Dafansu Turbocharged January 9, 2022 Share January 9, 2022 14 minutes ago, Inlinefour said: tpg is the cheapest but now seems getting very jialat liao most place will encounter sudden network missing maybe cutting cost I thought all along is like this. Relatively new operator with their own network base station, will need many more years before they stabilise, unlike other more established ones like Singtel, M1, Starhub. ↡ Advertisement Link to post Share on other sites More sharing options...
Adrianli Hypersonic January 10, 2022 Share January 10, 2022 23 hours ago, Inlinefour said: tpg is the cheapest but now seems getting very jialat liao most place will encounter sudden network missing maybe cutting cost Already cancelled my TPG last Oct and signed with MyRepublic. So far so good with MyRepublic. Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 10, 2022 Share January 10, 2022 36 minutes ago, Adrianli said: Already cancelled my TPG last Oct and signed with MyRepublic. So far so good with MyRepublic. they using M1 network? Link to post Share on other sites More sharing options...
Adrianli Hypersonic January 10, 2022 Share January 10, 2022 1 minute ago, Inlinefour said: they using M1 network? Yes. 1 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 10, 2022 Share January 10, 2022 5 minutes ago, Adrianli said: Yes. can opt for eSim? Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged January 10, 2022 Share January 10, 2022 27 minutes ago, Inlinefour said: can opt for eSim? I did use eSIM on myrepublic.. very easy to configure and almost activate immediately 2 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 10, 2022 Share January 10, 2022 2 minutes ago, Ody_2004 said: I did use eSIM on myrepublic.. very easy to configure and almost activate immediately useful when we can go overseas Link to post Share on other sites More sharing options...
Adrianli Hypersonic January 10, 2022 Share January 10, 2022 1 hour ago, Inlinefour said: can opt for eSim? I don't know. I am using physical sim. They use Ninjavan to deliver. Then the Ninja failed to deliver on the set date, indicating I not home. Had to call MyRepublic and Ninjavan to complain. Next day night, the Ninja delivered a soaking wet envelope containing the sim card. Very bad experience with them. 3 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 10, 2022 Share January 10, 2022 39 minutes ago, Ody_2004 said: I did use eSIM on myrepublic.. very easy to configure and almost activate immediately 1 hour ago, Adrianli said: Already cancelled my TPG last Oct and signed with MyRepublic. So far so good with MyRepublic. Looks like MR is the second cheapest to tpg now M1 bespoke slightly more expensive than MR Link to post Share on other sites More sharing options...
13177 Hypersonic January 10, 2022 Share January 10, 2022 40 minutes ago, Adrianli said: I don't know. I am using physical sim. They use Ninjavan to deliver. Then the Ninja failed to deliver on the set date, indicating I not home. Had to call MyRepublic and Ninjavan to complain. Next day night, the Ninja delivered a soaking wet envelope containing the sim card. Very bad experience with them. Must be Ninja not happy you complaint for failed delivery? Thats why they delivered a soaking wet envelope to you? Lol. 1 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic January 10, 2022 Share January 10, 2022 1 hour ago, Adrianli said: I don't know. I am using physical sim. They use Ninjavan to deliver. Then the Ninja failed to deliver on the set date, indicating I not home. Had to call MyRepublic and Ninjavan to complain. Next day night, the Ninja delivered a soaking wet envelope containing the sim card. Very bad experience with them. Did the idiot pee on it? 😁 5 Link to post Share on other sites More sharing options...
Kopites Supersonic January 10, 2022 Share January 10, 2022 2 hours ago, Adrianli said: I don't know. I am using physical sim. They use Ninjavan to deliver. Then the Ninja failed to deliver on the set date, indicating I not home. Had to call MyRepublic and Ninjavan to complain. Next day night, the Ninja delivered a soaking wet envelope containing the sim card. Very bad experience with them. My wife on MR. The only complain for MR is the voicemail by default. Still working out how to disable it. Link to post Share on other sites More sharing options...
zipping Supersonic January 10, 2022 Share January 10, 2022 9 minutes ago, Kopites said: My wife on MR. The only complain for MR is the voicemail by default. Still working out how to disable it. u can't, but there is a work around go to ur hp call settings, look for "call forwarding", change e numbers for "when busy", "when unanswered" & "when unreachable" to +651 (+65 is country code, e number 1 is just any number u wan to put, i use e number 1) Link to post Share on other sites More sharing options...
Kopites Supersonic January 10, 2022 Share January 10, 2022 6 hours ago, zipping said: u can't, but there is a work around go to ur hp call settings, look for "call forwarding", change e numbers for "when busy", "when unanswered" & "when unreachable" to +651 (+65 is country code, e number 1 is just any number u wan to put, i use e number 1) Yes. Thanks. Using this method there is a catch. The first call (re-route to +651) would take up a second of two. The immediate subsequent calls to that line won't go through. One need to pause for a second or 2 seconds before redialing again. Link to post Share on other sites More sharing options...
Loki Supersonic January 11, 2022 Share January 11, 2022 I swopped the whole family over to vivifi share last week. It was seamless and all numbers ported over from Gomo and Myrepublic easily. Now we have 120GB/mth which is insane. But after one year, it's down to 40GB to share across 3 lines. Link to post Share on other sites More sharing options...
Tkseah Turbocharged February 17, 2022 Share February 17, 2022 Me decided to switch over to Zero1 new $6.90 plan.. back to Singtel network.. 😁 1 Link to post Share on other sites More sharing options...
13177 Hypersonic February 17, 2022 Share February 17, 2022 31 minutes ago, Tkseah said: Me decided to switch over to Zero1 new $6.90 plan.. back to Singtel network.. 😁 $6.90 cheap sia. 1 Link to post Share on other sites More sharing options...
Ender Hypersonic February 18, 2022 Share February 18, 2022 18 hours ago, Tkseah said: Me decided to switch over to Zero1 new $6.90 plan.. back to Singtel network.. 😁 Wah, this one has to be the cheapest for low data users. comparable with the others MVNO's $10 plan.. ↡ Advertisement Link to post Share on other sites More sharing options...
Crazy weather in Singapore ?
National Service in Singapore
Marathons in Singapore
Paper exposing internal leaks for Civil servants to make property purchases near to upcoming MRTs
