Watwheels Supersonic October 27, 2014 Share October 27, 2014 If 2nd hand from dealer, definitely it's genuinely fake. +1 can times 2 the mileage and add somemore. Usually they just use an OBDII device and key in the mileage, sync, on off the ignition and the mileage from 150K km becomes 60K km. ↡ Advertisement Link to post Share on other sites More sharing options...
ChickenMob 6th Gear October 27, 2014 Share October 27, 2014 +1 can times 2 the mileage and add somemore. Usually they just use an OBDII device and key in the mileage, sync, on off the ignition and the mileage from 150K km becomes 60K km. Check the clutch plates also..... Link to post Share on other sites More sharing options...
Uluwatu06 2nd Gear October 27, 2014 Share October 27, 2014 I highly suspect low battery. Happened once to my FIL's Latio. Link to post Share on other sites More sharing options...
TVT Supercharged October 27, 2014 Share October 27, 2014 I highly suspect low battery. Happened once to my FIL's Latio. Huh....Latio is battery operated one ?? 1 Link to post Share on other sites More sharing options...
Ezfaun 3rd Gear October 27, 2014 Share October 27, 2014 When you step on the accelerator, does your engine rev higher and make more noise or does it stay at any particular spot? Sound would be like buuuuuuuu instead of waaaaaaaaah. If so I think u may be in limp mode. Maybe you can try disconnecting the negative terminal when the car is off for 30 secs and put back and see if it helps. Otherwise, if your engine revs higher but the car is still stuck at 20 then it could be a problem with your cvt gearbox like band slippage or faulty actuator. Link to post Share on other sites More sharing options...
Watwheels Supersonic October 27, 2014 Share October 27, 2014 If it's in limp mode it can be many possibilities eg. oxygen sensor, catalytic converter failure etc. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic October 27, 2014 Share October 27, 2014 Huh....Latio is battery operated one ?? Latio Leaf. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear October 27, 2014 Author Share October 27, 2014 Workshop said speed sensor spoilt. Repair cost is 600 plus. Is this normal? Workshop said speed sensor spoilt. Repair cost is 600 plus. Is this normal? Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 27, 2014 Share October 27, 2014 Workshop said speed sensor spoilt. Repair cost is 600 plus. Is this normal? Workshop said speed sensor spoilt. Repair cost is 600 plus. Is this normal? call tan cheong up and set it as benchmark. Link to post Share on other sites More sharing options...
Blackyv Turbocharged October 27, 2014 Share October 27, 2014 I highly suspect low battery. Happened once to my FIL's Latio. didnt know there is a hybrid latio... Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear October 27, 2014 Author Share October 27, 2014 My car already towed there. If tow again sure v ex. Somemore may need to change cvt oil .. everything plus up easily to 1k. Faint Link to post Share on other sites More sharing options...
Uluwatu06 2nd Gear October 27, 2014 Share October 27, 2014 Huh....Latio is battery operated one ?? Latio Leaf. didnt know there is a hybrid latio... Laugh as much as you want. I laughed too back then. And still do thinking about it. Never encountered this on my cars/bikes though. Link to post Share on other sites More sharing options...
Charmaine12 3rd Gear October 27, 2014 Author Share October 27, 2014 Anyone knows if speed sensor can be repaired instead of replaced? And if speed sensor really cause this issue? Link to post Share on other sites More sharing options...
Hamburger Hypersonic October 27, 2014 Share October 27, 2014 Anyone knows if speed sensor can be repaired instead of replaced? And if speed sensor really cause this issue? sensor have to be replaced. Yes, speed sensor can cause what you described as it is not feeding ecu the right data. Link to post Share on other sites More sharing options...
Sadan 6th Gear October 27, 2014 Share October 27, 2014 My car already towed there. If tow again sure v ex. Somemore may need to change cvt oil .. everything plus up easily to 1k. Faint car tow to your WS or TC?? Either place.. like other bosses mentioned.. better to get separate quote from other place. The difference in quote is worth to get ur latio tow again.. Link to post Share on other sites More sharing options...
Munimal 1st Gear October 27, 2014 Share October 27, 2014 Just to check. Anyone have this prob. My car nissan latio cvt cannot accerlerate. No matter which gear i change to. Max is 20km Same problem here...the spark plugs connections manifold are faulty(if my technical terms are correct)( ...therefore cannot fire...cannot ignite...there are 8 of them...if a few spoilt have to change all...as it is difficult to dismantle....but tan chong people do it within an hour...about 600plus..outside workshop 500plus...thanks...tan chong service advisor knew this problem very well....thanks Link to post Share on other sites More sharing options...
TVT Supercharged October 27, 2014 Share October 27, 2014 sensor have to be replaced. Yes, speed sensor can cause what you described as it is not feeding ecu the right data. Yes, a faulty speed sensor will send wrong signals to the ECU. However. depending on the fault of the sensor, some will just affect the speedometer that make the needle always point at zero, but the car still can accelerate normally. So the driver detects his speed using the RPM instead. Link to post Share on other sites More sharing options...
Dumb 4th Gear October 27, 2014 Share October 27, 2014 (edited) I highly suspect low battery. Happened once to my FIL's Latio. What? Then no battery how? I drove my car from Selegie to Gul (my WS) in Jurong without battery at hwy speed. Edited October 27, 2014 by Dumb ↡ Advertisement Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Nissan QashQai 2014 Part 2
future of mitsubishi?
2018 Nissan Serena e-POWER
Nissan N7
Nissan N7
