Lala81 Hypersonic November 20, 2022 Share November 20, 2022 Just wanted to ask some general questions about coolant. My car almost 8 years old liao. Was told on my last servicing that coolant was "low condition", required $60 to change. I declined as i already spent some money on changing brake fluid and also replacing my fan/serpentine belt which they said was cracked. Servicing manual says change coolant every 30k. Car is being serviced once a year. I thought it was just a simple top up like washer fluid or what. I didn't look inside the engine bay. So i bought a 2L coolant bottle on 11.11 to "top up". I also watched some youtube videos, so i do know how to release the spigot valve at the bottom of the radiator for my model. To do a full change would probably require somewhere in the level of at least a a couple more litres. Hmm today morning went to take a look when my engine was cold, but the coolant in the reservoir tank is actually above the maximum mark. Then open radiator cap is u can see the fluid level but i know there's no marking inside. So should i buy more coolant and do a full flush? Is the above the maximum mark coolant level in the coolant reservoir abnormal? My engine temps dont seem to have any issue. ↡ Advertisement Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 20, 2022 Share November 20, 2022 (edited) 19 minutes ago, Lala81 said: Just wanted to ask some general questions about coolant. My car almost 8 years old liao. Was told on my last servicing that coolant was "low condition", required $60 to change. I declined as i already spent some money on changing brake fluid and also replacing my fan/serpentine belt which they said was cracked. Servicing manual says change coolant every 30k. Car is being serviced once a year. I thought it was just a simple top up like washer fluid or what. I didn't look inside the engine bay. So i bought a 2L coolant bottle on 11.11 to "top up". I also watched some youtube videos, so i do know how to release the spigot valve at the bottom of the radiator for my model. To do a full change would probably require somewhere in the level of at least a a couple more litres. Hmm today morning went to take a look when my engine was cold, but the coolant in the reservoir tank is actually above the maximum mark. Then open radiator cap is u can see the fluid level but i know there's no marking inside. So should i buy more coolant and do a full flush? Is the above the maximum mark coolant level in the coolant reservoir abnormal? My engine temps dont seem to have any issue. If coolant has not been change since day1 then yes you should drain and fill. If you know where the stop cock is it is easy. Do it when cold. Get a container to catch the used coolant and pour it into a bottle for disposal. But 2 bottle of 4L premix. Should be enough. else just let workshop do Edited November 20, 2022 by Mkl22 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 20, 2022 Author Share November 20, 2022 (edited) 6 minutes ago, Mkl22 said: If coolant has not been change since day1 then yes you should drain and fill. If you know where the stop cock is it is easy. Do it when cold. Get a container to catch the used coolant and pour it into a bottle for disposal. But 2 bottle of 4L premix. Should be enough. else just let workshop do Honestly can't remember when i last changed. maybe when it was serviced with kah motors, but pretty sure not since i started servicing outside from 60k onwards. I have the 2L bottle. If i buy a totachi 4L bottle (cheapest online at $20 inclusive of shipping), then i think 6L maybe enough. I know for some older civics it's about 4.7L for a full flush. But there's no information on how much is required in the owner's manual. Quite bohua to buy another 8L of coolant. I'm puzzled why they say its low condition, when there is excess coolant in the reservoir tank. Edited November 20, 2022 by Lala81 Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 20, 2022 Share November 20, 2022 my previous car did this too in the beginning I find it is counterintuitive that the coolant level rise when the engine is cold but I have my own theory when the engine is hot/warm, the rubber hoses of the cooling system soften and balloon if you fill the coolant to the correct level when it is warm after cooling down, the rubber hoses shrink back to the original sizes and reducing the total volume that will push the coolant level up 4 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 20, 2022 Author Share November 20, 2022 5 minutes ago, Gnahp said: my previous car did this too in the beginning I find it is counterintuitive that the coolant level rise when the engine is cold but I have my own theory when the engine is hot/warm, the rubber hoses of the cooling system soften and balloon if you fill the coolant to the correct level when it is warm after cooling down, the rubber hoses shrink back to the original sizes and reducing the total volume that will push the coolant level up wah haha that makes a lot of sense. Especially the mechanics are probably doing it with an at least a warm engine bay. Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 20, 2022 Share November 20, 2022 16 minutes ago, Lala81 said: I'm puzzled why they say its low condition, when there is excess coolant in the reservoir tank. do you meant your radiator coolant level is low but the reservoir tank level is ok? if that is the case likely the pressure cap of the radiator need replacement (I assume your cooling system is those typical Japanese/Korean setup with pressure cap on the radiator and non pressurised expansion tank) a working cap will allow the coolant to suck back from the expansion tank when the engine is cooling down a defective cap will suck air instead of coolant, sometimes could be an air leakage of the small rubber hose between the radiator cap neck and the expansion tank overtime, the coolant level in the radiator will drop but the expansion tank level stays the same 6 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 20, 2022 Author Share November 20, 2022 (edited) 24 minutes ago, Gnahp said: do you meant your radiator coolant level is low but the reservoir tank level is ok? if that is the case likely the pressure cap of the radiator need replacement (I assume your cooling system is those typical Japanese/Korean setup with pressure cap on the radiator and non pressurised expansion tank) a working cap will allow the coolant to suck back from the expansion tank when the engine is cooling down a defective cap will suck air instead of coolant, sometimes could be an air leakage of the small rubber hose between the radiator cap neck and the expansion tank overtime, the coolant level in the radiator will drop but the expansion tank level stays the same I have no idea. The "low condition" is quoted by the workshop. Maybe every 30k, they will always recommend that. Though my last service was at 89k. Right now I'm around 106k. I can still see the fluid level below my radiator cap. seems ok? Thanks for the diagram, so that's how the cap works. Edited November 20, 2022 by Lala81 Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 20, 2022 Share November 20, 2022 2 minutes ago, Lala81 said: I have no idea. The "low condition" is quoted by the workshop. Maybe every 30k, they will always recommend that. Though my last service was at 89k. Right now I'm around 106k. I can still see the fluid level below my radiator cap. seems ok? Thanks for the diagram, so that's how the cap works. for me, a working cap will show coolant level to the brim when I open it like this if it isn't, I will replace the cap first, it is cheap yes, the cap is a spring loaded valve when engine warm up coolant expand and pressure build up the extra volume will flow into the expansion tank and store temporary when the engine cools down, the extra coolant stored in the expansion tank will get suck back to the cooling system maintaining a closed system without air 6 Link to post Share on other sites More sharing options...
Mkl22 Supersonic November 20, 2022 Share November 20, 2022 49 minutes ago, Lala81 said: I have no idea. The "low condition" is quoted by the workshop. Maybe every 30k, they will always recommend that. Though my last service was at 89k. Right now I'm around 106k. I can still see the fluid level below my radiator cap. seems ok? Thanks for the diagram, so that's how the cap works. If you can see the fluid, like the picture @Gnahp posted then it’s fine. workshop pulling a fast one on you if they say it’s low. hate such workshops. 1 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 20, 2022 Author Share November 20, 2022 Hmm so you are saying with a higher than max level in the reservoir, it's more likely there's too much air in the system (being introduced by a leaky cap) rather than coolant being lost or evaporated? 38 minutes ago, Gnahp said: for me, a working cap will show coolant level to the brim when I open it like this if it isn't, I will replace the cap first, it is cheap yes, the cap is a spring loaded valve when engine warm up coolant expand and pressure build up the extra volume will flow into the expansion tank and store temporary when the engine cools down, the extra coolant stored in the expansion tank will get suck back to the cooling system maintaining a closed system without air Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 20, 2022 Author Share November 20, 2022 (edited) 1 minute ago, Mkl22 said: If you can see the fluid, like the picture @Gnahp posted then it’s fine. workshop pulling a fast one on you if they say it’s low. hate such workshops. I can see it but not as high. I'm going overseas tomorrow so i don't think i have time to take a picture tomorrow am after my engine cools overnight cos I'm working today. Edited November 20, 2022 by Lala81 Link to post Share on other sites More sharing options...
Gnahp Turbocharged November 20, 2022 Share November 20, 2022 1 minute ago, Lala81 said: Hmm so you are saying with a higher than max level in the reservoir, it's more likely there's too much air in the system (being introduced by a leaky cap) rather than coolant being lost or evaporated? that is also another possibility don't want to confuse you first with air in the cooling system 😁 air trapped in the cooling system can do all kind of funny things to the coolant level I also surrender now as long as I see coolant level between MIN and MAX I won't think and analyse too much 2 Link to post Share on other sites More sharing options...
zipping Supersonic November 20, 2022 Share November 20, 2022 (edited) https://oils-finder.com/index.php?model_code=accord13 Anyway, had an previous car, drove for 10 yrs, nvr chg coolent b4, oni do topups w distilled water. Edited November 20, 2022 by zipping 3 Link to post Share on other sites More sharing options...
Fitvip Supersonic November 20, 2022 Share November 20, 2022 The coolant level should be at the brim when the cap is opened. When the cooling system is not functioning optimally, the coolant will be expelled through the pressure cap into the reservoir. When the temperature drops, the engine will suck back the expelled coolant from the reservoir. So, it is not necessary to fill the reservoir to the brim, giving space for the expelled liquid from the engine. It is a to and fro process. Unless too much coolant is expelled to the reservoir causing it to overflow, there will always be enough coolant for the engine. Cooling system will malfunction when rust choke up the tubes or when the fan is not in order and the heat is not dispelled efficiently. I have never changed the my coolant. Link to post Share on other sites More sharing options...
Ct3833 Supersonic November 20, 2022 Share November 20, 2022 If your reservoir is full but radiator is not, just replace the radiator cap, it should solve your problem. 4 Link to post Share on other sites More sharing options...
Lala81 Hypersonic November 20, 2022 Author Share November 20, 2022 are all reservoir caps one size fit all? Link to post Share on other sites More sharing options...
Inlinefour Twincharged November 20, 2022 Share November 20, 2022 AD told me to top up distilled water I drink the whole bottle don’t know correctly done 🥹 1 Link to post Share on other sites More sharing options...
Beregond Supersonic November 20, 2022 Share November 20, 2022 3 hours ago, Lala81 said: Just wanted to ask some general questions about coolant. My car almost 8 years old liao. Was told on my last servicing that coolant was "low condition", required $60 to change. I declined as i already spent some money on changing brake fluid and also replacing my fan/serpentine belt which they said was cracked. Servicing manual says change coolant every 30k. Car is being serviced once a year. I thought it was just a simple top up like washer fluid or what. I didn't look inside the engine bay. So i bought a 2L coolant bottle on 11.11 to "top up". I also watched some youtube videos, so i do know how to release the spigot valve at the bottom of the radiator for my model. To do a full change would probably require somewhere in the level of at least a a couple more litres. Hmm today morning went to take a look when my engine was cold, but the coolant in the reservoir tank is actually above the maximum mark. Then open radiator cap is u can see the fluid level but i know there's no marking inside. So should i buy more coolant and do a full flush? Is the above the maximum mark coolant level in the coolant reservoir abnormal? My engine temps dont seem to have any issue. I dun recommend u to drain out the radiator from the btm. Its easy to drain and top up. But some time air pockets go in and etc and the thermostat cannot open. It might cause problem that might be beyond your expertise. Change every 30k is too wasteful. More like every 100k. As long as the coolant stoll got colour and at the max mark. Dun need bother about it. If its below the min mark. Just buy same colour and top up. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Coolant level going down
Car repair and maintenance
Ho Hup Seng......Some good info for our Brudders
Maintenance Tips For Beginners/First Time Car Owners
Teana repair/parts
Teana repair/parts
