wil suck u dry. I go Markcool n only see Ah Huat the foreman. So far I have no such problems with him. ↡ Advertisement Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 19, 2014 Share May 19, 2014 Huh. How come yr AC coil spoil so fast? Cooling coil usually last longer than the 10 year COE even. My Optra its already 8 years n still good. Usually coil can last very long. Only my compressor I changed abt >1 year ago. I have an aftermarket ionioser but that dun affect the ac cos it just cleans n sterelizes the air. Don't know leh... Nothing spoil so far except leak coiling coil once when the car was like 3.5yrs old... Now 7+yrs, so suspect cooling coil koyak again... Anyway, I'll leave it to expert to diagnosis.. .. Will either check with mark cool or tomika..... Link to post Share on other sites More sharing options...
Optramagnum 6th Gear May 19, 2014 Share May 19, 2014 (edited) Where u go to do yr AC??? Many AC shops r crooks n incompentent. They wil suck u dry. I go Markcool n only see Ah Huat the foreman. So far I have no such problems with him. Usually, I dun mention name of wksp, so not to undermine their reputations.. anyway, I did all the repairs at To**ka and my last compressor was changed at Mar**ool. Sad thing is these parts doesn' come with long warranty. So maybe just my bad luck. Actually, I rarely drive in hot day time, so i can actually bear with it. But seeing wife and children sweating when we go out during weekends, I know I gonna spend that money.. Just my luck maybe. Anyway, I driving a Optra magnum '08, is it true that I must set the temp to coldest(blue label) at all times? Cos I heard the coil will ice after long drive if I dun, please advise. Edited May 19, 2014 by Optramagnum Link to post Share on other sites More sharing options...
Optramagnum 6th Gear May 20, 2014 Share May 20, 2014 (edited) Don't know leh... Nothing spoil so far except leak coiling coil once when the car was like 3.5yrs old... Now 7+yrs, so suspect cooling coil koyak again... Anyway, I'll leave it to expert to diagnosis.. .. Will either check with mark cool or tomika..... bro, I suggest you go both shops to reaffirm the fault and also compare the prices.. although the distances are far, but it's worth the effort.. Edited May 20, 2014 by Optramagnum Link to post Share on other sites More sharing options...
TVT Supercharged May 20, 2014 Share May 20, 2014 May 14, not cold and leaked gas again!! Went to same and other wksp to confirm that my 1yr old compress body is leaking!! LL, change again. Damage is $535. Compress body is the compressor ?? So the compressor only lasted one year? That's is unusual of a compressor breakdown so fast. Ppl always say put aside 2-3k to replace faulty parts when u purchase used car. How true is that.. Nowadays, whenever I go servicing, my hands will shake.. hahaha. It is not necessary true. Many times it depends on luck also.... Some people I know buy used car don't really have a problem at all, except to change wear-n-tear parts. Not only you, many of us also hand shake when going for servicing....its normal lah. Link to post Share on other sites More sharing options...
Optramagnum 6th Gear May 20, 2014 Share May 20, 2014 Compress body is the compressor ?? So the compressor only lasted one year? That's is unusual of a compressor breakdown so fast. It is not necessary true. Many times it depends on luck also.... Some people I know buy used car don't really have a problem at all, except to change wear-n-tear parts. Not only you, many of us also hand shake when going for servicing....its normal lah. The first compressor, the Ah Huat said the body got dislodged aabit maybe due to heat when metal expands. So the air leak thru the gap, he also showed me the oil(luminous green) also leaked all overt the place. He shared that it is indeed rare for a compressor to die so fast, but there are csimilar cases.I guess it was a lemon product. So pray hard for my existing one. Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 20, 2014 Share May 20, 2014 bro, I suggest you go both shops to reaffirm the fault and also compare the prices.. although the distances are far, but it's worth the effort.. I will.. I seldom listen to one party.... This morning checked personally, seems like not cooling coil leak.. The fan is not rotating... Ummm.. Link to post Share on other sites More sharing options...
Kb27 Supersonic May 20, 2014 Share May 20, 2014 I will.. I seldom listen to one party.... This morning checked personally, seems like not cooling coil leak.. The fan is not rotating... Ummm.. Try New Luck aircon at Kaki Bukit Autobay Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 20, 2014 Share May 20, 2014 Try New Luck aircon at Kaki Bukit Autobay thanks for the lobang.. will check with them as well... hope i got luck from them... Link to post Share on other sites More sharing options...
Kb27 Supersonic May 20, 2014 Share May 20, 2014 thanks for the lobang.. will check with them as well... hope i got luck from them... I used to go to moto-aire. They were good, but 50% more costly than New Luck, based on changing evaporator coil alone. I wouldn't hesitate to go back to New Luck any time for aircon problem. Link to post Share on other sites More sharing options...
Deckki Clutched May 20, 2014 Share May 20, 2014 hi guys, need some advice. I am driving a mini, is there any reliable merchant that i can look for to change my aircon filter or any merchant can do it? thanks ! Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 20, 2014 Share May 20, 2014 hi guys, need some advice. I am driving a mini, is there any reliable merchant that i can look for to change my aircon filter or any merchant can do it? thanks ! aiyoh, go google from youtube on how to change aircon filter... very easy one... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 20, 2014 Share May 20, 2014 I will.. I seldom listen to one party.... This morning checked personally, seems like not cooling coil leak.. The fan is not rotating... Ummm.. bro, how to tell if cooling coil is leakin? Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 20, 2014 Share May 20, 2014 bro, how to tell if cooling coil is leakin? I remember last time, aircon not Cold, top up gas, cold but after a while not Cold again and got some smell also.. Then totally not Cold at all... I think they check pressure and determine coming coil leak... True enough... When take out, damn chialat with the colorant very obvious at one corner.... Sibei Sian... Just now jam like mad at kje, no aircon..smell all the smoke... And I cannot Tahan hot one.. Sweat like mad... Knn... Thinking of taking leave tomorrow to get it done... Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 20, 2014 Share May 20, 2014 I used to go to moto-aire. They were good, but 50% more costly than New Luck, based on changing evaporator coil alone. I wouldn't hesitate to go back to New Luck any time for aircon problem. Bro, any idea what time they open?.. Need to plan my timing... Hehehe Link to post Share on other sites More sharing options...
Kb27 Supersonic May 20, 2014 Share May 20, 2014 Bro, any idea what time they open?.. Need to plan my timing... Hehehe Not sure, I went there around afternoon. But I think best you go there around 9 am where you can be amongst the first and don't need to wait too long. Link to post Share on other sites More sharing options...
Blackyv Turbocharged May 20, 2014 Share May 20, 2014 Not sure, I went there around afternoon. But I think best you go there around 9 am where you can be amongst the first and don't need to wait too long. Thxs.. See how it goes... Link to post Share on other sites More sharing options...
Fuelsaver Supercharged May 20, 2014 Share May 20, 2014 I remember last time, aircon not Cold, top up gas, cold but after a while not Cold again and got some smell also.. Then totally not Cold at all... I think they check pressure and determine coming coil leak... True enough... When take out, damn chialat with the colorant very obvious at one corner.... Sibei Sian... Just now jam like mad at kje, no aircon..smell all the smoke... And I cannot Tahan hot one.. Sweat like mad... Knn... Thinking of taking leave tomorrow to get it done... bro, when u mentioned "smell", what kinda smell is it? how long did it last? ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
Nissan Preventive Maintenance Programme
Nissan QashQai 2014 Part 2
future of mitsubishi?
2018 Nissan Serena e-POWER
