teomingern Supercharged January 29, 2017 Share January 29, 2017 Hi All, I am repeatedly encountering the parking brake warning light (Amber) which will not go off (Unless workshop reset the fault code) even after i restart my car on my 2015 Vezel X. This issue was observed when (1) i use my Brake Hold function, or (2) when the CTBA was activated locking the brake. The common observation that caused the parking brake warning light was upon the automatic unhold of the park brake for brake hold and CTBA. I had recently changed a new car battery as suggested by many that could be weak battery issue but it still doesn't solve the problem. Workshop diagnosed the DTC error to be " 58-11 brake diag circuit off failure". Will like to seek assistance if anyone had similar issue and managed to resolve Looks like you just have to replace the whole module that controls the automatic braking function. It appears that the auto hold function of the electronic parking brake, and the auto braking function of the adaptive cruise control are one and the same. Replacing this module will resolve the problem I suppose. It also appears that the sensor that tells the system whether the brakes are currently applied or not is not working (if the brakes remained locked even after you move off) or it might simply the electronic circuit doesn't update the system that the brakes have been released (physically the brakes are released) and hence the system warns you that you haven't released the brakes. If it is the latter, it would seem that the easiest path would be to just replace the whole electronic module, or motherboard. ↡ Advertisement 2 Link to post Share on other sites More sharing options...
Ahqiang83 Clutched January 29, 2017 Share January 29, 2017 Looks like you just have to replace the whole module that controls the automatic braking function. It appears that the auto hold function of the electronic parking brake, and the auto braking function of the adaptive cruise control are one and the same. Replacing this module will resolve the problem I suppose. It also appears that the sensor that tells the system whether the brakes are currently applied or not is not working (if the brakes remained locked even after you move off) or it might simply the electronic circuit doesn't update the system that the brakes have been released (physically the brakes are released) and hence the system warns you that you haven't released the brakes. If it is the latter, it would seem that the easiest path would be to just replace the whole electronic module, or motherboard.Thanks. The break was released and everything works normally except for the warning. 2 Link to post Share on other sites More sharing options...
Titank 1st Gear January 30, 2017 Share January 30, 2017 (edited) Have anyone heard that Honda HRV which have a manual transmission? Obtain a copy of this from one of the PI which claim it is Japan! https://www.dropbox.com/sh/q17v7u6cvth1jpl/AAAF_bcgx79Ab_XoSE08J_nFa?dl=0 Edited January 30, 2017 by Titank 2 Link to post Share on other sites More sharing options...
Woobala 1st Gear January 31, 2017 Share January 31, 2017 Hi all, Have read through quite a fair bit in this Honda Vezel discussion thread and have some questions which I hope someone can provide some advice.. 1) have finally decided on the Honda Vezel 1.5X Sensing over the Kia K3. Are there any recommended P.I in terms of reliability? I see so many P.I with so many pricing schemes which I'm kinda confused. 2) have read that the new models would not have the defects/faults like the BBC, etc. how to verify the model is 2016? am concerned whether the P.I will pass off the 2015 stocks to sell as the new models.. Apologies if the questions sound noobish... Thanks!! 2 Link to post Share on other sites More sharing options...
w7_lee 4th Gear February 1, 2017 Share February 1, 2017 Hi all, Have read through quite a fair bit in this Honda Vezel discussion thread and have some questions which I hope someone can provide some advice.. 1) have finally decided on the Honda Vezel 1.5X Sensing over the Kia K3. Are there any recommended P.I in terms of reliability? I see so many P.I with so many pricing schemes which I'm kinda confused. 2) have read that the new models would not have the defects/faults like the BBC, etc. how to verify the model is 2016? am concerned whether the P.I will pass off the 2015 stocks to sell as the new models.. Apologies if the questions sound noobish... Thanks!! I believe Sensing feature is available only for the (mid/late) 2016 models, so if you get a new Vezel with sensing, hardly possible that it is a 2015 model. If you have the RU number of the specific vehicle, you can check at the Honda Japan website for actual year of manufacturer and recalls. 2 Link to post Share on other sites More sharing options...
LQY 1st Gear February 1, 2017 Share February 1, 2017 Just for laugh Just for laugh 7 Link to post Share on other sites More sharing options...
Woobala 1st Gear February 1, 2017 Share February 1, 2017 I believe Sensing feature is available only for the (mid/late) 2016 models, so if you get a new Vezel with sensing, hardly possible that it is a 2015 model. If you have the RU number of the specific vehicle, you can check at the Honda Japan website for actual year of manufacturer and recalls. I see.. thanks I would like to know more about the reliability of the PIs. A few of my friends gotten their vehicle from Autolink and commented it's good, I've also been checking out Smartcars Boutique. What are your opinions?? Link to post Share on other sites More sharing options...
Stone-Cold 1st Gear February 2, 2017 Share February 2, 2017 (edited) I see.. thanks I would like to know more about the reliability of the PIs. A few of my friends gotten their vehicle from Autolink and commented it's good, I've also been checking out Smartcars Boutique. What are your opinions?? There is a separate thread discussing on this matter. You can check it out whether are the PIs already discussed and will get more input from visitors of other car model also. Do bear in mind that experience shared are based on that specific point of time, no guarantee what will happen when come to your turn. Those 'more reliable' PIs mentioned do not mean '100% reliable'. Anything can happen overnight, e.g. currency fluctuate, rules/regulation changes, company stability, that might affect the delivery and also after sales support down the road. Edited February 2, 2017 by Stone-Cold Link to post Share on other sites More sharing options...
Ahqiang83 Clutched February 3, 2017 Share February 3, 2017 Thanks. The break was released and everything works normally except for the warning.Anyone know of any workshop that resolved this issue? Link to post Share on other sites More sharing options...
Hotsoup Neutral Newbie February 3, 2017 Share February 3, 2017 (edited) My first primary car would be the shuttle hybrid but not many PIs are bringing them in to our shore. Alternatively , I am looking at Vezel hybrid if LL can't get shuttle Been trying to go thru he long threads and I still can't find what I required for vezel' parts such as recommended approved exhaust, coliver and air filter system Any kind bros to advice on my queries? Thank you in advance Edited February 3, 2017 by Hotsoup Link to post Share on other sites More sharing options...
Kopites Supersonic February 3, 2017 Share February 3, 2017 (edited) I just realised our wiper very smart. At Intermittent level I adjusted to the fastest speed. It would as expected up/down..without intermittent break. However when car come to a complete stop at junction..It would give an intermittent break. I reckon 2/3 second. Edited February 3, 2017 by Kopites Link to post Share on other sites More sharing options...
w7_lee 4th Gear February 4, 2017 Share February 4, 2017 I just realised our wiper very smart. At Intermittent level I adjusted to the fastest speed. It would as expected up/down..without intermittent break. However when car come to a complete stop at junction..It would give an intermittent break. I reckon 2/3 second. Yeah, it seems to work this way only when at intermittent position (I try at other speeds). But when at other lever position, I think the intermittent break (at complete stop) does not happen. Also, when the wiper lever is activated (any position), the rear wiper will automatically swipe the rear glass when car is put in reverse. Link to post Share on other sites More sharing options...
Hotsoup Neutral Newbie February 5, 2017 Share February 5, 2017 Hi Owners, There are 2 models; the Honda Vezel Hybrid 1.5 X (A) and Honda Vezel Hybrid 1.5 X Honda Sensing (A) on the market. I did a compare with Sgcarmart on these 2 models and pardon my old eyes could not spot the different except the prices. Any1 able to advise on the differences between these 2? Thanks Link to post Share on other sites More sharing options...
Leo22 2nd Gear February 5, 2017 Share February 5, 2017 Hi Owners, There are 2 models; the Honda Vezel Hybrid 1.5 X (A) and Honda Vezel Hybrid 1.5 X Honda Sensing (A) on the market. I did a compare with Sgcarmart on these 2 models and pardon my old eyes could not spot the different except the prices. Any1 able to advise on the differences between these 2? Thanks I am not the owners of either. Just trying to help. Based on the name, one with Honda sensing and one without. The power and torque... etc all the same. Link to post Share on other sites More sharing options...
Hotsoup Neutral Newbie February 5, 2017 Share February 5, 2017 Thanks. The compare shows both have sensing By the way, u guys on any approved exhaust system or coilovers? Link to post Share on other sites More sharing options...
JSTong Clutched February 5, 2017 Share February 5, 2017 Does anyone know some reliable Body-work Workshop in JB ? My Vezel needs some knocking after its rear hit a pillar ! Please give me the contact asap ! Does anyone know some reliable Body-work Workshop in JB ? My Vezel needs some knocking after its rear hit a pillar ! Please give me the contact asap ! Link to post Share on other sites More sharing options...
aarcee Clutched February 6, 2017 Share February 6, 2017 There is a separate thread discussing on this matter. You can check it out whether are the PIs already discussed and will get more input from visitors of other car model also. Do bear in mind that experience shared are based on that specific point of time, no guarantee what will happen when come to your turn. Those 'more reliable' PIs mentioned do not mean '100% reliable'. Anything can happen overnight, e.g. currency fluctuate, rules/regulation changes, company stability, that might affect the delivery and also after sales support down the road. Able to pass the other thread which is discussing about the PI . I am planning to book it by next week . Thanks Link to post Share on other sites More sharing options...
urbanvoodoo 1st Gear February 6, 2017 Share February 6, 2017 this is interesting.. I always thought that AD workshop are better and safer...hehe.. so this means some PI workshops are even better! cheerS! In my recent experience - and this is highly dependant on which PI you go to. Sometimes you get a better deal. But must do your homework. ↡ Advertisement Link to post Share on other sites More sharing options...
All BMW owner thread
2025 Mazda 6e
2025 Mazda 6e
2026 Mazda EZ-60 / CX-6e
