Somebody 1st Gear April 25, 2014 Share April 25, 2014 Hi everyone!I just installed my headlights a few hours ago and it already started misting up!The garage told me "misting up is normal, but if water gets in we'll replace it."Is this the way it's supposed to be? ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Blackyv Turbocharged April 25, 2014 Share April 25, 2014 You ask the chap who told you its norm go fark spider... After this solved, do yourself a favor by not going to this Ws anymore... 2 Link to post Share on other sites More sharing options...
Somebody 1st Gear April 26, 2014 Author Share April 26, 2014 Any other comments? I need to know what is "normal" and "right" so I know what to do. Link to post Share on other sites More sharing options...
Crossangel Neutral Newbie April 26, 2014 Share April 26, 2014 its not normal at all.. your headlamps are original ones? 1 Link to post Share on other sites More sharing options...
Coolpica 4th Gear April 26, 2014 Share April 26, 2014 The fact that headlights is misting shows that water has entered, no? 1 Link to post Share on other sites More sharing options...
Watwheels Supersonic April 26, 2014 Share April 26, 2014 Aftermarket headlights? Made in Taiwan? Get back the original headlights. Link to post Share on other sites More sharing options...
Biohazard 1st Gear April 26, 2014 Share April 26, 2014 Hi everyone! I just installed my headlights a few hours ago and it already started misting up! The garage told me "misting up is normal, but if water gets in we'll replace it." Is this the way it's supposed to be? The famous sonar ones? 1 Link to post Share on other sites More sharing options...
NightWind 4th Gear April 26, 2014 Share April 26, 2014 Bro its NOT NORMAL. R u using halogens or xenons? Nvm either ways its not normal I suspect they installed the fitting badly so when it rains or when u wash car moisture entered. Get the garage to fix it immediately pls BTW which garage did it pls? I will avoid them lol Hi everyone!I just installed my headlights a few hours ago and it already started misting up!The garage told me "misting up is normal, but if water gets in we'll replace it."Is this the way it's supposed to be? 1 Link to post Share on other sites More sharing options...
LoneCatFish 3rd Gear April 26, 2014 Share April 26, 2014 (edited) Hi everyone! I just installed my headlights a few hours ago and it already started misting up! The garage told me "misting up is normal, but if water gets in we'll replace it." Is this the way it's supposed to be? If you just installed few hours ago, and never gone through car wash, rain, etc, it could because water (or water vapor) was somehow trapped inside the headlight before the installation. If the workshop refuse to do anything for you, and you are in suck thumb situation, I suggest you loosen the rubber cover of the bulb housing, this is the rubber cover behind the headlight housing in the engine bay side. Doing so is basically to give escape path for the water vapor, leave the headlight on for may be, 30min, to heat up the headlight, and let the water vapor escape, then put back the rubber cover, hopefully can solve the problem. If the misting comes back again, especially after rain or car wash, there's definite water leak. Do whatever you can to get the workshop to replace the headlight. Edited April 26, 2014 by LoneCatFish 1 Link to post Share on other sites More sharing options...
Spiderman302 2nd Gear April 26, 2014 Share April 26, 2014 Which ws? You better speak to the bosss. If the boss also same reply must black list this ws. 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 26, 2014 Share April 26, 2014 You sure this is a brand new head light taken out from the box. If so it should never mist. 1 Link to post Share on other sites More sharing options...
Fu11thr0tt1e Turbocharged April 26, 2014 Share April 26, 2014 Hi everyone! I just installed my headlights a few hours ago and it already started misting up! The garage told me "misting up is normal, but if water gets in we'll replace it." Is this the way it's supposed to be? Its not normal. Get it replace soon. 2 Link to post Share on other sites More sharing options...
RageX 1st Gear April 26, 2014 Share April 26, 2014 last time one of my headlights misted the fitting had come out... NOT normal... 2 Link to post Share on other sites More sharing options...
Patrickyan Clutched April 28, 2014 Share April 28, 2014 can share share which ws is this? 2 Link to post Share on other sites More sharing options...
Jerryong April 28, 2014 Share April 28, 2014 once this is mist in the headlight. it will be persistent to come back. 1 Link to post Share on other sites More sharing options...
Jerryong April 28, 2014 Share April 28, 2014 once this is mist in the headlight. it will be persistent to come back. btw anyone know where can get this spare part. connect to headlight to adjust high and low light angle? Link to post Share on other sites More sharing options...
Jerryong April 30, 2014 Share April 30, 2014 btw anyone know where can get this spare part. connect to headlight to adjust high and low light angle?IMG_04181.JPG hi expert, please advise on the post I make. need help......... Link to post Share on other sites More sharing options...
Newkidontheblock Clutched April 30, 2014 Share April 30, 2014 imo ive some friends who have experienced this before... what they did was drill a small hole through the plastic so theres 'ventilation'... problem solved. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Energy Savings / Non Heat up LED Headlights Technology
Need help with water trapped in my headlight lamp cover. Anywhere to get it fix?
Car inspection questions
LED head light
LED head light
Theives Gouged Out This Poor Porsche Taycan's Headlights
Toyota Camry
Toyota Camry
3m normal and crystalline solar film
