Hachi 3rd Gear August 12, 2019 Share August 12, 2019 (edited) Anyone DIY? Brought a thrttle body cleaner at Mr DIY, loosen the air duct, ask my kid to step on the accelrator when I on the igition swtich without starting the car. Open the e throttle, use a rag, spray the cleaner and clean it... Less than 10 mins job, spend less than $5. Remove battery terminal and reset the ECU, and start cleaning the battery terminals using steel brushes. Apply copper grease on the terminal and connect it back. Required Materials for this How to Clean a Throttle Body ProjectHere’s a list. Paper towels or rags Throttle body cleaner Gloves Edited August 12, 2019 by Hachi ↡ Advertisement 4 Link to post Share on other sites More sharing options...
KaKiLang 4th Gear August 13, 2019 Share August 13, 2019 I remove the whole body/MAF/positioning sensor and did a thorough cleaning. You be surprise the amount of gunk behind the butterfly and down the manifold. 4 Link to post Share on other sites More sharing options...
Hachi 3rd Gear August 14, 2019 Author Share August 14, 2019 Nice, yours is the cable one. Mine is the e throttle... Link to post Share on other sites More sharing options...
Jusnel 6th Gear November 19, 2019 Share November 19, 2019 Just did my throttle cleaning over weekend Went to this freelance guy, he did a pretty good job. Remove the throttle body and did the cleaning. $30. My mileage is 50k km. Throttle already has some junk behind it. The after effect of cleaning is good. I can feel smoother acceleration and gear change, car wont feel sluggish. Just like a brand new car. For some cars, they might show check engine lights after cleaning. I got it but it went away after a day. I heard its just the sensor that sense the different lean air or something. Everything is good! Link to post Share on other sites More sharing options...
Kklim Supercharged November 19, 2019 Share November 19, 2019 1 hour ago, Jusnel said: Just did my throttle cleaning over weekend Went to this freelance guy, he did a pretty good job. Remove the throttle body and did the cleaning. $30. My mileage is 50k km. Throttle already has some junk behind it. The after effect of cleaning is good. I can feel smoother acceleration and gear change, car wont feel sluggish. Just like a brand new car. For some cars, they might show check engine lights after cleaning. I got it but it went away after a day. I heard its just the sensor that sense the different lean air or something. Everything is good! Can share the contact? Thanks. Mine due for a clean-up. 1 Link to post Share on other sites More sharing options...
Limck007 Neutral Newbie November 28, 2019 Share November 28, 2019 On 11/19/2019 at 10:59 AM, Jusnel said: Just did my throttle cleaning over weekend Went to this freelance guy, he did a pretty good job. Remove the throttle body and did the cleaning. $30. My mileage is 50k km. Throttle already has some junk behind it. The after effect of cleaning is good. I can feel smoother acceleration and gear change, car wont feel sluggish. Just like a brand new car. For some cars, they might show check engine lights after cleaning. I got it but it went away after a day. I heard its just the sensor that sense the different lean air or something. Everything is good! can share with us the contacts ??? Link to post Share on other sites More sharing options...
QQDreamer 4th Gear December 1, 2019 Share December 1, 2019 (edited) On 11/19/2019 at 10:59 AM, Jusnel said: Just did my throttle cleaning over weekend Went to this freelance guy, he did a pretty good job. Remove the throttle body and did the cleaning. $30. My mileage is 50k km. Throttle already has some junk behind it. The after effect of cleaning is good. I can feel smoother acceleration and gear change, car wont feel sluggish. Just like a brand new car. For some cars, they might show check engine lights after cleaning. I got it but it went away after a day. I heard its just the sensor that sense the different lean air or something. Everything is good! u driving a honda civic? if you have CEL, please get your TPS value reset. Else your RPM will be dancing up and down. Even you remove battery 10000 times it will not cure. You may experience higher FC due to the RPM at higher range. Edited December 1, 2019 by StreamRSZ 1 Link to post Share on other sites More sharing options...
LoxXxA Neutral Newbie February 10, 2020 Share February 10, 2020 On 11/19/2019 at 10:59 AM, Jusnel said: Just did my throttle cleaning over weekend Went to this freelance guy, he did a pretty good job. Remove the throttle body and did the cleaning. $30. My mileage is 50k km. Throttle already has some junk behind it. The after effect of cleaning is good. I can feel smoother acceleration and gear change, car wont feel sluggish. Just like a brand new car. For some cars, they might show check engine lights after cleaning. I got it but it went away after a day. I heard its just the sensor that sense the different lean air or something. Everything is good! Can share with me the freelance contact? Mine idling has been rough and hoping by cleaning it will improve Link to post Share on other sites More sharing options...
henryhartmann Neutral Newbie February 24, 2020 Share February 24, 2020 not really relevant, when should I clean the throttle body? Link to post Share on other sites More sharing options...
Discoburg Supersonic March 1, 2020 Share March 1, 2020 Anyone received the contact for this freelancer?? Link to post Share on other sites More sharing options...
jdb613 Neutral Newbie March 16, 2020 Share March 16, 2020 You know, many GM trucks go into limp mode if Throttle Body is too grimey...PC will read "Service Stabilitrak, Service Traction Control, Engine power down"...One of the fixes for this headache is cleaning the heck out of the throttle body. 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 16, 2020 Share March 16, 2020 On 2/24/2020 at 3:58 PM, henryhartmann said: not really relevant, when should I clean the throttle body? Is hard to say. If you never drive the car to its optimum condition, there is sure some carbon around one. Maybe you can try to do like once every 3 years? Link to post Share on other sites More sharing options...
Noviaen Neutral Newbie April 8, 2020 Share April 8, 2020 On 11/19/2019 at 9:59 AM, Jusnel said: Just did my throttle cleaning over weekend Went to this freelance guy, he did a pretty good job. Remove the throttle body and did the cleaning. $30. My mileage is 50k km. Throttle already has some junk behind it. The after effect of cleaning is good. I can feel smoother acceleration and gear change, car wont feel sluggish. Just like a brand new car. For some cars, they might show check engine lights after cleaning. I got it but it went away after a day. I heard its just the sensor that sense the different lean air or something. Everything is good! looks so clean bruhhh Link to post Share on other sites More sharing options...
DavidGeller Neutral Newbie July 20, 2021 Share July 20, 2021 I think you should have a complete cleaning service. Sanitation Services in Long Beach. ↡ Advertisement Link to post Share on other sites More sharing options...
Simple home DIY repairs
Wheel Spacer Installation DIY
Is Wide Body Kit Illegal??
Scrap Value for my Integra
DIY Dashcam Installation vs Poor Worksmanship from Installation Workshops
Cooking: All About Beef
DIY detailing experiment
