Johnwalk 1st Gear July 10 Share July 10 Just bought a 2nd hand car and after 3days engine light light up. Went back to dealer and he ask me to drive to below workshop and check is catalyst error code. He doesn't want to fix for me saying it is wear and tear part. What should I do? If bypass it, will it pass inspection? ↡ Advertisement Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 10 Share July 10 By Pass,comfirmed Fail Inspection,caught by LTA on the Road,comfirmed get Fine.[Easy to Detect,as the Exhaust Gases very Toxic & Smelly]...just change a new one,blame on own Bad Luck for getting a Lemon. 4 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 10 Share July 10 Actually, instead of using an extender or spacer to trick the ecu...why not just remove the sensor and wrap it with maybe alum foil or something then put it back in...inspector won't remove it to check if it's wrapped...will just use eye power to look for any bad welding or spacer...🤔 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 On 7/11/2025 at 7:03 AM, mersaylee said: Actually, instead of using an extender or spacer to trick the ecu...why not just remove the sensor and wrap it with maybe alum foil or something then put it back in...inspector won't remove it to check if it's wrapped...will just use eye power to look for any bad welding or spacer...🤔 If Inspection,Emission fail how.?Still need to replace correct.? 3 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 @Johnwalkcan i know,what Make,Model & Age of your Car.? Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 11 Share July 11 On 7/11/2025 at 8:30 AM, ER-3682 said: If Inspection,Emission fail how.?Still need to replace correct.? So long no check light...even with failure in emission probe test...can try to ask for a pass with condition if left with one year to end of coe...🤞😁 1 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator July 11 Share July 11 On 7/11/2025 at 2:21 AM, Johnwalk said: Just bought a 2nd hand car and after 3days engine light light up. Went back to dealer and he ask me to drive to below workshop and check is catalyst error code. He doesn't want to fix for me saying it is wear and tear part. What should I do? If bypass it, will it pass inspection? How long the car left? How much loan did you take up? 1 Link to post Share on other sites More sharing options...
Hamburger Hypersonic July 11 Share July 11 add in a good CC cleaner and take a drive to Melacca and back. Its call clearing of carbon. 1 Link to post Share on other sites More sharing options...
mersaylee Hypersonic July 11 Share July 11 On 7/11/2025 at 10:09 AM, Hamburger said: add in a good CC cleaner and take a drive to Melacca and back. Its call clearing of carbon. It's call pollution if still cannot clear...becos cat mati liao...😂 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 On 7/11/2025 at 10:09 AM, Hamburger said: add in a good CC cleaner and take a drive to Melacca and back. Its call clearing of carbon. Later his Car(if an Old one) breakdown in Mallaysia,cost more to Tow out.🤦♂️ 2 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 11 Share July 11 On 7/11/2025 at 9:43 AM, kobayashiGT said: How long the car left? How much loan did you take up? Huh, not full cash meh? 😃 2 Link to post Share on other sites More sharing options...
Ct3833 Supersonic July 11 Share July 11 On 7/11/2025 at 2:21 AM, Johnwalk said: Just bought a 2nd hand car and after 3days engine light light up. Went back to dealer and he ask me to drive to below workshop and check is catalyst error code. He doesn't want to fix for me saying it is wear and tear part. What should I do? If bypass it, will it pass inspection? Like other bros here are asking, what model and how long more the car is. You can go ask how much is a new converter, alternatively, not sure if there is used one in the market if the car is left a short fre years, can go scrap yards and ask, no loss. If you need scrap yard contact, can post your question here too. Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 TS missing liao. 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 On 7/11/2025 at 9:26 AM, mersaylee said: So long no check light...even with failure in emission probe test...can try to ask for a pass with condition if left with one year to end of coe...🤞😁 Now not so easy,fully Computer,cannot Bribe Inspectors also. 2 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 On 7/11/2025 at 9:43 AM, kobayashiGT said: How long the car left? How much loan did you take up? Could be a 10 Years COE Masarati. 2 Link to post Share on other sites More sharing options...
kobayashiGT Internal Moderator July 11 Share July 11 On 7/11/2025 at 1:24 PM, ER-3682 said: Could be a 10 Years COE Masarati. If left less than 3 years, Just go scrap yard and find a replacement. No need get new lah. tong yi tong, can change new car liao. if TS take loan, he cannot just off load the car, sure lose money. 1 1 Link to post Share on other sites More sharing options...
ER-3682 Supersonic July 11 Share July 11 On 7/11/2025 at 2:40 PM, kobayashiGT said: If left less than 3 years, Just go scrap yard and find a replacement. No need get new lah. tong yi tong, can change new car liao. if TS take loan, he cannot just off load the car, sure lose money. I think is a fresh COE Car. Link to post Share on other sites More sharing options...
Gnahp Turbocharged July 11 Share July 11 On 7/11/2025 at 1:24 PM, ER-3682 said: Could be a 10 Years COE Masarati. Masarati got V engine got two sets of cat 🤭 ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Car repair and maintenance
Drug dealer
Drug dealer
Lee Sheng Auto - One Stop Auto Repair Centre! From accident repair & claims, spray painting, diagnostics, general repairs to servicing.
