Mkl22 Supersonic December 28, 2020 Share December 28, 2020 (edited) 10 hours ago, t0y0ta said: You should be first looking at your manual to check what is the proper sizes for your car instead of asking a forum where no one has any idea what you are driving. For 8in 225-235; 8.5in 235-245, 9in 245-255; 9.5in 255-265. with the latter number the preferred size. 225 on 8.5 will be stretched unless you are using fatter tires like Dunlop z3 or re71, where they are wider than typical 225 tires. They will still be stretched a bit but not as obvious as regular 225. Edited December 28, 2020 by Mkl22 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic December 28, 2020 Share December 28, 2020 (edited) 11 hours ago, q1n3fer said: But if take this.. there would be variance to the overall diameter and height of sidewall between the front and rear tyres. Like you said, a stock is250 already has unequal front and rear. So don’t be too worried about a 1-2% difference. Edited December 28, 2020 by Mkl22 Link to post Share on other sites More sharing options...
ER-3682 Supersonic December 28, 2020 Share December 28, 2020 9 hours ago, q1n3fer said: Using this profile for a long time already? No issues? No issue....i using BBS RI-A Wheels. 1 Link to post Share on other sites More sharing options...
q1n3fer 1st Gear December 29, 2020 Author Share December 29, 2020 9 hours ago, Mkl22 said: For 8in 225-235; 8.5in 235-245, 9in 245-255; 9.5in 255-265. with the latter number the preferred size. 225 on 8.5 will be stretched unless you are using fatter tires like Dunlop z3 or re71, where they are wider than typical 225 tires. They will still be stretched a bit but not as obvious as regular 225. yea.. this would be my biggest concern of fitting 225 on my 8.5.. that it will be overstretched thanks for the info! 1 Link to post Share on other sites More sharing options...
Naimed 5th Gear December 29, 2020 Share December 29, 2020 Also to take note that once you run a staggered setup, you cannot rotate the tyres front to back (v. versa). You can dismount the tyres and swap left to right in most cases if you are running bigger camber settings. They say a staggered setup is more stable at the corners but in Singapore, a bit over-rated with family sedan. I run a staggered setup (factory spec) and constantly thinking of going non-staggered so I can save some money on the 245/40 tyres vs 225/45. Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 29, 2020 Share December 29, 2020 16 minutes ago, Naimed said: Also to take note that once you run a staggered setup, you cannot rotate the tyres front to back (v. versa). You can dismount the tyres and swap left to right in most cases if you are running bigger camber settings. They say a staggered setup is more stable at the corners but in Singapore, a bit over-rated with family sedan. I run a staggered setup (factory spec) and constantly thinking of going non-staggered so I can save some money on the 245/40 tyres vs 225/45. Well, it depends on whether you pushed the limit or not. Nothing to do whether in Singapore or not. Link to post Share on other sites More sharing options...
Naimed 5th Gear December 29, 2020 Share December 29, 2020 15 minutes ago, inlinesix said: Well, it depends on whether you pushed the limit or not. Nothing to do whether in Singapore or not. Bruh, is250 family sedan, push limits? 1 Link to post Share on other sites More sharing options...
inlinesix Hypersonic December 29, 2020 Share December 29, 2020 2 minutes ago, Naimed said: Bruh, is250 family sedan, push limits? Why not? Use your imagination. Link to post Share on other sites More sharing options...
q1n3fer 1st Gear December 29, 2020 Author Share December 29, 2020 44 minutes ago, Naimed said: Also to take note that once you run a staggered setup, you cannot rotate the tyres front to back (v. versa). You can dismount the tyres and swap left to right in most cases if you are running bigger camber settings. They say a staggered setup is more stable at the corners but in Singapore, a bit over-rated with family sedan. I run a staggered setup (factory spec) and constantly thinking of going non-staggered so I can save some money on the 245/40 tyres vs 225/45. yea. am aware that i won't be able to rotate the tyres. anyway it's my first time running staggered. gonna see if it's gonna bleed my pocket dry. lol.. Link to post Share on other sites More sharing options...
q1n3fer 1st Gear December 29, 2020 Author Share December 29, 2020 12 minutes ago, Naimed said: Bruh, is250 family sedan, push limits? not gonna push the limits or anything. just purely for aesthetics purposes! 1 Link to post Share on other sites More sharing options...
Naimed 5th Gear December 29, 2020 Share December 29, 2020 21 minutes ago, inlinesix said: Why not? Use your imagination. Not seen anyone in their right mind push their stock family sedan with just rims and tyres change, although I have seen a few crashed Vios videos on youtube. Those are not my imagination. Next, we should go into discussion on suspension setup (control arms, sway bars, RCA, bushings and cornerweighting...etc)? He is just asking to change tyres leh, why imagine things for him? 2 Link to post Share on other sites More sharing options...
Beregond Supersonic December 29, 2020 Share December 29, 2020 1 hour ago, Naimed said: Also to take note that once you run a staggered setup, you cannot rotate the tyres front to back (v. versa). You can dismount the tyres and swap left to right in most cases if you are running bigger camber settings. They say a staggered setup is more stable at the corners but in Singapore, a bit over-rated with family sedan. I run a staggered setup (factory spec) and constantly thinking of going non-staggered so I can save some money on the 245/40 tyres vs 225/45. the 250 is orginal staggered already . nowsaday alot of bmw and merc all staggered, even their SUV come with factory spec staggered. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic December 29, 2020 Share December 29, 2020 (edited) 1 hour ago, q1n3fer said: not gonna push the limits or anything. just purely for aesthetics purposes! ya. every day drive the car , every day look at the car. most important is u look at your car u feel song. 😁 trust me go for 235😀 actually why u didnt consider 255.40.18 for rear?? Edited December 29, 2020 by Beregond Link to post Share on other sites More sharing options...
q1n3fer 1st Gear December 29, 2020 Author Share December 29, 2020 1 hour ago, Beregond said: ya. every day drive the car , every day look at the car. most important is u look at your car u feel song. 😁 trust me go for 235😀 actually why u didnt consider 255.40.18 for rear?? i think the tyre shop purpose is to get the least differential as possible between front and rear with regards to overall diameter and tyre sidewall height. am considering 235/40 and 265/35 now. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic December 29, 2020 Share December 29, 2020 2 minutes ago, q1n3fer said: am considering 235/40 and 265/35 now. 2653518 aysm 5. very limited. if want need fhfl. lol Link to post Share on other sites More sharing options...
q1n3fer 1st Gear December 29, 2020 Author Share December 29, 2020 1 minute ago, Beregond said: 2653518 aysm 5. very limited. if want need fhfl. lol just unsure if 265 would be overkill for is250.. lol! Link to post Share on other sites More sharing options...
Beregond Supersonic December 29, 2020 Share December 29, 2020 3 minutes ago, q1n3fer said: just unsure if 265 would be overkill for is250.. lol! Your rear original already 245. U go 265. Its 1 side add 5 cm only. The key issue is 255.35.18 is lower then 245.45.17 If u go this size. The gap between the fender and the tyre become bigger. And it look ugly. But your rim offset plus width plus 265 tyre. Will it protrude out of the fender? If out your inspection will fail. If totally flush will look very nice. But u carry full load behind might rub against tyre Link to post Share on other sites More sharing options...
q1n3fer 1st Gear December 29, 2020 Author Share December 29, 2020 15 minutes ago, Beregond said: Your rear original already 245. U go 265. Its 1 side add 5 cm only. The key issue is 255.35.18 is lower then 245.45.17 If u go this size. The gap between the fender and the tyre become bigger. And it look ugly. But your rim offset plus width plus 265 tyre. Will it protrude out of the fender? If out your inspection will fail. If totally flush will look very nice. But u carry full load behind might rub against tyre i have intentions to go for aftermarket coilovers after rims are done, so gap won't be an issue. and u just addressed out my concern. whether 265 will protrude out of fender not and i have to pick parents at times.. full load how also a question mark.. lol! ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Petlas Or Giti?
Petlas Or Giti?
Is this tyre good? Made in SG!! Giti tyres!
