Jamesc Hypersonic September 25, 2023 Share September 25, 2023 On 9/24/2023 at 9:51 PM, Macrosszero said: Or Jamesc I am sending MIL's car there now. I won't be complaining when he rubs his oily fingers on her brake disc and spray on oily wheel and tyre shine straight onto the disc. Actually I will f him upside down so he cuts the brake hose too! Must remember to keep workshop receipt for the polis. Now where did I keep MIL's 1 million dollar policy. ↡ Advertisement Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 25, 2023 Share September 25, 2023 (edited) Changing oil is not a difficult process. Unscrew nut and let oil drain - must remember to put back nut or happy happy pour new oil in and straight onto shoes! Also put a big pan for oil to drain out or get a head shower of oil. Remove oil filter - must remember to put a new filter in. Pour new oil in - don't just pour the whole friggin can in and overfill. Amazing how often they overfill! Pro tip if using own oil and sump 3.3 litres just give them 3 litres. Go home and top up yourself. Easier to top up 0.3 litres than trying to drain out excess. Changing spark plug is the most dangerous. Watch out for monkey with wrench jamming in the spark plug and cross threading it! Replacing tyres watch if they forget to tighten. My car has 4 wheels and 5 nuts so that 20 nuts to put back, screw up to 95% and then tighten up the last 5% for 20 nuts. Possible to screw up the 20 nuts but only tighten 17 as lost count because tighten up 3 nuts twice. If you notice they never tighten in sequence just randomly do, so possible they tighten some twice and never tighten up other. Anyway easy mistake to spot. You are driving on the PIE and your tyre overtakes you. Edited September 25, 2023 by Jamesc 2 Link to post Share on other sites More sharing options...
stan_lee Clutched September 25, 2023 Share September 25, 2023 How you dispose the old EO when you DIY? 2 Link to post Share on other sites More sharing options...
t0y0ta Supercharged September 25, 2023 Share September 25, 2023 On 9/24/2023 at 2:26 PM, Gnahp said: I DIY oil change for the past 18 years, except the period when the car is under warranty recently I thought I don't want to get my hands dirty so I send the car to workshop for oil change 1st oil change no drama 2nd oil change, at the same workshop - told them I want grade X before passing them the key, went to the rack and pointed them the oil, at the end found out they pour in grade Y - removed both my aircon filters, telling me they are dirty, I told them I just change it, in the end they fix it back, totally unnecessary - top up my coolant reservoir with tap water, I keep my coolant level at the correct level, now they overfilled it, with tap water some more, I have to extract the excess out - asked me to pour in engine oil additive, petrol additive, I said no thanks, I just want to change the oil and oil filter - the last straw (tree trunk actually), after washing/vacuum the car, bill settled, I opened the bonnet to have a quick check before leaving, found out the intake pipe was missing, it was still on the tool cart of the mechanic who serviced my car the oil filter is underneath the cold air intake pipe, need to remove to access the oil filter You never eyeball the process? In my previous WS, I just hang around the vehicle and watch as they do the servicing... also can ask them some questions when things seem to go wrong. Even if nearby got coffeeshop to relax. Usually no funny things will happen because you will physically catch it. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged September 25, 2023 Author Share September 25, 2023 On 9/25/2023 at 11:32 AM, stan_lee said: How you dispose the old EO when you DIY? bring the waste oil to workshop and pour into their waste oil drum 3 Link to post Share on other sites More sharing options...
Gnahp Turbocharged September 25, 2023 Author Share September 25, 2023 On 9/25/2023 at 11:34 AM, t0y0ta said: You never eyeball the process? In my previous WS, I just hang around the vehicle and watch as they do the servicing... also can ask them some questions when things seem to go wrong. Even if nearby got coffeeshop to relax. Usually no funny things will happen because you will physically catch it. I don't want to do that lah it is like you know how to cook curry fish head decided to have it in restaurant but hang around in the kitchen to eyeball the chef when he cooks not very nice leh might as well I cook at home 1 6 Link to post Share on other sites More sharing options...
Lethalstrike Turbocharged September 25, 2023 Share September 25, 2023 On 9/24/2023 at 2:26 PM, Gnahp said: I DIY oil change for the past 18 years, except the period when the car is under warranty recently I thought I don't want to get my hands dirty so I send the car to workshop for oil change 1st oil change no drama 2nd oil change, at the same workshop - told them I want grade X before passing them the key, went to the rack and pointed them the oil, at the end found out they pour in grade Y - removed both my aircon filters, telling me they are dirty, I told them I just change it, in the end they fix it back, totally unnecessary - top up my coolant reservoir with tap water, I keep my coolant level at the correct level, now they overfilled it, with tap water some more, I have to extract the excess out - asked me to pour in engine oil additive, petrol additive, I said no thanks, I just want to change the oil and oil filter - the last straw (tree trunk actually), after washing/vacuum the car, bill settled, I opened the bonnet to have a quick check before leaving, found out the intake pipe was missing, it was still on the tool cart of the mechanic who serviced my car the oil filter is underneath the cold air intake pipe, need to remove to access the oil filter Actually the mechanic was giving your car a free boost, by modding your car's stock intake to open CAI (Cold Air Intake) 🤣 6 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator September 25, 2023 Share September 25, 2023 truth to be told, I usually hang around the workshop during my servicing to make sure the mechanic does his work properly. hahahaha. I also cannot tahan such standard. Link to post Share on other sites More sharing options...
Tohto Hypersonic September 25, 2023 Share September 25, 2023 On 9/24/2023 at 2:26 PM, Gnahp said: I DIY oil change for the past 18 years, except the period when the car is under warranty recently I thought I don't want to get my hands dirty so I send the car to workshop for oil change 1st oil change no drama 2nd oil change, at the same workshop - told them I want grade X before passing them the key, went to the rack and pointed them the oil, at the end found out they pour in grade Y - removed both my aircon filters, telling me they are dirty, I told them I just change it, in the end they fix it back, totally unnecessary - top up my coolant reservoir with tap water, I keep my coolant level at the correct level, now they overfilled it, with tap water some more, I have to extract the excess out - asked me to pour in engine oil additive, petrol additive, I said no thanks, I just want to change the oil and oil filter - the last straw (tree trunk actually), after washing/vacuum the car, bill settled, I opened the bonnet to have a quick check before leaving, found out the intake pipe was missing, it was still on the tool cart of the mechanic who serviced my car the oil filter is underneath the cold air intake pipe, need to remove to access the oil filter What WS is that? Do share.. 1 Link to post Share on other sites More sharing options...
Gnahp Turbocharged September 25, 2023 Author Share September 25, 2023 On 9/25/2023 at 4:45 PM, Tohto said: What WS is that? Do share.. this can happen at any workshop it was not my intention to expose the workshop just sharing what can go wrong when you send your car for servicing/repair 😁 3 Link to post Share on other sites More sharing options...
alphapunk2 1st Gear September 25, 2023 Share September 25, 2023 i'm gonna send my car for major servicing soon, ATF, engine oil, brake fluid, etc. i'll just stick around and ask to watch cause i'm genuinely curious on how these things are done. 1 Link to post Share on other sites More sharing options...
Ingenius Turbocharged September 26, 2023 Share September 26, 2023 If you cannot trust the workshop to do the job right, then you shouldn't send your car there in the first place. 1 Link to post Share on other sites More sharing options...
Unfazed 6th Gear September 26, 2023 Share September 26, 2023 (edited) On 9/26/2023 at 9:26 AM, Ingenius said: If you cannot trust the workshop to do the job right, then you shouldn't send your car there in the first place. Cock...read...that's the subsequent time TS had sent the car! Obviously when prior experience was ok?! You ate nice food at ABC stall but find food not so nice the 2nd time you went, and someone tell you same thing, if you not even sure food there nice, you shouldn't eat there in the first place? How you feel? Song bo? Edited September 26, 2023 by Unfazed 2 Link to post Share on other sites More sharing options...
AndrewLee72 6th Gear September 26, 2023 Share September 26, 2023 Another option is chose those workshop that allows you to sit near the work area - eg : got 1 glass window allow customer to view thro to see car work area. I always go to 1 that allow customer to sit near the work area and if need be just walk to my car and tok cock with mechanic (at sametime can see what he do) ! You know what i mean.. haha. Link to post Share on other sites More sharing options...
Hamburger Hypersonic September 26, 2023 Share September 26, 2023 my backyard workshop has no qualm with me looking on when they work. Thats because i have to instruct them how it should be done properly. Eg. changing of ATF fluid and with where to pump in the new ATF and to check for level using the overflow nut. 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 26, 2023 Share September 26, 2023 All the pro workshops seal off the area for servicing so owners cannot see the cock ups! Aiyoh only the amateurs let owners know what a bad job they do! The real pros even disable your cameras so that you cannot see them blasting you nice hifi or blasting your aircon or driving around the workshop at full speed like F1 cars going around the track. The only time you will find out is when they smashed it! 1 Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 26, 2023 Share September 26, 2023 Sometimes if you leave your car there and come back to pick it up its not there. They have taken it for a "test drive" probably picking up their kids from school or something. My cousins told me this happens in MY a lot. Link to post Share on other sites More sharing options...
Jamesc Hypersonic September 26, 2023 Share September 26, 2023 Buy new car first 3 service by them to keep warranty. So no choice but to service with the AD. So don't want to go also cannot! ↡ Advertisement Link to post Share on other sites More sharing options...
Where do you do your servicing/repair/tyre change?
