nazerath Turbocharged August 13, 2014 Share August 13, 2014 Anyone knows if it is possible to connect an airgun (ref: http://www.westernsafety.com/guardair2008/guardair.html) to a portable pump? If possible, good for cleaning brakes and engine compartment. You will need a compressor So that's what that flat tyre button is for. Then for normal pump air (into a non flat tyre) we should not touch this button, I suppose....? Yes, dun need unless flat. ↡ Advertisement 5 Link to post Share on other sites More sharing options...
Newcell Clutched August 13, 2014 Share August 13, 2014 Not sure those meter same like this? You will need to press the button in order to inflate a flat tyre after preset the pressure2014-08-12-12-29-39_deco.jpg Thank you. Will note which kiosk having this for future needs. Those i went didn't had that xtra button. Not sure those meter same like this? You will need to press the button in order to inflate a flat tyre after preset the pressure2014-08-12-12-29-39_deco.jpg Thank you. Will note which kiosk having this for future needs. Those i went didn't had that xtra button. Link to post Share on other sites More sharing options...
Watwheels Supersonic August 13, 2014 Share August 13, 2014 Wah lao eh, how much money got to spent just to pump air into a tire? Want to get an air dryer to remove the air humidity while you guys are at it? Our air humidity is 80%-90% you know? It's good to invest in an air dryer to remove the moisture in the air. Less moisture means less fluctuation in the air pressure in your tire. LoL... For goodness sake just get a 12V portable and compact pump so that it wouldn't take up space in your trunk. Plus you sweat less dan those hand or leg pump. Link to post Share on other sites More sharing options...
Newcell Clutched August 13, 2014 Share August 13, 2014 Wah lao eh, how much money got to spent just to pump air into a tire? Want to get an air dryer to remove the air humidity while you guys are at it? Our air humidity is 80%-90% you know? It's good to invest in an air dryer to remove the moisture in the air. Less moisture means less fluctuation in the air pressure in your tire. LoL... For goodness sake just get a 12V portable and compact pump so that it wouldn't take up space in your trunk. Plus you sweat less dan those hand or leg pump. Haha i tried 12v pump before, so malu to disturb my neighbour with such noise. It kaput and never want the same again. Link to post Share on other sites More sharing options...
TVT Supercharged August 13, 2014 Share August 13, 2014 Not sure those meter same like this? You will need to press the button in order to inflate a flat tyre after preset the pressure Can anyone tell me what's the last button (1st from right) for ? The one with a "circulating arrow".... Thanks. Link to post Share on other sites More sharing options...
Yeobh 4th Gear August 15, 2014 Share August 15, 2014 Can anyone tell me what's the last button (1st from right) for ? The one with a "circulating arrow".... Thanks. The info taken from PCL ( leading UK maker of tyre inflator for service stations ), hope this helps. Link to post Share on other sites More sharing options...
Ckchong8 1st Gear August 15, 2014 Share August 15, 2014 Haha i tried 12v pump before, so malu to disturb my neighbour with such noise. It kaput and never want the same again. Must get a better brand, I got it from autobac for $30+ serve me well already more then a yr and even can inflate a flat tyre when I patched my puncture twice. Link to post Share on other sites More sharing options...
Newcell Clutched August 16, 2014 Share August 16, 2014 Must get a better brand, I got it from autobac for $30+ serve me well already more then a yr and even can inflate a flat tyre when I patched my puncture twice. If it doesn't fire like AK47, dont mind having. The sound from the pump really attract attention while one try to quickly get the tyre done. Anyway thanks for recommending. :) Link to post Share on other sites More sharing options...
beef331994 Neutral Newbie August 16, 2014 Share August 16, 2014 Must get a better brand, I got it from autobac for $30+ serve me well already more then a yr and even can inflate a flat tyre when I patched my puncture twice. thanks Link to post Share on other sites More sharing options...
Extremme 4th Gear December 6, 2014 Share December 6, 2014 saw these 2 at Autobacs. Anone used it before? Item (1) cost about S$50 plus Item 2 Link to post Share on other sites More sharing options...
Extremme 4th Gear December 7, 2014 Share December 7, 2014 Bought 150PSI bicycle pump at Cash Converter at $12/- for my road bike. 100PSI foot pump version cost a little lesser. For car? Link to post Share on other sites More sharing options...
Extremme 4th Gear December 8, 2014 Share December 8, 2014 Thought if the $30+ is fine then can buy. Save some hand/foot energy lolxx Link to post Share on other sites More sharing options...
Forte3737 5th Gear December 8, 2014 Share December 8, 2014 Made in where? saw these 2 at Autobacs. Anone used it before? Item (1) cost about S$50 plus Item 2 Link to post Share on other sites More sharing options...
Extremme 4th Gear December 8, 2014 Share December 8, 2014 Did not check but looks like Japan since it's all in Japanese Link to post Share on other sites More sharing options...
Neutrino Supercharged December 8, 2014 Share December 8, 2014 TB always with a "manual" one! quite good and easy to use. But to me will go to petrol station everytime. I check my tyre pressure quite regularly and find that it can vary between petrol station and petrol station. Arte petrol station air pumps checked frequently. Disparity may be dangerous. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 8, 2014 Share December 8, 2014 saw these 2 at Autobacs. Anone used it before? Item (1) cost about S$50 plus Item 2 I am using the $36.80 one. Noisy but get the job done. From totally flat tyre to 220kpa in about 5 minutes. Link to post Share on other sites More sharing options...
Extremme 4th Gear December 8, 2014 Share December 8, 2014 I am using the $36.80 one. Noisy but get the job done. From totally flat tyre to 220kpa in about 5 minutes. Nice. Thks for sharing. I travel Alot up north so I want to buy it for emergency since Estima does not come with spare Tyre. Link to post Share on other sites More sharing options...
Fcw75 Hypersonic December 8, 2014 Share December 8, 2014 (edited) Nice. Thks for sharing. I travel Alot up north so I want to buy it for emergency since Estima does not come with spare Tyre.No prob bro. Do u have a tyre repair kit too? Can get this: http://www.amazon.com/gp/product/B000AMOEGY/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 Edited December 8, 2014 by Fcw75 ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Any recommended tyre shop
Tyre puncture
Tyre puncture
Continental CSC 7.
Continental CSC 7.
Tyre Rotation and balancing
