ER-3682 Supersonic June 27 Share June 27 On 6/27/2026 at 5:48 PM, Gnahp said: it's normal, as long as it doesn't get worse and stay consistent those pin hole and evaporative leaks are hard to detect and not worth the troubles to trace a lot of people will tell you their car never consume coolant (same for engine oil) that's because workshop top up for them until you ownself check and replenish the coolant you will know the level will drop over time I keep a record on how much coolant my wife's car consumes so far stable at 650ml / 10,000km You took your Wife's Cake Making Jar & put Coolant inside.?Later She thought Strawberry Syrup,add into the Cake Mix & Bake for you to eat.!!!🤣😩😅 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 27 Share June 27 On 6/27/2026 at 8:18 PM, ER-3682 said: @Gnahp If still Cold just leave it...i done at CAS Garage[90901222] in Kaki Bukit Auto Point.. thanks 👍 not as cold comparing when it was new don't think I can siam topping up gas till I dump it 2 years later Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 27 Share June 27 On 6/27/2026 at 8:21 PM, ER-3682 said: You took your Wife's Cake Making Jar & put Coolant inside.?Later She thought Strawberry Syrup,add into the Cake Mix & Bake for you to eat.!!!🤣😩😅 hello, I am the one who bake at home ok... 1 2 Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 27 Share June 27 On 6/27/2026 at 8:26 PM, Gnahp said: thanks 👍 not as cold comparing when it was new don't think I can siam topping up gas till I dump it 2 years later What Temperature usually our Wife set.?22c or lower.?Fan Speed at ''Auto''.? Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 27 Share June 27 On 6/27/2026 at 8:33 PM, ER-3682 said: What Temperature usually our Wife set.?22c or lower.?Fan Speed at ''Auto''.? temperature setting wife 24c me 23c fan speed wife 3 out of 7 me 4 out of 7 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 27 Share June 27 On 6/27/2026 at 8:21 PM, ER-3682 said: You took your Wife's Cake Making Jar & put Coolant inside.?Later She thought Strawberry Syrup,add into the Cake Mix & Bake for you to eat.!!!🤣😩😅 That's so cool a cake no? 😅 Link to post Share on other sites More sharing options...
mersaylee Hypersonic June 27 Share June 27 On 6/27/2026 at 8:30 PM, Gnahp said: hello, I am the one who bake at home ok... No no no...we put the dough in and it becums a bun in the oven...tink birds and bees...it takes two...✌️😁 2 Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 27 Share June 27 On 6/27/2026 at 8:36 PM, Gnahp said: temperature setting wife 24c me 23c fan speed wife 3 out of 7 me 4 out of 7 Then MaSeeLee's Aircon is Colder..mine set 22°c..leave the Fan at Auto..just average cooling,but Camry & Vezel set at 24°c very Cold.. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic June 27 Share June 27 On 6/27/2026 at 9:08 PM, ER-3682 said: Then MaSeeLee's Aircon is Colder..mine set 22°c..leave the Fan at Auto..just average cooling,but Camry & Vezel set at 24°c very Cold.. Means thermostats kaput! 24 means output must be 24, not very cold means good! 2 Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 27 Share June 27 @Volvobrick Most Toyota & Honda's Aircon are like this,i saw Altis's Aircon,alot set at 25..Windows misted up.! 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 28 Share June 28 (edited) On 6/27/2026 at 7:31 PM, ER-3682 said: @Gnahp sidekick a bit,Today just topped up my Aircon Gas,Mechanic said slightly below something pressure "200"..topped up to "225"..now is alright,He said over 7 Years top up a bit should be "Normal". Yes normal. 100% will have some losses over the years. so many joints in the car. 8-10, plus their O Rings, Plus vibration. I would say usually you will not feel this 25 diff. But sometimes you can hear a slight hiss. It’s during only idling on a hot day can you detect the Aircon is not as cold. Once moving and higher rpm it’s about same for such a small diff. Edited June 28 by Mkl22 2 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 28 Share June 28 On 6/27/2026 at 8:26 PM, Gnahp said: thanks 👍 not as cold comparing when it was new don't think I can siam topping up gas till I dump it 2 years later L&kim $20 for top up. 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 28 Share June 28 @Mkl22 We must have a Honest Workshop & Mechanic,if We kena those Greedy Workshops[PML also 1 of Them] & Car Owners don't know anything,they sure ''Chop'' the Customers,telling them 7 Years ++,Cooling Coil slight Leak,Compressor not at 100% or other issue..💸💸😅 3 Link to post Share on other sites More sharing options...
Mkl22 Supersonic June 28 Share June 28 On 6/28/2026 at 11:20 AM, ER-3682 said: @Mkl22 We must have a Honest Workshop & Mechanic,if We kena those Greedy Workshops[PML also 1 of Them] & Car Owners don't know anything,they sure ''Chop'' the Customers,telling them 7 Years ++,Cooling Coil slight Leak,Compressor not at 100% or other issue..💸💸😅 Just to clarify with regards to home aircon and fridge. for home Aircon there are also joints. But these are compression fit. No O rings. Very very small and minute leak over maybe 10years or more. for fridge. No joints. All joints are brazed on. Plus the compressor is hermetically sealed. So zero leaks. 3 Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 28 Share June 28 On 6/28/2026 at 11:20 AM, ER-3682 said: @Mkl22 We must have a Honest Workshop & Mechanic,if We kena those Greedy Workshops[PML also 1 of Them] & Car Owners don't know anything,they sure ''Chop'' the Customers,telling them 7 Years ++,Cooling Coil slight Leak,Compressor not at 100% or other issue..💸💸😅 that is why I like to go to those "word of mouth" shops with positive (or no negative) experience from the members here especially for things (i.e. aircon) that I am not familiar with don't want to go for a simple $12 hair cut and walk out signing $4k package 😅 2 Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 28 Share June 28 (edited) @Gnahp Little India,Indian Barber only $8.00..No using NETS,Paynow or Credit Card for payment,you won't get "Chop" $4,000.00 Package there. Edited June 28 by ER-3682 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic June 28 Share June 28 Actually @Gnahpcan afford so many Tools for your Car,you should buy some Hair Cutting & Trimming Tools for your Wife to try on your Head,can save $12.00 a Month...also can save Carpark & Petrol Money going to the Hairdresser. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged June 28 Share June 28 On 6/28/2026 at 2:32 PM, ER-3682 said: Actually @Gnahpcan afford so many Tools for your Car,you should buy some Hair Cutting & Trimming Tools for your Wife to try on your Head,can save $12.00 a Month...also can save Carpark & Petrol Money going to the Hairdresser. I have this for a long time very useful during covid, as I didn't meet the vaccination requirement, I was not allowed to enter malls and barber shops I used it to cut botak during covid and cut my son botak before and during his NS for my monthly haircut, I just pay $12 lah, looks nicer than botak 😅 ↡ Advertisement 3 Link to post Share on other sites More sharing options...
Car repair and maintenance
Coolant level going down
Ho Hup Seng......Some good info for our Brudders
