Drion 2nd Gear November 9, 2016 Share November 9, 2016 Hi Bro, Thanks for the explanation. I plan to add the trd front bar during my 2nd or 3rd service from BM. Do you know if I were to add other TRD or UR bar to the car will it void BM warranty? Warranty will not cover all TRD and 3rd party stuff and imo it will not void the basic car warranty. Adding the bar will give u a stiffer aka more stable ride, steering is tighter also i installed a total of 4 bars (trd front strut bar, UR lower arm bar -3 point, rear strut and rear anti-roll bar) + replace the torsion beam with trd torsion beam, went back to BM to do wheel alignment, no question asked. They simply do it for me. Hope it helps ↡ Advertisement Link to post Share on other sites More sharing options...
Wester86 1st Gear November 10, 2016 Share November 10, 2016 think they will get for u. 6 bid non g'ted. last time i got mine in 3rd or 4th bid.BM also bidded 48k for me during yesterday bidding. 5th bids. I think no chance to secure. Asking the SE for refund so that no need to waste their and my time Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear November 10, 2016 Share November 10, 2016 Bits of info update 1. For Night driving AYE->MCE->KPE, Altis dashboard indicates about 22.2km/L 2. Coolant temperature maintains around 90 degrees Celsius. 3. Battery Voltage maintains around 13.7 volts. Hi. Did you have OBD tool or otherwise where can i find tuis info from HU ir info cluster on current model? Link to post Share on other sites More sharing options...
Zensushi 1st Gear November 10, 2016 Share November 10, 2016 While the functional checks are important, they are usually covered by waranty. If the lights suddenly stopped working during the first few days, I would think that they are covered by warranty. I concentrated on defects on leather seats, interior and exterior panels including rims and tyres. Defects can be covered up by polishing so do be extra careful. Doors, boot and bonnet panels should be flushed and easy to open/close. Check exhaust tip for paint marks. Also open up the engine bay to check for leaks, coolant level or signs of repairs. Quoted for bookmark... for when I pick my ride. :Þ 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear November 11, 2016 Author Share November 11, 2016 (edited) Hi. Did you have OBD tool or otherwise where can i find tuis info from HU ir info cluster on current model? Yup, OBD2. Edited November 11, 2016 by Kklee Link to post Share on other sites More sharing options...
Zensushi 1st Gear November 11, 2016 Share November 11, 2016 Mine comes as a package. The film for the 2nd row lets in less light. What does "FWS" & "BWS" stand for, please? Link to post Share on other sites More sharing options...
7hm Turbocharged November 11, 2016 Share November 11, 2016 What does "FWS" & "BWS" stand for, please? In context of solar film, likely Front Wind Shield (or screen) and Back Wind Shield. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear November 12, 2016 Share November 12, 2016 vehicle info has 2 items only. 1) trip history and details 2) eco drive - how well have you used eco drive. based on 5 leaves. the more means you used it more efficiently Does the trip fc history creates a new bar automatically when you refuel ? Or only when you reset the average fc from the info cluster? I thought it created a new bar after my girst refuel but no new bar foe subsequent refuel. But i did not get full tank. Dont expect this is the reason. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear November 12, 2016 Share November 12, 2016 Is there a website that I can find out more information on this pioneer HU and also the apps that I can download to this HU? I was trying to google on toyota's istore (?) but can't find anything. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear November 13, 2016 Share November 13, 2016 There is no audio or blink when we open close trunk when the doors are locked despite its part of central lock. Is it possible to enable? Else I think this is a missing feature. Link to post Share on other sites More sharing options...
nomodox Neutral Newbie November 13, 2016 Share November 13, 2016 Does the trip fc history creates a new bar automatically when you refuel ? Or only when you reset the average fc from the info cluster? I thought it created a new bar after my girst refuel but no new bar foe subsequent refuel. But i did not get full tank. Dont expect this is the reason. You'll need to reset it after every refill. The reset button is on the right side of the steering wheel, press and hold till new bar appears. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear November 13, 2016 Share November 13, 2016 You'll need to reset it after every refill. The reset button is on the right side of the steering wheel, press and hold till new bar appears.Thanks. Given the fc of each drive can be measured with user intervention (one of the info cluster function) n fc upon refuel, they should write the app so user cannchoose to display the info as per trip, per refuel or average since last reset. My > 5 yrs old garmin can do this. Link to post Share on other sites More sharing options...
Reddy09 Neutral Newbie November 13, 2016 Share November 13, 2016 I am gonna change my stock halogen headlight bulbs (Altis Classic) to philips crystal vision which is whiter.Did your car come out with error code ? Check headlight system Link to post Share on other sites More sharing options...
Reddy09 Neutral Newbie November 13, 2016 Share November 13, 2016 (edited) Just change a aftermarket headlight using a HID light but keep on got error code(check headlight system)..check with shop they say need to use back the same voltage...anyone got recommendation where to get ? Edited November 13, 2016 by Reddy09 Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear November 13, 2016 Share November 13, 2016 Is there a website that I can find out more information on this pioneer HU and also the apps that I can download to this HU? I was trying to google on toyota's istore (?) but can't find anything.Got some time today n got onto the iAuto site. Not much there. They got more apps on social n entertainment and few tools. Eg youtube and facebook app. May be it is for passenger not driver to use? Will try the map search app download to my unit. See if it actually can work (the iAuto n app on HU). Link to post Share on other sites More sharing options...
Advancer 3rd Gear November 13, 2016 Share November 13, 2016 Did your car come out with error code ? Check headlight systemNope. Mine is classic and it's easily replaced using h11 type bulbs. Link to post Share on other sites More sharing options...
Reddy09 Neutral Newbie November 13, 2016 Share November 13, 2016 Nope. Mine is classic and it's easily replaced using h11 type bulbs.Where u get it from bro? Link to post Share on other sites More sharing options...
Advancer 3rd Gear November 13, 2016 Share November 13, 2016 Where u get it from bro?Bought from Carousell. The seller even came to my car park to install it for me. But 1 bulb decided to give way after 1 year and I reverted back to the stock bulb. I think it's cheaper on eBay but it ships from U.K. ↡ Advertisement Link to post Share on other sites More sharing options...
Should I sell my existing car
Wheel Bearing Labour cost
Toyota Corolla Cross
Toyota Land Cruiser Mini
Toyota bZ4X (2026) Part 2
