Engine brake
Smiley
so you are those who stop at 5th gear at traffic lights. [laugh]
huh? no, my gear will go to neutral even before my car comes to a stop [;)]
oh.........if I stop at traffic light at 5th I must be going at least 100km/h b4 i stop ..... then won't be using engine brake will be using e-brake .....and bet will activate ABS too .......dizzy.gif but seriously when driving manual will shift to 3rd b4 stop rather than be at 4th and brake ..... not a matter of choice right when road speed slows can't expect engine speed to remain high right so have to shift down ....otherwise ....
Edited by Bpfocus
yeap, that is when you hear the loud noise and the car jerk..
Hmm then that's not the right way to engine brake. You should still be using your brakes and not relying entirely on the engine to brake the car. It should be a smooth process and your car shouldn't jerk...
Supersonic
not so drastic down shift lah. it still will. assuming you travelling at 100 then you down shift fm 5th to 4th, the cut also significant.
i've downshifted from 5th to 3rd from abt 100+ to power out of corners. no jerk or engine drama leh.
Edited by Soya
Me still practising to get the perfect engine brake, from 5 - 4 - 3 - stop.
- release acc.
- step brake. (u can feel rev slow down)
- depress clutch while holding brake.
- Change to gear 4.
- slowly release clutch. (If still too fast, step brake more)
- release brake.
then cont to gear 3.
Pls correct me, if this is incorrect... [thumbsup]
when i use it and i hear the engine cuts back, wow, heart ache man. wonder if it is harmful to the car.
its not possible.even if u clutch in liao...your gear box wont allow u to do it.
I also only recenty then found out.
...yes....with a bit of heel and toe and a blip on the throttle as you get the rpm up again.......shiok.nod.gif
- release acc.
- Change to gear 4.
- release brake.
Thats the way a driving school would teach you ... but the heel-to-toe method is taught by Racing Schools
- release acc.
- step brake with the top of your foot (toe).
- depress clutch while holding brake and your right heel shifts over to rev the engine (clutch-in) at the same time.
- drop to 4th or 3rd
- release clutch. (If still too fast, step brake more)
- release brake.
With a higher engine rev on a lower gear ... your car can actually stop much faster than it can without engine brake assistance and also fly out of a corner much faster. tongue.gif
To do the above correctly and successfully , your pedal height has got to be right. As this is not normally practised on family road cars, adjustment is needed with pedal heights and the pedal itself. wink.gif
My pedal is adjusted to conform to a diferent method .... right toe brake whilst outer right revs .... see here http://www.pfyc.com/z06/virfull0303.wmv (about 46 secs and 2mins4sec into the movie). My brake pedal is adjusted to be closer to the accelerator so that this can be done. nod.gif
Edited by Hitman
Control it with your clutch lah .... dont release it immediately , half-clutch it on the downshift ... thumbsup.gif
Maybe can use your brakes to assist in the braking as well... It's cheaper to change brake pads than to change your whole gearbox!
"What's the correct method"
Practice.
Rgds
Paul Yong
