DarkLord 1st Gear May 2, 2004 Share May 2, 2004 But don't practice until your car has to be sent in for service horz? Singapore cars very expensive to "practice" with! Maybe cheaper to find a driving instructor and practise with his car!! HEHE! By the way, anybody ever seen a female driving instructor before?? Any experiences to relate?? ↡ Advertisement Link to post Share on other sites More sharing options...
Bpfocus Neutral Newbie May 3, 2004 Share May 3, 2004 ....you must have done it countless time without knowing it........when you shift down ....at the moment when you clutch out and the gear engages ..... the car actually slows down abit that is when you are on engine brake .......cos ...... the engine which sends power to your wheels via the tranny is now running on a lower gear which operates at a slower speed abeit at a higer power/torque band ......... that's why it is call engine brake ...... oso that's why you normally shift down to overtake ....inorder to access the higher power/torque band .......to ensure optimum acceleration the toe to heel method is used to blip the engine .....to keep up the engine rev while you are stepping on the brake at the same time........so that when you clutch out you lessen or eliminate the engine brake and can smoothly apply power and accelerate away .......... Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "I don't even know" Hi! there, Unknown_G7, If you don't ask, then you'll never know. Rgds Paul Yong Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "cheaper to change brake pads" Hi! there, DarkLord, Most of the time, when I drop gears, not necessary to use brakes. Rgds Paul Yong Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "Yalor," What are you practicing now?? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "and practise with his car!!" Hi! there, DarkLord, If you don't use your own car to practice, then how are you going to know the performance & limits of your car?? Rgds Paul Yong Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 3, 2004 Share May 3, 2004 OIC Thanks Link to post Share on other sites More sharing options...
Unknown_G7 Neutral Newbie May 3, 2004 Share May 3, 2004 Now I know after Bpfocus had explained it Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "you normally shift down to overtake ...." Hi! there, BPFocus, When I was driving a Mondeo, I didn't bother to down-shift. I just turn. Rgds Paul Yong Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "Now I know" Hi! there, Unknown_G7, You still don't know, until someone shows you how it's done. Rgds Paul Yong Link to post Share on other sites More sharing options...
Yansen Neutral Newbie May 3, 2004 Share May 3, 2004 what do u mean by just turn? Link to post Share on other sites More sharing options...
Yansen Neutral Newbie May 3, 2004 Share May 3, 2004 wow u must be the 1st lady ive come across who drives a manual? Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 Hi! there, Yansen, As stated, just turn, as in swing the steering around. Rgds Paul Yong Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 "the 1st lady" Hi! there, Yansen, Many of the lady members here, drives manual. Rgds Paul Yong Link to post Share on other sites More sharing options...
Saaber Neutral Newbie May 3, 2004 Share May 3, 2004 practicing to be a father... Link to post Share on other sites More sharing options...
Bpfocus Neutral Newbie May 3, 2004 Share May 3, 2004 (edited) ....aiyah .....you must be driving an auto mah .......in which case the gear will automatically drop if you keep pressing on the gas to accelerate .......or you oredi at 3rd going up to 4th when overtaking ......... Edited May 3, 2004 by Bpfocus Link to post Share on other sites More sharing options...
DarkLord 1st Gear May 3, 2004 Share May 3, 2004 Heh! I like to do that also! Link to post Share on other sites More sharing options...
Pauly75ts Neutral Newbie May 3, 2004 Share May 3, 2004 I can help you to practice. ↡ Advertisement Link to post Share on other sites More sharing options...
Engine Mounting
Engine Mounting
