Adyrai 1st Gear July 29, 2018 Share July 29, 2018 Just placed my deposit today! Hope everything goes smooth on next COE bidding! Congrats , do you get good deals ? ↡ Advertisement Link to post Share on other sites More sharing options...
Ck3128 Clutched July 29, 2018 Share July 29, 2018 (edited) Congrats , do you get good deals ? hmmm... I think so! Already squeezed the maxed out of the SE I believed.... lol Edited July 29, 2018 by Ck3128 Link to post Share on other sites More sharing options...
Echew Neutral Newbie July 29, 2018 Share July 29, 2018 @Ck3128 congrats on making the purchase! Are you able to share with me some of the freebies you managed to get? Was at the Ubi showroom today and the sales rep was like there’s nothing at all I can give you. Maybe you can share who served you? 3 Link to post Share on other sites More sharing options...
Jus4fun 1st Gear July 29, 2018 Share July 29, 2018 @Ck3128 congrats on making the purchase! Are you able to share with me some of the freebies you managed to get? Was at the Ubi showroom today and the sales rep was like thereâs nothing at all I can give you. Maybe you can share who served you?Heard frm my dealer that C&C Ubi is an independent family-owner dealer of C&C. Better to go to C&C Alexandra, may be able to get better deal.. 2 Link to post Share on other sites More sharing options...
Jus4fun 1st Gear July 29, 2018 Share July 29, 2018 Hi all, I always off my AS&G bcos dun like the feel of the engine stopping n starting (with a faint jerk) intermittently. So far so good until recently, I feel tt engine shows very faint 'stop n start' (although the engine does not actually stop) despite the function is off. Anyone else experiences the same? Link to post Share on other sites More sharing options...
Echew Neutral Newbie July 29, 2018 Share July 29, 2018 Heard frm my dealer that C&C Ubi is an independent family-owner dealer of C&C. Better to go to C&C Alexandra, may be able to get better deal.. Thanks for the tip. I'll check out Alexandra tomorrow. :) Link to post Share on other sites More sharing options...
Contipro 5th Gear July 29, 2018 Share July 29, 2018 Hi all, I always off my AS&G bcos dun like the feel of the engine stopping n starting (with a faint jerk) intermittently. So far so good until recently, I feel tt engine shows very faint 'stop n start' (although the engine does not actually stop) despite the function is off. Anyone else experiences the same?your rpm drop till how low ? Link to post Share on other sites More sharing options...
Ck3128 Clutched July 29, 2018 Share July 29, 2018 Thanks for the tip. I'll check out Alexandra tomorrow. :) yea... I went Alexanda showroom as well. There is one SE I meet "Izaac", he is quite friendly and totally no pushy at all. I know some of the SE at C&C tend to be quite "cocky" or very pushy... pm me if you need this SE contact. Btw, tomorrow he will be at Tampines 1 roadshow. Tuesday only he will be back to showroom. Cheers. Link to post Share on other sites More sharing options...
Jus4fun 1st Gear July 30, 2018 Share July 30, 2018 your rpm drop till how low ?It's typically at 800rpm when idling at the traffic lights.. Then rpm will go up to 900rpm momentarily then return to 800rpm.. as if the AS&G is activated (although it's off). Is this normal? Link to post Share on other sites More sharing options...
Contipro 5th Gear July 30, 2018 Share July 30, 2018 It's typically at 800rpm when idling at the traffic lights.. Then rpm will go up to 900rpm momentarily then return to 800rpm.. as if the AS&G is activated (although it's off). Is this normal? When AS&G is switch ON. AS&G the rpm is at "zero" when activated, engine fully stop. sometime if you do not press the brake pedal hard enough (means sometime press little already can hold the car from moving), the AS&G will not activate to stop the engine. When AS&G is switch OFF AS&G will not activate at all. the scenario you mentioned is where the air con compressor clutch cut in and cut out; as it regulating the coolant required according to your set air con temperature. if you coming from korean car, you will notice this significant different. As for korean car most design the air con compressor clutch is always engage when you turn on A/C. then it use the radiator hot water to regulate the air con output temperature accordance to your set air temperature. so in this design you will not notice the engine rpm fluctuating between 800~900rpm. 2 Link to post Share on other sites More sharing options...
Jus4fun 1st Gear July 30, 2018 Share July 30, 2018 (edited) When AS&G is switch ON. AS&G the rpm is at "zero" when activated, engine fully stop. sometime if you do not press the brake pedal hard enough (means sometime press little already can hold the car from moving), the AS&G will not activate to stop the engine. When AS&G is switch OFF AS&G will not activate at all. the scenario you mentioned is where the air con compressor clutch cut in and cut out; as it regulating the coolant required according to your set air con temperature. if you coming from korean car, you will notice this significant different. As for korean car most design the air con compressor clutch is always engage when you turn on A/C. then it use the radiator hot water to regulate the air con output temperature accordance to your set air temperature. so in this design you will not notice the engine rpm fluctuating between 800~900rpm. Thanks bro! Pro as always! Edited July 30, 2018 by Jus4fun 1 Link to post Share on other sites More sharing options...
Lee9389ck 4th Gear July 31, 2018 Share July 31, 2018 Just placed my deposit today! Hope everything goes smooth on next COE bidding! Good luck bro :) Gotten my COE during last bidding so hoping you’ll be similarly successful on 8 Aug :) 1 Link to post Share on other sites More sharing options...
Bancer Clutched August 1, 2018 Share August 1, 2018 Good luck bro :) Gotten my COE during last bidding so hoping youâll be similarly successful on 8 Aug :) When is your expected delivery? Booked mine mid July and got my coe too, delivery only in Nov. Long wait. 1 Link to post Share on other sites More sharing options...
Ck3128 Clutched August 2, 2018 Share August 2, 2018 When is your expected delivery? Booked mine mid July and got my coe too, delivery only in Nov. Long wait. So late? You picked red right? Link to post Share on other sites More sharing options...
Lee9389ck 4th Gear August 2, 2018 Share August 2, 2018 When is your expected delivery? Booked mine mid July and got my coe too, delivery only in Nov. Long wait. Haha, mine only marginally better, was told to expect delivery in Oct... but hoping late Sept...fingers crossed.... Link to post Share on other sites More sharing options...
Bancer Clutched August 2, 2018 Share August 2, 2018 Yeah booked red. What colors u guys book? I suppose same batch of shipment no matter the color? Link to post Share on other sites More sharing options...
JohnnyBGood 1st Gear August 2, 2018 Share August 2, 2018 I'm encountering a really strange problem using Android Auto now. When I plug my phone into the front USB port situated next to the ECO MODE button, the system gives me a "unsupported device detected" error message. However, when I plug my phone into the USB port inside the glove box, Android Auto works. Nothings seems to be wrong with the front USB port as well as I'm able to play MP3 songs from a thumbdrive plugged into it. I'm really puzzled what could be the problem. Anybody encountered the same problem as me? 1 Link to post Share on other sites More sharing options...
Ck3128 Clutched August 2, 2018 Share August 2, 2018 Yeah booked red. What colors u guys book? I suppose same batch of shipment no matter the color? That's why! I believe Red is hot in demand comparing to the rest of the color... so the stocks will be very limited. I wanted red too but my wife dun like ... So I go for titanium grey . (SE told me should be able to get it around Sept if got the COE next week)... ↡ Advertisement Link to post Share on other sites More sharing options...
Deepal S05/E07/S07/S09/G318
Omoda E5
Omoda E5
BYD Sealion 6 DM-i
BYD Sealion 6 DM-i
Toyota Corolla Cross
Asian Games 2023-26
Asian Games 2023-26
MG 4/S5/S6 EV
MG 4/S5/S6 EV
[Official] 2021 Skoda Enyaq
2026 Volvo EX60 BEV
2026 Volvo EX60 BEV
