ConnorMcLeod 2nd Gear December 24, 2025 Share December 24, 2025 On 12/23/2025 at 10:49 AM, zipping said: Different ride but coe car, $ not much difference on comprehensive insurance (must do homework), nvr claim b4 so not sure on claims & scrap, road tax every yr add 10%, went mechanic (jb) to replace items that NEEDS replacing upon coe renewal, e rest wait until down then replace. Hi @zipping. Thanks. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear February 2 Author Share February 2 @ConnorMcLeod IMHO. Eh.... extended COE? How many miles now? Should be good till 240km. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear February 2 Share February 2 (edited) On 2/2/2026 at 4:23 PM, Kklee said: @ConnorMcLeod IMHO. Eh.... extended COE? How many miles now? Should be good till 240km. @Kklee most likely extend COE. only 130k km now. if good till 240k km then mire then enough for me 😎 Edited February 2 by ConnorMcLeod 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear February 2 Author Share February 2 On 2/2/2026 at 4:33 PM, ConnorMcLeod said: @Kklee most likely extend COE. only 130k km now. if good till 240k km then mire then enough for me 😎 IMHO. Mine IIRC is 220k. Change the whole set of ignition coils early. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear February 2 Share February 2 On 2/2/2026 at 4:37 PM, Kklee said: IMHO. Mine IIRC is 220k. Change the whole set of ignition coils early. i talked to the SE at my previous service. Ge mentioned things like cooling fan belt, ignition coil, aircon, are typical items that need repair/replacement. of course consumables like brake pads, shocks/suspension etc all ok based on my expected low mileage for the coming years. Link to post Share on other sites More sharing options...
Kklee 6th Gear February 2 Author Share February 2 On 2/2/2026 at 5:36 PM, ConnorMcLeod said: i talked to the SE at my previous service. Ge mentioned things like cooling fan belt, ignition coil, aircon, are typical items that need repair/replacement. of course consumables like brake pads, shocks/suspension etc all ok based on my expected low mileage for the coming years. IMHO. BM only change ignition coil when spoil and they change one. You have another 3 chances. The down time is not worth it for me. I got someone from Carousell when it was down the second time, change everything. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear February 2 Share February 2 (edited) On 2/2/2026 at 7:19 PM, Kklee said: IMHO. BM only change ignition coil when spoil and they change one. You have another 3 chances. The down time is not worth it for me. I got someone from Carousell when it was down the second time, change everything. The BM SE actually suggested to change all 4x ignition coils at the same time, because he sees they should all fail around the same period. IIRC he says SGD400 each (I suppose parts + labour). Based on this YT video: https://youtu.be/qpeEK1-mQns?si=0-JIr7231wy0uNVN , changing one ignition coil is a 2 min job (video 01:00 to 03:00) + another couple of minutes to disconnect & connect the battery. Let's say the YT video skipped some of the details so each ignition coil replacement takes 10mins. So replacing all 4x will be about 1 hr. I wonder how much BM will charge for labour 😉 Now basic service, even after my TSI discount of 30%, costs me SGD240. Before covid, i think even the service package that changes CVT fluid is less than SGD300. Prices went up a lot at BM. Edited February 2 by ConnorMcLeod Link to post Share on other sites More sharing options...
Kklee 6th Gear February 2 Author Share February 2 On 2/2/2026 at 10:13 PM, ConnorMcLeod said: The BM SE actually suggested to change all 4x ignition coils at the same time, because he sees they should all fail around the same period. IIRC he says SGD400 each (I suppose parts + labour). Based on this YT video: https://youtu.be/qpeEK1-mQns?si=0-JIr7231wy0uNVN , changing one ignition coil is a 2 min job (video 01:00 to 03:00) + another couple of minutes to disconnect & connect the battery. Let's say the YT video skipped some of the details so each ignition coil replacement takes 10mins. So replacing all 4x will be about 1 hr. I wonder how much BM will charge for labour 😉 Now basic service, even after my TSI discount of 30%, costs me SGD240. Before covid, i think even the service package that changes CVT fluid is less than SGD300. Prices went up a lot at BM. IMHO. I stranded twice. 1st time tow back to BM. 2nd time on expressway, tow to nearest carpark. 🤣 That's why change outside. 🤣 Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear February 3 Share February 3 @Kklee hmm... the SE was telling me when an ignition coil fails, the engine will have much less power (basically from 4 to 3 cylinders) and vibrations and CEL on, but never said it will not able to drive at all --- of course when powerless it will take long time to move off from traffic light so this maybe bad enough to have the car towed away. Indeed nasty when the car has problem on the expressway/highway. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear February 3 Author Share February 3 On 2/3/2026 at 9:11 PM, ConnorMcLeod said: @Kklee hmm... the SE was telling me when an ignition coil fails, the engine will have much less power (basically from 4 to 3 cylinders) and vibrations and CEL on, but never said it will not able to drive at all --- of course when powerless it will take long time to move off from traffic light so this maybe bad enough to have the car towed away. Indeed nasty when the car has problem on the expressway/highway. IMHO. Yes, can move but no power - really no power. Actually expressway good, can call EMAS. If you off expressway, call your own. 2nd time I towed some carpark and ask the carousell fella. 🤣 1 Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear February 4 Share February 4 @Kklee will be quite dangerous if fails while in fast lane on ecpressway n needs to limp to the left kerb side to wait for emas..... 🥶 1 Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear July 8 Share July 8 Hi All, anyone put 225/55 R17 instead of 215/45 R17 on their Elegance and any noticeable effect on FC (better, worse) and the ride? Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 9 Share July 9 On 7/8/2026 at 10:18 PM, ConnorMcLeod said: Hi All, anyone put 225/55 R17 instead of 215/45 R17 on their Elegance and any noticeable effect on FC (better, worse) and the ride? Maybe can try 225/45-17....I don't can can fit 225/55-17,this size is even bigger than Camry using only 215/55-17. Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 10 Share July 10 I don't think* Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 10 Share July 10 Can consider 215/50-17 also. Link to post Share on other sites More sharing options...
inlinesix Hypersonic July 10 Share July 10 On 7/10/2026 at 6:50 AM, ER-3682 said: Maybe can try 225/45-17....I don't can can fit 225/55-17,this size is even bigger than Camry using only 215/55-17. On 7/10/2026 at 8:18 AM, ER-3682 said: I don't think* On 7/10/2026 at 8:19 AM, ER-3682 said: Can consider 215/50-17 also. Ppl want thicker sidewall la Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 10 Share July 10 On 7/10/2026 at 10:38 AM, inlinesix said: Ppl want thicker sidewall la Later kena Fender when Full Lock Steering,also hit the Upper Edge of Fender when going over Humps with Paxs behind,i changed my Camry 18" Wheels from 235/45-18 to 19" Wheels with 235/45-19 Tyres..also kena Fenders. Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 10 Share July 10 On 7/10/2026 at 10:38 AM, inlinesix said: Ppl want thicker sidewall la Buy SUV if want Higher Profile Tyres. ↡ Advertisement Link to post Share on other sites More sharing options...
Toyota bZ4X (2026) Part 2
Toyota Land Cruiser Mini
2022 Toyota bZ4X
2022 Toyota bZ4X
Nissan QashQai 2014 Part 2
