When to use tyre rotation or alignment?
Kelpie
1. I just wonder whether tyres rotation and alignment are done as part of the regular servicing when under warranty? I overheard a SE advising a customer to do rotation as the car has covered X amount of distances.
2. Under what conditions would warrant one of these services? I was told once that if you hit a kerb, rotation is required but why?
3. By the way, is it common for a car to steer slightly towards either side when braking? I gathered earlier than it was due to the road conditions and surfaces. Could poor wheel rotation/alignment cause this problem?
Thank you for your advice.
Regards,
rotate and balancing, every 10,000 recommended, i do every 7500
when hit kerb, rotate and balancing recommended, cos ur rims might be dented (affect balancing), if more dmg, maybe need to do alignment
possible due to tramlining , uneven tyre wear, poor balancing, out of alignment
Reply: Not sure if its part of the servicing package. Recommended to do tyre rotation every 10k km.
Reply: I think it should be alignment instead of rotation, if you hit a kerb.
Reply: Not common to go side ways when braking. Could be due to suspension, alignment or tyre pressure uneven.
unbalance brake...coses tis prob....that is one side more 'jia' than the other side.. [:)]
when u rotate u must balance, if 4wd or 4wd, must balance all 4 wheel
2wd balance the 2 wheels that are for steering
improper balancing will wear out suspension, drive shaft, steering out of alignment, steering wheel vibrate
price is 10-15$, balancing is always foc with rotation
What car u driving that got no independent suspension??? [confused][confused]
Most manufacturers recommend a tire rotation,balancing & alignment( best is 4 wheel computerised alignment) at 10K km.
It's always better to balance ALL 4 wheels together but if u want to save a few $$$, balance only the front 2 as these affect the steering mostly.
If the rear wheels r badly out of balance, your rear suspension will wear out faster. That's why it's better to balance all 4 together.
Computerised 4 wheel alignment is necessary if you did some work on your suspension or steering components( I learnt the hard way). Do it seprately even though the mechanic tells you he already did it after he worked on your suspension/steering components).
Otherwise the normal alignment will do.
there is no such thing as unbalance brake.
all caliper brakes are self adjusted.
rotate, balancing, cleaning of rim plus pump nitrogen is $20.
but nitrogen not recommended.
balance or alignment?
4wd or 2wd also balance all 4 tires.
improper balancing wear out suspension, drive shaft or out of alignment not so likely.
vibrate yes.
normally wont do balancing unless rotating, changing of suspension & tires.
Why not? In Jakarta, pumpng nitrogen is a norm and FOC. Singapore still using normal pump or should I say outdated air pump at petrol stations?
Regards,
Edited by Kelpie
Where can you get this done? Stamford Tyres does rotation, balancing and alignment for $30 (I heard).
bro, if purely just do tyre rotation cost how much ah?
Usually, i do the rotation on my own so as to save some money. I've been DIY for 8 years. However, i will not save for full computerised 4 wheel alignment with those "Hunter" branded machines.
maybe you can share why pumping nitrogen is not recommended. As far as I know, it is lighter and last longer.
can share lobang for $10-$15 balancing with rotation? i quite TL with my last rotation..tx
