Mkl22 Supersonic March 14, 2022 Share March 14, 2022 First time happened to me. 99% sure it was a tire shop at amk who cross threaded my wheel nuts and then air gunned and jammed it. lucky I asked the workshop to rotate my tires while I was there doing servicing. managed to get it done in 15mins and $40 poorer. Workshop managed to remove the nuts after a few minutes by tightening and loosening a few times using a impact gun. Both nut and screw were damaged in the end. but glad it was solved pretty quick. An impact gun can be use but the nut need to be threaded by hand for the 1st few threads. unfortunately the shop didn’t have an original nut to replace. Thus I now have an odd one out. Considering to replace them all since all are quite old anyway. ↡ Advertisement 6 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 14, 2022 Share March 14, 2022 8 minutes ago, Mkl22 said: First time happened to me. 99% sure it was a tire shop at amk who cross threaded my wheel nuts and then air gunned and jammed it. lucky I asked the workshop to rotate my tires while I was there doing servicing. managed to get it done in 15mins and $40 poorer. Workshop managed to remove the nuts after a few minutes by tightening and loosening a few times using a impact gun. Both nut and screw were damaged in the end. but glad it was solved pretty quick. An impact gun can be use but the nut need to be threaded by hand for the 1st few threads. unfortunately the shop didn’t have an original nut to replace. Thus I now have an odd one out. Considering to replace them all since all are quite old anyway. To change to a new wheel hub, it is not expensive expensive. For safety purpose, i will suggest you to change. And if you are changing, just change all 4. One of the reason why I don't really like tyres shop use impact wrench to secure the bolt. Everytime I go southeast tyres, The mechanic there will use a torque wrench to help me tighten, which I am very appreciative with. 8 Link to post Share on other sites More sharing options...
ER-3682 Supersonic March 14, 2022 Share March 14, 2022 Good Tyre Shop will use Torque Wrench..as final tightening. 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 14, 2022 Author Share March 14, 2022 (edited) 7 minutes ago, kobayashiGT said: To change to a new wheel hub, it is not expensive expensive. For safety purpose, i will suggest you to change. And if you are changing, just change all 4. One of the reason why I don't really like tyres shop use impact wrench to secure the bolt. Everytime I go southeast tyres, The mechanic there will use a torque wrench to help me tighten, which I am very appreciative with. Why need to change hub. Just change the screw and done. Only need to change hub if changing the wheel bearing. Edited March 14, 2022 by Mkl22 4 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 14, 2022 Share March 14, 2022 2 minutes ago, Mkl22 said: Why need to change hub. Just change the screw and done. Only need to change hub if changing the wheel bearing. oh. my theory is since already dismantle liao, might as well change also. Link to post Share on other sites More sharing options...
Mkl22 Supersonic March 14, 2022 Author Share March 14, 2022 2 minutes ago, kobayashiGT said: oh. my theory is since already dismantle liao, might as well change also. Mine was done in 10-15mins $40. A whole wheel bearing is at least $100 plus and more labour and have to wait to order in the parts. 1 Link to post Share on other sites More sharing options...
macrosszero Turbocharged March 14, 2022 Share March 14, 2022 32 minutes ago, kobayashiGT said: To change to a new wheel hub, it is not expensive expensive. For safety purpose, i will suggest you to change. And if you are changing, just change all 4. One of the reason why I don't really like tyres shop use impact wrench to secure the bolt. Everytime I go southeast tyres, The mechanic there will use a torque wrench to help me tighten, which I am very appreciative with. What for change wheel bearing. Change new car best. Best safety best reliability! 11 Link to post Share on other sites More sharing options...
Beregond Supersonic March 14, 2022 Share March 14, 2022 (edited) 44 minutes ago, kobayashiGT said: To change to a new wheel hub, it is not expensive expensive. For safety purpose, i will suggest you to change. And if you are changing, just change all 4. One of the reason why I don't really like tyres shop use impact wrench to secure the bolt. Everytime I go southeast tyres, The mechanic there will use a torque wrench to help me tighten, which I am very appreciative with. actually then SE. anymore tyres shop u know still using torque wrench😅 i say less then 10% . 3-5 % max or even lesser Edited March 14, 2022 by Beregond 2 Link to post Share on other sites More sharing options...
Gnahp Twincharged March 14, 2022 Share March 14, 2022 I kena exactly the same thing many years ago even normal workshop pneumatic impact gun also unable to unscrew it at the end drove to lorry workshop and use their BF 1" pneumatic impact wrench to unscrew it when I picked up the nut from the floor, it burnt a blister on my finger, that's how tight it was I didn't change the entire hub bought one piece of new wheel stud from stockist knock out the remnant of the broken stub knock in the new one 5 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 14, 2022 Share March 14, 2022 33 minutes ago, Beregond said: actually then SE. anymore tyres shop u know still using torque wrench😅 i say less then 10% . 3-5 % max or even lesser The best bet hor is you buy your own torque wrench and leave it inside your boot. When change tyres, take out and pass the mechanic. hahahahahaha. Like that 100% of the tyre shop in SG have torque wrench. 5 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator March 14, 2022 Share March 14, 2022 46 minutes ago, Macrosszero said: What for change wheel bearing. Change new car best. Best safety best reliability! Ahhhhh! I forgot! This is MCF. Anything not happy change car one! Wansui to 100K COE! hahahahahahaha 😭 2 Link to post Share on other sites More sharing options...
Gnahp Twincharged March 14, 2022 Share March 14, 2022 Just now, kobayashiGT said: The best bet hor is you buy your own torque wrench and leave it inside your boot. When change tyres, take out and pass the mechanic. hahahahahaha. Like that 100% of the tyre shop in SG have torque wrench. I am very tempted to do that but I worry I will hurt the feelings of the mechanic wait he says - you so clever you do it yourself lor 1 6 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged March 14, 2022 Share March 14, 2022 1 hour ago, kobayashiGT said: oh. my theory is since already dismantle liao, might as well change also. The hub is not a wear and tear item. So I don't think is necessary to change unless u want to make the ws owner happy. If bearings worn, yes. Can change both sides or all 4s. 4 Link to post Share on other sites More sharing options...
Stratovarius Turbocharged March 14, 2022 Share March 14, 2022 2 minutes ago, Phang said: I am very tempted to do that but I worry I will hurt the feelings of the mechanic wait he says - you so clever you do it yourself lor I recently tried Stamford mobile service just want to see how they do it. Impressed I must say. Even the mobile service used a torque wrench for the final tightening. 5 Link to post Share on other sites More sharing options...
Gnahp Twincharged March 14, 2022 Share March 14, 2022 Just now, Stratovarius said: I recently tried Stamford mobile service just want to see how they do it. Impressed I must say. Even the mobile service used a torque wrench for the final tightening. I did tire rotation at home last week, it's hard work I'll pay someone to do it if they do it properly 2 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic March 14, 2022 Share March 14, 2022 9 minutes ago, kobayashiGT said: The best bet hor is you buy your own torque wrench and leave it inside your boot. When change tyres, take out and pass the mechanic. hahahahahaha. Like that 100% of the tyre shop in SG have torque wrench. My guess is 90% of the mechanics never seen a torque wrench before and will just tighten using it without setting the torque! 3 3 Link to post Share on other sites More sharing options...
Beregond Supersonic March 14, 2022 Share March 14, 2022 6 minutes ago, Phang said: I am very tempted to do that but I worry I will hurt the feelings of the mechanic wait he says - you so clever you do it yourself lor they are not going to use their finger slowly turn the nuts in and then use the torque wench, they will use the impact wench then use the torque wench . 😂 to those that really want to protect your nuts and rim and really buy a torque wench. my best advice is must have a regular ws , they already know your pattern, and before u even suggest this, must inform u willing to pay extra like 20 buks for their time. 2 3 Link to post Share on other sites More sharing options...
Blackaccent 3rd Gear March 14, 2022 Share March 14, 2022 Last year went to LS at Paya Ubi to replace the air valve. Saw the worker using a torque wrench for the final tightening too. ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Wheel Hubs
Wheel Hubs
