Happily1986 5th Gear February 23, 2019 Share February 23, 2019 Hi All, for Elegance (means 17" rim), the original tire (Michelin PIlot 3) which is good from my perspective. What other tires fits this rim and has good grip in wet weather and quiet (if these are opposing criteria then good grip is priority). Thanks. I would say Michelin Primacy 4 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear March 11, 2019 Share March 11, 2019 (edited) wondering if there is a way to display the google map from iphone on the HU LCD. I can do for andriod phone but somehow not my iphone. Still trying. btw when i connect my iphone with the lightning cable to the HU, i briefly saw a message about navigation. I cannot make the phone display this message again by unplug/plug the cable again. anyone know what it was telling me , and if something I need to do to enable navigation from phone and display on the HU with the lightning cable? Edited March 11, 2019 by ConnorMcLeod Link to post Share on other sites More sharing options...
Happily1986 5th Gear April 23, 2019 Share April 23, 2019 wondering if there is a way to display the google map from iphone on the HU LCD. I can do for andriod phone but somehow not my iphone. Still trying. btw when i connect my iphone with the lightning cable to the HU, i briefly saw a message about navigation. I cannot make the phone display this message again by unplug/plug the cable again. anyone know what it was telling me , and if something I need to do to enable navigation from phone and display on the HU with the lightning cable? I think this is only realistically possible if you had CarPlay. Personally i am still trying to find means to update the maps in the stock iAuto firmware. Does anybody knows if it is possible to purchase the door handle with the smart door sensor? Personally i find it quite stupid that the smart sensor is only located at the driver's door. It will be great if somehow at least the front passenger door handle has this smart door sensor too. Link to post Share on other sites More sharing options...
Happily1986 5th Gear May 11, 2019 Share May 11, 2019 Can someone check the votlage reading across the battery terminals on his or her 2014 corolla when 1. engine is running @ 2000 ~ 2200rpm 2. with electrical load i.e. A/C switched on with HU running My reading is about 13.8V so i would like to do a sanity check. Thanks Link to post Share on other sites More sharing options...
Kklee 6th Gear May 13, 2019 Author Share May 13, 2019 Can someone check the votlage reading across the battery terminals on his or her 2014 corolla when 1. engine is running @ 2000 ~ 2200rpm 2. with electrical load i.e. A/C switched on with HU running My reading is about 13.8V so i would like to do a sanity check. Thanks Hmm.... I thought should be higher.... Link to post Share on other sites More sharing options...
Happily1986 5th Gear May 13, 2019 Share May 13, 2019 Hmm.... I thought should be higher....What’s your reading? Link to post Share on other sites More sharing options...
IvanWenXiong Clutched May 13, 2019 Share May 13, 2019 Hi guys anyone have “hissing” sound coming from the rain sensor located beside/behind rear mirror? When I press and hold it will silence, sound can be heard even car moving or not moving. Went down Borneo twice and highlighted during servicing also keep coming back. Link to post Share on other sites More sharing options...
Kklee 6th Gear May 13, 2019 Author Share May 13, 2019 What’s your reading? IIRC, above 14. I will try to check later. Link to post Share on other sites More sharing options...
Happily1986 5th Gear May 13, 2019 Share May 13, 2019 IIRC, above 14. I will try to check later. Thank you for that. Very much appreciated. Link to post Share on other sites More sharing options...
Kklee 6th Gear May 13, 2019 Author Share May 13, 2019 Thank you for that. Very much appreciated. After a long drive, at IDLE, it is 13.8v. Eh... single person, so cannot rev engine to above 2000rpm. Link to post Share on other sites More sharing options...
Happily1986 5th Gear May 14, 2019 Share May 14, 2019 After a long drive, at IDLE, it is 13.8v. Eh... single person, so cannot rev engine to above 2000rpm. Thank you! i couldn’t praise your post cos i have praised some other post from you recently 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear June 22, 2019 Author Share June 22, 2019 I just want to comment that the car runs very well using Malaysia ron97 and Malaysia Shell Vpower. Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear June 22, 2019 Share June 22, 2019 i tried VPower in MY last time too and was good. It worked out like SGD40 for almost a full tank iirc so worth trying it in MY. I just want to comment that the car runs very well using Malaysia ron97 and Malaysia Shell Vpower. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear June 22, 2019 Author Share June 22, 2019 (edited) i tried VPower in MY last time too and was good. It worked out like SGD40 for almost a full tank iirc so worth trying it in MY. IMHO, the car is suitable to use higher octane. The only consideration in SG is the price. Edited June 22, 2019 by Kklee Link to post Share on other sites More sharing options...
inlinesix Hypersonic June 22, 2019 Share June 22, 2019 i tried VPower in MY last time too and was good. It worked out like SGD40 for almost a full tank iirc so worth trying it in MY. Don't waste money on Vpower. Want to spend money? Go & pump RON100. Link to post Share on other sites More sharing options...
Kklee 6th Gear June 22, 2019 Author Share June 22, 2019 Don't waste money on Vpower. Want to spend money? Go & pump RON100. In MY, i don't specifically look for what to pump. I just reach the pump and pump. Link to post Share on other sites More sharing options...
louisbosco 3rd Gear June 24, 2019 Share June 24, 2019 (edited) Anyone knows the pcd of Altis? The tyres are worn out. Thinking of changing to 17" rims 5x100 Hope it helps uh pretty sure it's 5x114.3. 5x100 is for USDM models.. Edited June 24, 2019 by louisbosco Link to post Share on other sites More sharing options...
ConnorMcLeod 2nd Gear August 3, 2019 Share August 3, 2019 Anyone knows if the doors will auto lock if you parked the car n forgot to lock it with door handle or fob key ? I know if I unlock then a minute or so later it will lock. But dunno what happens after drive. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Toyota bZ4X
2022 Toyota bZ4X
Barrier arms raised at carpark gantries in 500 HDB estates following ‘technical difficulties’
Nissan QashQai 2014 Part 2
