Anjoy 1st Gear May 17, 2014 Share May 17, 2014 (edited) Hi, My power window is not functioning as it should. Have changed the switch and checked but the problem returns. Please advise where/who can get it fixed. Ride: NC Thanks in advance. Edited May 17, 2014 by Anjoy ↡ Advertisement Link to post Share on other sites More sharing options...
Alphas 2nd Gear May 17, 2014 Share May 17, 2014 likely motor inside died Link to post Share on other sites More sharing options...
Awboonboon Neutral Newbie May 17, 2014 Share May 17, 2014 either the window motor has spoilt, or the cable is loosed or snapped. Do get a window specialist to diagnose. Link to post Share on other sites More sharing options...
Meanmachine Supercharged May 17, 2014 Share May 17, 2014 check the power window motor, either brand is Bosch or french brand , can't remb exact name, I know tis guy in Eunos who can fix it, he is specialist in all car cushion / electric power-window and chair repair ) Can call him, Mr. Foo 90294774, ( Coy name : In Siang Huat ) Link to post Share on other sites More sharing options...
Anjoy 1st Gear May 18, 2014 Author Share May 18, 2014 check the power window motor, either brand is Bosch or french brand , can't remb exact name, I know tis guy in Eunos who can fix it, he is specialist in all car cushion / electric power-window and chair repair ) Can call him, Mr. Foo 90294774, ( Coy name : In Siang Huat ) Thanks! Will contact Mr. Foo. Link to post Share on other sites More sharing options...
Zerofighter Neutral Newbie May 24, 2014 Share May 24, 2014 My driver's side power window has a funny sound while winding down. Winding up is fine. Anyone knows what's the issue? Thanks Link to post Share on other sites More sharing options...
Astrid 4th Gear May 24, 2014 Share May 24, 2014 Hi, My power window is not functioning as it should. Have changed the switch and checked but the problem returns. Please advise where/who can get it fixed. Ride: NC Thanks in advance. NC ... MX5? Bring it back to TransEurokars Mazda AD lah! Link to post Share on other sites More sharing options...
Kingkong 5th Gear May 24, 2014 Share May 24, 2014 My driver's side power window has a funny sound while winding down. Winding up is fine. Anyone knows what's the issue? Thanks Many stickers on your window? Link to post Share on other sites More sharing options...
Anjoy 1st Gear May 24, 2014 Author Share May 24, 2014 NC ... MX5? Bring it back to TransEurokars Mazda AD lah! It's a PI model. Not sure why too. Mark can't pinpoint the problem too. Link to post Share on other sites More sharing options...
Keefe 1st Gear June 29, 2014 Share June 29, 2014 Did you just changed battery or ECU reset? Link to post Share on other sites More sharing options...
Anjoy 1st Gear August 11, 2014 Author Share August 11, 2014 Did you just changed battery or ECU reset? Yes. Prior to that the window is fine. Any connection between the two? So what's your advice? Link to post Share on other sites More sharing options...
TVT Supercharged August 11, 2014 Share August 11, 2014 Yes. Prior to that the window is fine. Any connection between the two? So what's your advice? You mean after 3 months plus you haven't got it fixed yet ?? Link to post Share on other sites More sharing options...
Anjoy 1st Gear August 11, 2014 Author Share August 11, 2014 You mean after 3 months plus you haven't got it fixed yet ?? Hahaha. Yes! No one knows what's wrong with it. Link to post Share on other sites More sharing options...
TVT Supercharged August 11, 2014 Share August 11, 2014 Hahaha. Yes! No one knows what's wrong with it. Have you checked the motor? Or something inside is jamming it ? Power window have only a few parts. Switch, cable, motor, level mechanism.....tot it should be easy to pinpoint the cause. Link to post Share on other sites More sharing options...
Keefe 1st Gear August 11, 2014 Share August 11, 2014 After battery change or ECU reset, the power window module needs reprogramming. After starting the car, wind down the window by holding the down button + 1-2 sec after the action is complete. Do the same for winding up. The auto up/down will be activated again. If all four windows have auto up/down, then repeat for every door. Link to post Share on other sites More sharing options...
Optramagnum 6th Gear August 11, 2014 Share August 11, 2014 I just changed mine last month. It failed me at JB custom, when wanna chop passport! Darn wrong timing.. $130 for motor, $115 for regulator, $65 for labor. I guess it's a common wear N tear, esp driver side. Try spraying some WD40 at the fringe on glass window and and those rubber, it will reduce the suction effect when u wanna use esp after parked long hours in hot sun. Link to post Share on other sites More sharing options...
TVT Supercharged August 12, 2014 Share August 12, 2014 I just changed mine last month. It failed me at JB custom, when wanna chop passport! Darn wrong timing.. $130 for motor, $115 for regulator, $65 for labor. I guess it's a common wear N tear, esp driver side. Try spraying some WD40 at the fringe on glass window and and those rubber, it will reduce the suction effect when u wanna use esp after parked long hours in hot sun. You are opposite of me! Mine is can't wind up after I power it down one late night last year. So I had to park overnight @ MSCP and drove to WS the next day, all with the driver side window down...... Luckily it didn't rain that day or else.... Link to post Share on other sites More sharing options...
Anjoy 1st Gear August 12, 2014 Author Share August 12, 2014 (edited) After battery change or ECU reset, the power window module needs reprogramming. After starting the car, wind down the window by holding the down button + 1-2 sec after the action is complete. Do the same for winding up. The auto up/down will be activated again. If all four windows have auto up/down, then repeat for every door. Mine is a miata so the windows (2 doors only so 2 windows) will normally drop a little as I retract the roof but as one side of the window isn't working down, so I dare not retract the roof. My question is now the driver side is fine but the passenger side, not. Cannot move up/down, at all. So can I still try your method? The problem is that I tried moving the window. It moved down a little (maybe 3cm) then stopped. Can't move up/down anymore. So I do not want to risk having to park the car with a window half down. I went to several miata workshops and they cannot find the root for the cause and it's been very frustrating. Your adivce please. Edited August 12, 2014 by Anjoy ↡ Advertisement Link to post Share on other sites More sharing options...
2025 Mazda 6e
2025 Mazda 6e
2026 Mazda EZ-60 / CX-6e
MAZDA 6
MAZDA 6
Recirculation mode not working
Carbonics Cold Air Intake System - Full Handmake CF
windows tinting...
windows tinting...
Mazda FC3S RX-7
Mazda FC3S RX-7
Win a Limited-Edition Mazda RX-7 Diecast in Sgcarmart livery!
