richard_crl032 6th Gear June 1, 2018 Share June 1, 2018 Thanks Richard. Did you change cvt fluid at MI or outside? What cvt fluid did you use? MI maintenance schedule indicated 40k mileage to change cvt fluid, at $180 for the cvt fluid change itself, others like EO change and diff oil are separated. That orange color high torque cvt fluid costs $600++ per pail so if MI charges only $180 to do then its really quite cheap. Hmmm...... Hi Orixy, My mileage is 15k km and yet to change .. perhaps at 20k km since 1st time and then at 40 or 50k km depending if got extra funds ..keke ! AD ws do not flush and replace and I go to katc auto at ubi road to do so for my qashqai but it is not cheap as they need another 3-4l to circulate and dilute as much as possible .. 300+ excluding any needed filter replacement. Cheers Richard ↡ Advertisement Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 1, 2018 Share June 1, 2018 (edited) Hi Bros, Not sure fna but fxt's stock battery is 48Ah nia which say good things and not bad things of the electrical design .. geting booster fuse installed and decided to upgrade one of the best Varta Silver Dynamic E39. https://www.hkbelect.com/product/206-mk3-micro-blade-75a-electronic-fuse-version-2016/ Note have to cut bottom tray cos 11" vs stock 10" but fit swee swee. Cheers. Richard PS: great find on this neighbourhood battery shop with galore of Varta batteries and not paying about 500 at audio shops Edited June 1, 2018 by richard_crl032 Link to post Share on other sites More sharing options...
Orixy 2nd Gear June 1, 2018 Share June 1, 2018 Hi Bros, Not sure fna but fxt's stock battery is 48Ah nia which say good things and not bad things of the electrical design .. geting booster fuse installed and decided to upgrade one of the best Varta Silver Dynamic E39. https://www.hkbelect.com/product/206-mk3-micro-blade-75a-electronic-fuse-version-2016/ Note have to cut bottom tray cos 11" vs stock 10" but fit swee swee. Cheers. Richard PS: great find on this neighbourhood battery shop with galore of Varta batteries and not paying about 500 at audio shops Nice! Pls share this Varta shop and how much u paid for the 70ah batt :) Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 1, 2018 Share June 1, 2018 (edited) Nice! Pls share this Varta shop and how much u paid for the 70ah batt :)Hi Orixy, Ngai Heng Battery 36 Yio Chu Kang Road Varta E39 AGM 70Ah@sgd338 nett. Btw, cranking current spec is 700+ vs 300+ stock battery ...lol ! Cheers. Richard Edited June 1, 2018 by richard_crl032 Link to post Share on other sites More sharing options...
titaniclexus 3rd Gear June 1, 2018 Share June 1, 2018 Anyone try this SYMS air intake? Hear tat good for FNA owner, improve performance..... hmm...... Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear June 1, 2018 Share June 1, 2018 Thanks Richard. Did you change cvt fluid at MI or outside? What cvt fluid did you use? MI maintenance schedule indicated 40k mileage to change cvt fluid, at $180 for the cvt fluid change itself, others like EO change and diff oil are separated. That orange color high torque cvt fluid costs $600++ per pail so if MI charges only $180 to do then its really quite cheap. Hmmm...... Hi Orixy, From Lesun, the pail of HI-Torque CVT will cost you $450.00. If I am not wrong. The pail of is 18~20 liters, which is sufficient for many changes. In TR690 transmission, there is a paper filter. http://jp-carparts.com/subaru/partlist.php?maker=subaru&car_baseid=F33004&type=S13&cartype=007&fig_id=154 For the CVT maintenance; drain and fill will be sufficient. But have to ensure correct cvt fluid level in transmission during fill. Thank you. Best regards, K. C. Link to post Share on other sites More sharing options...
Epsilon 2nd Gear June 2, 2018 Share June 2, 2018 (edited) Usually swapping for rims and tyres, does the WS do any wheel balancing? Usually what is the cost like? Thanks Edited June 2, 2018 by Epsilon 1 Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear June 2, 2018 Share June 2, 2018 (edited) Usually swapping for rims and tyres, does the WS do any wheel balancing? Usually what is the cost like? Thanks Hi Epsilon, Yes. They are suppose to perform wheel balancing for all wheels during wheel rotation. Depends on the tyre shop, the cost will vary. Some might charge $10~$20 or more. Some provide free lifetime rotation and puncture repair. Thank you. Best regards, K. C. Edited June 2, 2018 by OnceInALifeTime Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear June 2, 2018 Share June 2, 2018 (edited) Hi to all owners who might like to self install Cusco Master Brake Cylinder on Forester XT, It is quite an easy process; with fours bolts, one spacer and one washer to be used. The only difficulty encountered was tight working space. Only simple tools required. Allen Key and Spanners. Part number as provided in the pictures for those who buy online. Thank you. Best regards, K. C. Edited June 2, 2018 by OnceInALifeTime 1 Link to post Share on other sites More sharing options...
Xefera 6th Gear June 3, 2018 Share June 3, 2018 Can provide feedback on the braking feel after installation? Can still feel the firewall flex during heavy braking? Hi to all owners who might like to self install Cusco Master Brake Cylinder on Forester XT, It is quite an easy process; with fours bolts, one spacer and one washer to be used. The only difficulty encountered was tight working space. Only simple tools required. Allen Key and Spanners. Part number as provided in the pictures for those who buy online. Thank you. Best regards, K. C. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 3, 2018 Share June 3, 2018 Can provide feedback on the braking feel after installation? Can still feel the firewall flex during heavy braking?Hi Xefera, KC is awaiting for his fxt and only nicely sharing info. For me, no significant difference after installation at BKS but I do have Ksport BBK and stock ride may or may not have more significant difference. Cheers. Richard Link to post Share on other sites More sharing options...
Orixy 2nd Gear June 3, 2018 Share June 3, 2018 Hi Orixy, From Lesun, the pail of HI-Torque CVT will cost you $450.00. If I am not wrong. The pail of is 18~20 liters, which is sufficient for many changes. In TR690 transmission, there is a paper filter. http://jp-carparts.com/subaru/partlist.php?maker=subaru&car_baseid=F33004&type=S13&cartype=007&fig_id=154 For the CVT maintenance; drain and fill will be sufficient. But have to ensure correct cvt fluid level in transmission during fill. Thank you. Best regards, K. C. Thanks KC for the research info on the CVT fluid! Thumbs up! :) Link to post Share on other sites More sharing options...
Orixy 2nd Gear June 3, 2018 Share June 3, 2018 Just to share i just swapped my stock BS Dueler H/L 400 for 235/55/R18 Michelin Latitude Sport 3 for $1k ($250×4). First impression was very very nice! Instantly the grip was much better than before and the steering response was way better than the botak-ing Dueler HL400s. It was raining when i took them to Msia over the weekend and the wet grip was good too. Aqua planning was to the minimum when going over puddles of water on Msia B roads. Puts a grin on me for a cool $1k spent! 2 Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear June 3, 2018 Share June 3, 2018 Can provide feedback on the braking feel after installation? Can still feel the firewall flex during heavy braking? I do feel that it is slight firmer during braking. Slightly lesser travel (depressing) of the brake pedal to get the "bite" of the brakes. Note: The installation does not improve or decrease the brake performance. As it is not a change of brake system parts. Hi to all owners who might like to self install Cusco Master Brake Cylinder on Forester XT, It is quite an easy process; with fours bolts, one spacer and one washer to be used. The only difficulty encountered was tight working space. Only simple tools required. Allen Key and Spanners. Part number as provided in the pictures for those who buy online. Thank you. Best regards, K. C. Missed on the tools required: 1. 12 mm Spanner 2. 10 mm Spanner 3. 10 mm Allen Key Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 4, 2018 Share June 4, 2018 I do feel that it is slight firmer during braking. Slightly lesser travel (depressing) of the brake pedal to get the "bite" of the brakes. Note: The installation does not improve or decrease the brake performance. As it is not a change of brake system parts. Missed on the tools required: 1. 12 mm Spanner 2. 10 mm Spanner 3. 10 mm Allen Key Hi KC, Congras !! Din realised you had received your ride ... enjoy !! Cheers, Richard PS: Please PM me to collect the underseat aircon ductings/funnels reserved for you. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear June 4, 2018 Share June 4, 2018 Just to share i just swapped my stock BS Dueler H/L 400 for 235/55/R18 Michelin Latitude Sport 3 for $1k ($250×4). First impression was very very nice! Instantly the grip was much better than before and the steering response was way better than the botak-ing Dueler HL400s. It was raining when i took them to Msia over the weekend and the wet grip was good too. Aqua planning was to the minimum when going over puddles of water on Msia B roads. Puts a grin on me for a cool $1k spent! Hi Orixy, Good to know and nice ! Believe added positive of heavier steering which is also less vague with 235 compared to stock 225 width .... With our AWD, aqua planning performance is top notch and minimal loss of control even with significant water puddles. Cheers, Richard Link to post Share on other sites More sharing options...
OnceInALifeTime 2nd Gear June 4, 2018 Share June 4, 2018 Hi KC, Congras !! Din realised you had received your ride ... enjoy !! Cheers, Richard PS: Please PM me to collect the underseat aircon ductings/funnels reserved for you. Hi Richard, Thank you for your well-wishes. Currently, slightly tied up with too many "things-to-do" and daily stuffs. Do take care. Best regards, K. C. 1 Link to post Share on other sites More sharing options...
Xefera 6th Gear June 4, 2018 Share June 4, 2018 Hi Xefera, KC is awaiting for his fxt and only nicely sharing info. For me, no significant difference after installation at BKS but I do have Ksport BBK and stock ride may or may not have more significant difference. Cheers. Richard Thanks Richard. Tempted to install but not fully convinced yet. I do feel that it is slight firmer during braking. Slightly lesser travel (depressing) of the brake pedal to get the "bite" of the brakes. Note: The installation does not improve or decrease the brake performance. As it is not a change of brake system parts. Thanks KC. Will add this to the pool of mods in future. ↡ Advertisement Link to post Share on other sites More sharing options...
2022 Subaru Solterra BEV
Advice on exhaust.
Advice on exhaust.
