boonhat_91 6th Gear May 24, 2024 Share May 24, 2024 Today no CEL 🙃 don't know should I feel happy or not ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Gnahp Turbocharged May 24, 2024 Author Share May 24, 2024 On 5/24/2024 at 4:48 PM, boonhat_91 said: Today no CEL 🙃 don't know should I feel happy or not for some faults the car won't show CEL the moment it detected one they are programmed to wait and see if the same fault repeats again i.e. for x numbers of time in x numbers of hour then only turn on that dreaded CEL 😁 1 Link to post Share on other sites More sharing options...
Unfazed 6th Gear May 24, 2024 Share May 24, 2024 On 5/24/2024 at 3:27 PM, t0y0ta said: Means some obscure or double COE-renewed car. Noticed you don't wanna share your car make/model Then LLST live with it or scrap Ssshhssss..... It's just karma at work lah. 😁 Link to post Share on other sites More sharing options...
Comage 5th Gear May 24, 2024 Share May 24, 2024 On 5/24/2024 at 5:17 PM, Unfazed said: Ssshhssss..... It's just karma at work lah. 😁 You're right - it's karma. I very well deserve it. I shall f-off and not be a bane to society. Thanks for your constant reminders of what an a**hole I am! 1 Link to post Share on other sites More sharing options...
Fcw75 Hypersonic May 24, 2024 Share May 24, 2024 得饶人处且饶人。 1 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 24, 2024 Share May 24, 2024 On 5/24/2024 at 2:28 PM, Comage said: The ones online are all Chinese-made... It's the clutch that has gone bad and is wobbling upon engine starting up. Stockist told me EOL - not in production anymore. Chinese made still can try. At least it’s new. Not all Chinese stuff is shit. 1 Link to post Share on other sites More sharing options...
Volvobrick Hypersonic May 24, 2024 Share May 24, 2024 On 5/24/2024 at 4:48 PM, boonhat_91 said: Today no CEL 🙃 don't know should I feel happy or not CDL bulb blown already. No need to worry any more. 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear May 29, 2024 Share May 29, 2024 IMHO. Not sure if it has been discussed before - changing of EO, hot or cold ? Thinking of getting those 12V oil extractor. Cold, takes longer. 🤣 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged May 30, 2024 Share May 30, 2024 On 5/30/2024 at 7:58 AM, Kklee said: IMHO. Not sure if it has been discussed before - changing of EO, hot or cold ? Thinking of getting those 12V oil extractor. Cold, takes longer. 🤣 Unless you are DIY in your own carpark or porch, otherwise you can't avoid it being warm as you need to drive to workshop. Oil extractor is the type that stick into your oil stick tube and suck out the existing EO? I would really prefer the traditional bottom oil pan release method, if you think about it - you will anyway need to jack up to access and change the oil filter. 1 Link to post Share on other sites More sharing options...
Beregond Supersonic May 30, 2024 Share May 30, 2024 On 5/30/2024 at 7:58 AM, Kklee said: IMHO. Not sure if it has been discussed before - changing of EO, hot or cold ? Thinking of getting those 12V oil extractor. Cold, takes longer. 🤣 No different. But if can most prefer to do it cold. To avoid being burn. Not only the oil is hot. The engine compartment, if u need to reach inside can burn the arm easily. 2 Link to post Share on other sites More sharing options...
Gnahp Turbocharged May 30, 2024 Author Share May 30, 2024 On 5/30/2024 at 7:58 AM, Kklee said: IMHO. Not sure if it has been discussed before - changing of EO, hot or cold ? Thinking of getting those 12V oil extractor. Cold, takes longer. 🤣 last time I use manual vacuum oil extractor sucking from dipstick tube for 5W40, overnight cold oil will be much slower to suck out usually I will wait for 1 hour after I switch off the engine, warm enough to flow easily but not hot enough to burn my hand 4 Link to post Share on other sites More sharing options...
Mkl22 Supersonic May 30, 2024 Share May 30, 2024 Yes agreed. Warm oil. With cold oil, the bloody 12v will buzz so damn long to extract. my solution is to use fumoto valve. Easy and more simple. Don’t need to bother with keeping the extractor. Can let the cold hot warm oil slowly drip while you have a kopi. 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear May 30, 2024 Share May 30, 2024 On 5/30/2024 at 9:11 AM, t0y0ta said: Unless you are DIY in your own carpark or porch, otherwise you can't avoid it being warm as you need to drive to workshop. Oil extractor is the type that stick into your oil stick tube and suck out the existing EO? I would really prefer the traditional bottom oil pan release method, if you think about it - you will anyway need to jack up to access and change the oil filter. IMHO. Yes, DIY and it is those drain from the dipstick hole. I just need to change EO at 5k, skipping the filter because it is too unsafe unless I get proper equipment i.e. floor jack and jack stands. Floor jack I still have to think how to do maintenance service. 🤣 1 Link to post Share on other sites More sharing options...
Kklee 6th Gear May 30, 2024 Share May 30, 2024 On 5/30/2024 at 11:39 PM, Gnahp said: last time I use manual vacuum oil extractor sucking from dipstick tube for 5W40, overnight cold oil will be much slower to suck out usually I will wait for 1 hour after I switch off the engine, warm enough to flow easily but not hot enough to burn my hand On 5/31/2024 at 7:40 AM, Mkl22 said: Yes agreed. Warm oil. With cold oil, the bloody 12v will buzz so damn long to extract. my solution is to use fumoto valve. Easy and more simple. Don’t need to bother with keeping the extractor. Can let the cold hot warm oil slowly drip while you have a kopi. IMHO. I was looked at some Youtube, cold oil will bzzzzzzzz for 30 mins it seems. 🤣 Maybe after warranty will do the fumoto valve. My hybrid, the coolant and oil temp is not high, usually below 90°C. Maybe warm up a few minutes to let coolant rise to 50++ °C. 🤔 2 Link to post Share on other sites More sharing options...
Kklee 6th Gear May 31, 2024 Share May 31, 2024 IMHO. I checked with one freelance mechanic in my area - $70. 🤔 Link to post Share on other sites More sharing options...
Gnahp Turbocharged May 31, 2024 Author Share May 31, 2024 On 5/31/2024 at 7:52 AM, Kklee said: IMHO. I was looked at some Youtube, cold oil will bzzzzzzzz for 30 mins it seems. 🤣 Maybe after warranty will do the fumoto valve. My hybrid, the coolant and oil temp is not high, usually below 90°C. Maybe warm up a few minutes to let coolant rise to 50++ °C. 🤔 besides oil viscosity and temperature, the orifice size also affects the flow rate if you drain via the sump drain plug hole, very little different between cold/warm/hot oil as the hole is big enough fumoto and the similar valve will have a smaller orifice size comparing to the drain plug hole, it will slow down the flow also, our ambient temperature is close to 30C, some angmo suggest and insist to warm the engine before drain while they are typing the reply from a freezing room/garage 🤭 when you pour fresh engine oil from the bottle, how thick it can be? 3 Link to post Share on other sites More sharing options...
Kklee 6th Gear May 31, 2024 Share May 31, 2024 On 5/31/2024 at 8:21 AM, Gnahp said: besides oil viscosity and temperature, the orifice size also affects the flow rate if you drain via the sump drain plug hole, very little different between cold/warm/hot oil as the hole is big enough fumoto and the similar valve will have a smaller orifice size comparing to the drain plug hole, it will slow down the flow also, our ambient temperature is close to 30C, some angmo suggest and insist to warm the engine before drain while they are typing the reply from a freezing room/garage 🤭 when you pour fresh engine oil from the bottle, how thick it can be? IMHO. I think this challenge only occurs if drain engine oil from the top. I see Youtube, warm/hot engine oil, 5 mins only. 🤣 My experience from previous ICE, thickness varies. EO will thin and then thicken and then thin. Usually I will be in the thicken zone. For that vehicle, UOA suggest to me the EO will last between 7000-8000km. So 5000 km change will make sense. I use to do it usually manual pump. Now I want to "automate" and save time. 🤣 2 1 Link to post Share on other sites More sharing options...
t0y0ta Supercharged May 31, 2024 Share May 31, 2024 On 5/31/2024 at 8:54 AM, Kklee said: IMHO. I think this challenge only occurs if drain engine oil from the top. I see Youtube, warm/hot engine oil, 5 mins only. 🤣 My experience from previous ICE, thickness varies. EO will thin and then thicken and then thin. Usually I will be in the thicken zone. For that vehicle, UOA suggest to me the EO will last between 7000-8000km. So 5000 km change will make sense. I use to do it usually manual pump. Now I want to "automate" and save time. 🤣 I just spend 100+ every 8k km on an oil+filter change at a simple workshop. They can along the way also do FOC things like rotate tyres and do undercarriage check. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Where do you do your servicing/repair/tyre change?
