Fitvip Supersonic April 4, 2022 Share April 4, 2022 1 minute ago, Jamesc said: Maintain or replace? How to maintain a fuel pump, starter, alternator, ignition coils etc? Take out and wash? Put oil and lubricate them? Hahaha, spray some perfume and put back! If they function normally, don't disturb lah! ↡ Advertisement 1 1 Link to post Share on other sites More sharing options...
DOBIEMKZ Turbocharged April 4, 2022 Share April 4, 2022 9 minutes ago, Jamesc said: Maintain or replace? How to maintain a fuel pump, starter, alternator, ignition coils etc? Take out and wash? Put oil and lubricate them? Fuel pump maintenance I know is not to let fuel tank drained out too often but the other items I think can only change new ones after certain number of years if owner wants to have some assurance that they won't fail in the next few years. Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 4, 2022 Share April 4, 2022 Ever took over a car from a fren...he gave me new parts for the faulty ones and a few more as standby...sold the car about a year later without any fixes done...chin cai lah...used car fix for wat...sold some and dumped some of the parts in the end 😁 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic April 4, 2022 Share April 4, 2022 If car use timing belt then need to change 60k to 90k km and at the same time might as well change the water pump as just to change the water pump have pay the labour cost again. Save cost to just do both at the same time. 1 Link to post Share on other sites More sharing options...
Comage 5th Gear April 4, 2022 Share April 4, 2022 4 hours ago, Confusedboi said: Think for alternator there will be some warning signs. Like for my case there was a period of time got some weird sound on and off when driving a couple of days before alternator finally gave up. I thought I had hit something under the car carriage and went to work shop to check but couldn’t find source of noise. A few days later on 1 march 2021, my battery warning light suddenly turned on, faster went to the nearest gas station. Battery became flat just as I managed to pull in to Newton gas station with Stanford tyres shop attached. Shop checked and alternator was dead that’s why battery drained completely flat. They changed New battery for me costing 115 dollars then I drove to nearest workshop. (Found one shell auto serv at Moulmein road where they ordered new alternator (original Dont have recon or OEM) which cost me 800 plus dollars including labor. Total damage 1k in one day zzz. Forgot to mention my car was 12 years old last year when the original alternator gave up. Likewise for me, my alternator started showing signs when I had my headlights turned on with the hazard lights and the interior cabin light on. The interior lights started flickering one day as I parked my car and was about to shut off everything. Went to workshop and my mechanic confirmed with a voltage test that the alternator was failing soon, as it was outputting a lower voltage range (low 13.x volts instead of a high 13.x volt range). So I changed that. Water pump, also managed to change it before it broke as I observed a funny sound one fine day. Brought to workshop to check, found the pump was leaking, and also it wouldn't turn smoothly (bearings were shot). So I changed that as well. Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 4, 2022 Author Share April 4, 2022 5 hours ago, Confusedboi said: Think for alternator there will be some warning signs. Like for my case there was a period of time got some weird sound on and off when driving a couple of days before alternator finally gave up. I thought I had hit something under the car carriage and went to work shop to check but couldn’t find source of noise. A few days later on 1 march 2021, my battery warning light suddenly turned on, faster went to the nearest gas station. Battery became flat just as I managed to pull in to Newton gas station with Stanford tyres shop attached. Shop checked and alternator was dead that’s why battery drained completely flat. They changed New battery for me costing 115 dollars then I drove to nearest workshop. (Found one shell auto serv at Moulmein road where they ordered new alternator (original Dont have recon or OEM) which cost me 800 plus dollars including labor. Total damage 1k in one day zzz. Forgot to mention my car was 12 years old last year when the original alternator gave up. did you keep the alternator? can be easily striped and rebuilt, replacing the brushes and bearings Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 4, 2022 Author Share April 4, 2022 7 minutes ago, Comage said: Likewise for me, my alternator started showing signs when I had my headlights turned on with the hazard lights and the interior cabin light on. The interior lights started flickering one day as I parked my car and was about to shut off everything. Went to workshop and my mechanic confirmed with a voltage test that the alternator was failing soon, as it was outputting a lower voltage range (low 13.x volts instead of a high 13.x volt range). So I changed that. Water pump, also managed to change it before it broke as I observed a funny sound one fine day. Brought to workshop to check, found the pump was leaking, and also it wouldn't turn smoothly (bearings were shot). So I changed that as well. lucky for you. for me to only sign was the battery light coming on, while driving home. which means alternator conk already. the very next day, just drove straight to workshop with aircon and radio off. try to reduce the electrical load. battery survived. i think overall distance was 10km at most, once the alternator conked. 1 Link to post Share on other sites More sharing options...
Confusedboi Supercharged April 4, 2022 Share April 4, 2022 2 hours ago, Mkl22 said: did you keep the alternator? can be easily striped and rebuilt, replacing the brushes and bearings lol nope didnt think to keep it, left it at the workshop. Link to post Share on other sites More sharing options...
Ody_2004 Turbocharged April 4, 2022 Share April 4, 2022 Since on this topic anyone who uses Start Stop since car was new? This technology i guess abt 10 to 15 years.. does it wear off parts faster? Battery and alternator lifespan affected? I not a fan of this until petrol price keep inching up! whahahahhahaa.. Link to post Share on other sites More sharing options...
mersaylee Hypersonic April 4, 2022 Share April 4, 2022 47 minutes ago, Ody_2004 said: Since on this topic anyone who uses Start Stop since car was new? This technology i guess abt 10 to 15 years.. does it wear off parts faster? Battery and alternator lifespan affected? I not a fan of this until petrol price keep inching up! whahahahhahaa.. I always switch it off. Petrol save will go to battery replacement...save the hassle as it's easier to pump petrol than to change battery...especially if it's a sudden death of battery...also need to add for recovery service 😁 5 Link to post Share on other sites More sharing options...
Comage 5th Gear April 4, 2022 Share April 4, 2022 9 hours ago, Mkl22 said: did you keep the alternator? can be easily striped and rebuilt, replacing the brushes and bearings Most of the time the workshop's cost is assuming they take back in the faulty alternator and they will throw into the junk pile first to be assessed whether it's good for reconditioning. Don't believe me? You can try to ask the workshop that you want to take back the faulty part - see how fast their tone changes and the cost quoted to you change as well... Link to post Share on other sites More sharing options...
Boxster 2nd Gear April 4, 2022 Share April 4, 2022 2 wks ago removed and disassemble my almost 15yo alternator to see if it was the alternator making noise with the help of youtube videos. Saw the brush was quite short and the rotor commutator has "a step" I rem see some post alternator parts supplier in Singapore but couldn't find the post. I think it is difficult to get a brush for alternator. Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 4, 2022 Author Share April 4, 2022 4 hours ago, Comage said: Most of the time the workshop's cost is assuming they take back in the faulty alternator and they will throw into the junk pile first to be assessed whether it's good for reconditioning. Don't believe me? You can try to ask the workshop that you want to take back the faulty part - see how fast their tone changes and the cost quoted to you change as well... I have only changed alternator twice. Once it was remove and replace brushes and the the time was a brand new and I took back the old Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 4, 2022 Author Share April 4, 2022 19 minutes ago, Boxster said: 2 wks ago removed and disassemble my almost 15yo alternator to see if it was the alternator making noise with the help of youtube videos. Saw the brush was quite short and the rotor commutator has "a step" I rem see some post alternator parts supplier in Singapore but couldn't find the post. I think it is difficult to get a brush for alternator. If yours is a common car, then you probably can google the alternator model and buy the part online 1 Link to post Share on other sites More sharing options...
Comage 5th Gear April 4, 2022 Share April 4, 2022 27 minutes ago, Mkl22 said: I have only changed alternator twice. Once it was remove and replace brushes and the the time was a brand new and I took back the old You're lucky they still bother to fix it for you... My workshop won't bother with such repairs, and will simply sell a proper reconditioned unit or a brand new one. Asked them why? They said repair takes too much time; they'll just swap in a recon unit for customer and take back the customer's existing unit.. And off you go within the same working day. 3 Link to post Share on other sites More sharing options...
Beregond Supersonic April 5, 2022 Share April 5, 2022 54 minutes ago, Comage said: You're lucky they still bother to fix it for you... My workshop won't bother with such repairs, and will simply sell a proper reconditioned unit or a brand new one. Asked them why? They said repair takes too much time; they'll just swap in a recon unit for customer and take back the customer's existing unit.. And off you go within the same working day. Its like that . the cost is the same. a recon unit is repair from a damage unit. just that they fix it and get it ready before hand. as customer we dun need wait for them to fix our damage, and for ws , there is no rush for them to repair at once also esp if they busy . 1 Link to post Share on other sites More sharing options...
Comage 5th Gear April 5, 2022 Share April 5, 2022 1 hour ago, Beregond said: Its like that . the cost is the same. a recon unit is repair from a damage unit. just that they fix it and get it ready before hand. as customer we dun need wait for them to fix our damage, and for ws , there is no rush for them to repair at once also esp if they busy . Yes I understand this part on the workshop wanting to save their time. The only crap situation I encountered was I had an original part that broke (it was a driveshaft), and the guy wanted to swap in a reconditioned OEM part - and I still must pay for it! The original driveshaft cost 3-4x that of the OEM part! 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic April 5, 2022 Author Share April 5, 2022 23 minutes ago, Comage said: Yes I understand this part on the workshop wanting to save their time. The only crap situation I encountered was I had an original part that broke (it was a driveshaft), and the guy wanted to swap in a reconditioned OEM part - and I still must pay for it! The original driveshaft cost 3-4x that of the OEM part! they probably took an old orig driveshaft and replaced the CV joints on both ends, thus OEM.. depending on the CV joints used. could be as good as orig ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Nissan Preventive Maintenance Programme
Coolant question
Coolant question
Car repair and maintenance
Extending COE for Toyota Wish (2008)
Ho Hup Seng......Some good info for our Brudders
