kobayashiGT Internal Moderator January 7, 2022 Share January 7, 2022 The oil giant already operates a network of nearly 8,000 EV charging points. Source: https://insideevs.com/news/559069/shell-gas-station-ev-charging/ European oil companies are getting into the EV charging business in a big way—whether that’s a good thing remains to be seen, but Shell’s new “EV hub” in London certainly looks impressive. The oil giant, which currently operates a network of nearly 8,000 EV charging points, has converted an existing petrol station in Fulham, central London, to an electric vehicle charging hub that features ten 175 kW DC fast-charging stations, built by Australian manufacturer Tritium. The hub will offer “a comfortable seating area for waiting EV drivers,” along with a Costa Coffee store and a Little Waitrose & Partners shop. The hub features solar panels on the roof, and Shell says the chargers will be powered by 100% certified renewable electricity. It may be open for business by the time you read this. ↡ Advertisement 5 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 7, 2022 Author Share January 7, 2022 Hmmm. Coffee itself is not good enough. If Shell were to convert the store inside into an arcade shop, then I will consider it. Imagine you park your car at shell and charge your car, walk inside and start playing sim racing and next moment you are alrd at Fuji speedway tackling all the corners. This is what I call metaverse. 🤣 1 5 Link to post Share on other sites More sharing options...
Inlinefour Twincharged January 7, 2022 Share January 7, 2022 Back to square one I guess Cos charging price tag to oil prices again 🤣🤣🤣 Sea Hum Huat Ah 🤑🤑🤑 7 Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 7, 2022 Share January 7, 2022 With Kia EV6, 100km within 5 mins from 150kw DC Charger. Basically, plug into EV charger. Go pang jio. Come out can get 100km. 5 1 Link to post Share on other sites More sharing options...
D3badge 6th Gear January 7, 2022 Share January 7, 2022 11 minutes ago, kobayashiGT said: The oil giant already operates a network of nearly 8,000 EV charging points. Source: https://insideevs.com/news/559069/shell-gas-station-ev-charging/ European oil companies are getting into the EV charging business in a big way—whether that’s a good thing remains to be seen, but Shell’s new “EV hub” in London certainly looks impressive. The oil giant, which currently operates a network of nearly 8,000 EV charging points, has converted an existing petrol station in Fulham, central London, to an electric vehicle charging hub that features ten 175 kW DC fast-charging stations, built by Australian manufacturer Tritium. The hub will offer “a comfortable seating area for waiting EV drivers,” along with a Costa Coffee store and a Little Waitrose & Partners shop. The hub features solar panels on the roof, and Shell says the chargers will be powered by 100% certified renewable electricity. It may be open for business by the time you read this. Chey I thought in Singapore !! Was like wow impressive getting “ EV project “ASAP in Singapore ! Then read the news it is in London 😂😂😂 bubble burst ! For non landed 😂 let wait and see a few more years 4 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 7, 2022 Author Share January 7, 2022 7 minutes ago, D3badge said: Chey I thought in Singapore !! Was like wow impressive getting “ EV project “ASAP in Singapore ! Then read the news it is in London 😂😂😂 bubble burst ! For non landed 😂 let wait and see a few more years The shell charging station we have in SG are all fast charger, so 15 min will get 80% charge. Not bad lah. Plug liao go in play some daytona/initial D. lose liao come out and drive back home. 🤣 If is a normal charger, then the petrol station might consider opening a massage parlour thou. 😂 1 8 Link to post Share on other sites More sharing options...
t0y0ta Supercharged January 7, 2022 Share January 7, 2022 16 minutes ago, kobayashiGT said: The shell charging station we have in SG are all fast charger, so 15 min will get 80% charge. Not bad lah. Plug liao go in play some daytona/initial D. lose liao come out and drive back home. 🤣 If is a normal charger, then the petrol station might consider opening a massage parlour thou. 😂 Bro, Local Shell charger is only 50kW .... 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged January 7, 2022 Share January 7, 2022 10 minutes ago, kobayashiGT said: The shell charging station we have in SG are all fast charger, so 15 min will get 80% charge. Not bad lah. Plug liao go in play some daytona/initial D. lose liao come out and drive back home. 🤣 If is a normal charger, then the petrol station might consider opening a massage parlour thou. 😂 I think also depends on the car battery capacity and also its charging architecture (but all recent EVs should have rapid charging support). Twice when I charged a Hyundai Ioniq electric at Shell using the CCS (rapid) charging, I noted that at lower than 80% battery level, the charging time was about 1 minute for 2% charge. When the charge reached about 80%, the charging was pathetically slow, like 5 to 6 minutes for 1% increment; and so I stopped at that. So I guess if absolute distance or range is not a major concern, then rapid charging of EVs within a tolerable duration (of about 30 mins to 45 mins) should give drivers reasonable driving range/distance. The vehicle CCS charging port: Estimated range at about 80% battery charge: 6 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 7, 2022 Author Share January 7, 2022 7 minutes ago, DOBIEMKZ said: I think also depends on the car battery capacity and also its charging architecture (but all recent EVs should have rapid charging support). Twice when I charged a Hyundai Ioniq electric at Shell using the CCS (rapid) charging, I noted that at lower than 80% battery level, the charging time was about 1 minute for 2% charge. When the charge reached about 80%, the charging was pathetically slow, like 5 to 6 minutes for 1% increment; and so I stopped at that. So I guess if absolute distance or range is not a major concern, then rapid charging of EVs within a tolerable duration (of about 30 mins to 45 mins) should give drivers reasonable driving range/distance. The vehicle CCS charging port: Estimated range at about 80% battery charge: Don't worry! BYD have a new battery technology! The Blade battery! 1 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged January 7, 2022 Share January 7, 2022 5 minutes ago, kobayashiGT said: Don't worry! BYD have a new battery technology! The Blade battery! That is fantastic! BYD in EV industry is like Oppo in the smartphone market. Innovators and forerunners in rapid fast charging of batteries. 2 Link to post Share on other sites More sharing options...
inlinesix Hypersonic January 7, 2022 Share January 7, 2022 1 hour ago, t0y0ta said: Bro, Local Shell charger is only 50kW .... Copied from Shell Recharge webby. Link to post Share on other sites More sharing options...
Meanmachine Supercharged January 7, 2022 Share January 7, 2022 BYD Wan Shui, CHINA Wan Shui 😉 4 Link to post Share on other sites More sharing options...
Mkl22 Supersonic January 7, 2022 Share January 7, 2022 2 hours ago, inlinesix said: With Kia EV6, 100km within 5 mins from 150kw DC Charger. Basically, plug into EV charger. Go pang jio. Come out can get 100km. Meaning you get more mileage if you Pang Sai?🤣 6 Link to post Share on other sites More sharing options...
Soya Supersonic January 7, 2022 Share January 7, 2022 4 hours ago, kobayashiGT said: Hmmm. Coffee itself is not good enough. If Shell were to convert the store inside into an arcade shop, then I will consider it. Imagine you park your car at shell and charge your car, walk inside and start playing sim racing and next moment you are alrd at Fuji speedway tackling all the corners. This is what I call metaverse. 🤣 Lease out space to spa for short time n provide super quick chargers Charge and discharge Everybody happy 1 5 Link to post Share on other sites More sharing options...
Daniu82 Supercharged January 7, 2022 Share January 7, 2022 40 minutes ago, Soya said: Lease out space to spa for short time n provide super quick chargers Charge and discharge Everybody happy Every charge then go discharge 1 time, then those high mileage drivers confirm very fast become poor. 3 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged January 7, 2022 Share January 7, 2022 1 hour ago, Soya said: Lease out space to spa for short time n provide super quick chargers Charge and discharge Everybody happy Petrol pump attendants become masseurs. 2 1 Link to post Share on other sites More sharing options...
Carbon82 Moderator January 7, 2022 Share January 7, 2022 31 minutes ago, DOBIEMKZ said: Petrol pump attendants become masseurs. Wah lau, you have acquired taste... 2 7 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator January 7, 2022 Author Share January 7, 2022 Woah. I just create new business idea and job opportunities leh. 😎 Ah jack ah, I am so proud of you. 👋 * a pat on myself. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Nearly 2,000 HDB car parks to have at least 3 EV charging points each by 2025
Servicing car at Shell station
Shell x UOB Umbrella Redemption
Shell? Esso? Mobil? Caltex? SPC
Shell @ Yishun Ring Road is Closing Down
Join the Sgcarmart Stick It To Win It Contest now!
Shell x Monopoly 2021
