Jammed wheel nut
Mkl22
Internal Moderator
1 hour ago, ER-3682 said:
Thanks for buying from me...if you need one super big one..up to 3,000 Nm..i also have.😊
boss, you have a F16 fighter jet at your house ah? hahahah
  • Haha! 2
Internal Moderator
1 minute ago, ER-3682 said:
@kobayashiGT F16 Outdated liao..latest is F35..
F35 is govt level mah. They EOL F16 then will sell to public.
hahaha. You flying to ukaraine see see look look?
36 minutes ago, ER-3682 said:
Intake Manifold Bolts need to change to new ones once taken out from Engine..High Heat for many Years can weaken them..making them Brittle..
Yes I learnt the hard way.. Now I have ordered new bolts but need to extract the broken bolt first.
Is there such a thing as 1/2" torque wrench for torque specs under 30Nm?
Have...10-50 Nm.
Edited by ER-3682
Twincharged
32 minutes ago, ER-3682 said:
boss you threw in the 3/8" to 1/2" adapter for MCF members ah? 😁
3 minutes ago, kobayashiGT said:
Woah. Push thru sia.
What a name. :grin:
Push Thru means the Sq Drive can go either Left or Right Hand Screws.
  • Haha! 1
Use an adaptor.
I have all the step down, step up combinations.
Edited by Volvobrick
15 minutes ago, Volvobrick said:
Use an adaptor.
But too many adaptors, then the Torque at the nut will no longer be correct.
34 minutes ago, Volvobrick said:
Use an adaptor.
I try not to use adaptors...
  • Haha! 1
Don't use cheap adaptors for impact wrench!
No need Impact Wrench..lousy Adaptors even normal Torque Wrench..also can break it.
  • Haha! 1
Have you come across cheap spark plug sockets that crack when used to tighten the plug even though the maker claim the material is CRV ( durable, heat treated, chrome vanadium steel)
