Spring Moderator October 30, 2020 Share October 30, 2020 14 minutes ago, inlinesix said: Vezel/HRV also coming out by next yr so this segment will be competitive with the 2 big Jap brands introducing the 2 models at almost the same time. Hope this will make the ADs price their cars competitively! ↡ Advertisement 5 Link to post Share on other sites More sharing options...
Shouyi 3rd Gear November 10, 2020 Share November 10, 2020 BM going to bring in the 1.5 petrol or hybrid version ? Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 10, 2020 Share November 10, 2020 2 hours ago, mikk123 said: forget about BM, go for PI. BM prices will be too high to make any sense. That means a bare bone car. Link to post Share on other sites More sharing options...
Spoony 1st Gear November 11, 2020 Share November 11, 2020 i have ask around, most PI are just going to sell the X and XB model, you wont see any z specs due to VES banding to fall from a $10,000 rebate (currently projected) to a neutral grade, which means price difference between XB and Z will easily be more than $10,000 (higher OMV too = higher ARF and costing) zzzzzzzzzzzz Link to post Share on other sites More sharing options...
binkoon94 Clutched November 11, 2020 Share November 11, 2020 There will be PIs that will bring in higher spec variant definitely, just like the Raize Link to post Share on other sites More sharing options...
Spoony 1st Gear November 12, 2020 Share November 12, 2020 (edited) 23 hours ago, binkoon94 said: There will be PIs that will bring in higher spec variant definitely, just like the Raize so far the G specs Raize are the highest in spore...there is no z specs here The business mindset here more kasu . sell the lowest bare bone specs for maximum profit Edited November 12, 2020 by Spoony Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 12, 2020 Share November 12, 2020 On 11/11/2020 at 8:12 PM, binkoon94 said: There will be PIs that will bring in higher spec variant definitely, just like the Raize If it’s going to jump to a different VES banding then for sure no. Given that from next year it will be 15k difference between VES A2 and B. Link to post Share on other sites More sharing options...
haituni Neutral Newbie November 12, 2020 Share November 12, 2020 Does the one by Carle comes with toyota sensing? saw that they dropped it to 83k Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 13, 2020 Share November 13, 2020 14 hours ago, Mkl22 said: If it’s going to jump to a different VES banding then for sure no. Given that from next year it will be 15k difference between VES A2 and B. How does different spec affects VES banding? Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 13, 2020 Share November 13, 2020 (edited) 26 minutes ago, inlinesix said: How does different spec affects VES banding? upsize of the wheel. G grade yaris cross is 205/65R16 WLTC:30.2km/l, Z grade is 215/50R18 WLTC:27.8km/l thus CO2 emissions are different and also pollutants. https://toyota.jp/pages/contents/yariscross/001_p_001/4.0/pdf/spec/yariscross_spec_202008.pdf a good example was the 2018/19 audi A4 which came with 16in wheels. Edited November 13, 2020 by Mkl22 2 Link to post Share on other sites More sharing options...
binkoon94 Clutched November 13, 2020 Share November 13, 2020 27 minutes ago, Mkl22 said: upsize of the wheel. G grade yaris cross is 205/65R16 WLTC:30.2km/l, Z grade is 215/50R18 WLTC:27.8km/l thus CO2 emissions are different and also pollutants. https://toyota.jp/pages/contents/yariscross/001_p_001/4.0/pdf/spec/yariscross_spec_202008.pdf a good example was the 2018/19 audi A4 which came with 16in wheels. The emission readings in Singapore are independent from Japan’s emission reading. Depends on point of import if I’m not wrong. let’s see if any PIs will bring in the higher spec ones over the next few months. Saw on fb There is a PI doing a launch Tmr I think Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 13, 2020 Share November 13, 2020 (edited) 1 hour ago, binkoon94 said: The emission readings in Singapore are independent from Japan’s emission reading. Depends on point of import if I’m not wrong. let’s see if any PIs will bring in the higher spec ones over the next few months. Saw on fb There is a PI doing a launch Tmr I think Likely it won’t be far off. Test results will be close to WLTC. WLTC is a world standard. Edited November 13, 2020 by Mkl22 Link to post Share on other sites More sharing options...
haituni Neutral Newbie November 15, 2020 Share November 15, 2020 considering between yaris cross and honda fit.. any advice? Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 15, 2020 Share November 15, 2020 1 hour ago, haituni said: considering between yaris cross and honda fit.. any advice? Crossover vs Hatch How to give advice? Link to post Share on other sites More sharing options...
Zxcvb Turbocharged November 15, 2020 Share November 15, 2020 2 hours ago, haituni said: considering between yaris cross and honda fit.. any advice? Yaris Cross if you want to sit high, good for older folks getting in and out of car. 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 15, 2020 Share November 15, 2020 1 hour ago, Zxcvb said: Yaris Cross if you want to sit high, good for older folks getting in and out of car. 170mm vs 135mm Link to post Share on other sites More sharing options...
inlinesix Hypersonic November 24, 2020 Share November 24, 2020 1 Link to post Share on other sites More sharing options...
Zxcvb Turbocharged November 24, 2020 Share November 24, 2020 1 hour ago, inlinesix said: 水货. Even Hong Kong have to parallel import the Yaris Cross from Japan. ↡ Advertisement Link to post Share on other sites More sharing options...
MGS5
MGS5
2026 8th Generation Lexus ES
2025 Kia EV3
2025 Kia EV3
New 2015 Toyota Alphard and Vellfire
