Kklee 6th Gear May 11, 2007 Share May 11, 2007 Do take note that it may be possible that the actually voltage on battery and thru cigg adapter might be different. Example, Chevrolet Optra - difference is 0.2V ↡ Advertisement Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie May 11, 2007 Share May 11, 2007 (edited) Thanks alot Bro Nutty, YeoBH & Kklee. I'm looking for those that bro nutty posted. Bro YeoBH - By the way how or where should we plug the second volt meter (Gunson - Startcheck)? Edited May 11, 2007 by Fitzy Link to post Share on other sites More sharing options...
Chucky2007 Turbocharged May 11, 2007 Share May 11, 2007 if u notice that yr cabin light is really dimmer than usual... then its like very very soon battery is gonna die Link to post Share on other sites More sharing options...
Cobragold Clutched May 11, 2007 Share May 11, 2007 Yes, I am using a cheap and good malaysian battery from giant, cost only RM90 for NS60, still going strong after 3 years and i expect it to last a few more as it is well taken care for by a desulphator. But i noticed that most cars with battery problems are relatively new cars and the older COE cars like mine do not have much problems in this area. If you have to change battery every year it is very expensive hobby, a normal battery should last a few years, even taxi batteies are long lasting. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 11, 2007 Share May 11, 2007 MF batteries are bombs! I'm waiting for this one to die out next year before I get a conventional one from Malaysia. I kinda like the Yokohama Flat Top but it is the most expensive! Going for MYR190-200! I think the Yuasa will be so much better. Heck! Even the FB seen under lorries will be better! Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 11, 2007 Share May 11, 2007 When testing battery always take reading directly from the battery terminals.0.2v is the voltage drop due to wire or chasis ground resistance. Max volt drop permissible should be not more than 0.5volt.You can check voltage drop with digital volt meter - either terminal positive to positive sid of elect component or negative terminal to chasis ground. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 11, 2007 Share May 11, 2007 The second tester cw with clips Link to post Share on other sites More sharing options...
Fitzy Neutral Newbie May 11, 2007 Share May 11, 2007 Thanks alot Bro Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 11, 2007 Share May 11, 2007 Stock batteries are sized to meet the car electrical min requirments - normally 45 0r 55 amp/hr. Once you start to add more accessories, the battery will go flat in no time. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 11, 2007 Share May 11, 2007 Welcome Link to post Share on other sites More sharing options...
Octopus 3rd Gear May 12, 2007 Share May 12, 2007 MF batteries are bombs! I'm waiting for this one to die out next year before I get a conventional one from Malaysia. I kinda like the Yokohama Flat Top but it is the most expensive! Going for MYR190-200! I think the Yuasa will be so much better. Heck! Even the FB seen under lorries will be better! The initial battery which came with my COE car when I purchased it was Yokohama Flat Top. I just need to top up battery water once and it will remain for very long time without need to top-up. Tried to find locally but unsuccessfully... I would prefer that over those MF batteries. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 12, 2007 Share May 12, 2007 Get from Malaysia. Any workshop there is good. Just tell them you want the same battery. Link to post Share on other sites More sharing options...
Kklee 6th Gear May 12, 2007 Share May 12, 2007 MF batteries are bombs? Think my Chevrolet Optra needs to use MF batteries. Existing the one is a conventional battery, weekly have to top up battery water. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 13, 2007 Share May 13, 2007 They are. What battery dies within a year or year and a half? The convenience you pay for an MF battery is not justifiable the way I look at it. $100 for one and has to be changed yearly. Water used to top up the conventional battery is cheaper over 3yrs! Link to post Share on other sites More sharing options...
Ac1d6urn Neutral Newbie May 13, 2007 Share May 13, 2007 Any workshop from Malaysia to recommend? Link to post Share on other sites More sharing options...
Boxster 2nd Gear May 13, 2007 Share May 13, 2007 If you know how to DIY just go Giant they sell bat. But MY bat are make in MY. Some times got offer rm160+ can get MF bat. Last time I go buy one and keep (but I charge them up) But you have to know wat bat you using and take a pic be going to find coz quite limited models. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 13, 2007 Share May 13, 2007 Just go to anyone and they will sell you the battery. Link to post Share on other sites More sharing options...
Droozy Neutral Newbie May 16, 2007 Share May 16, 2007 Bro.. is the first voltmeter accurate in measuring ? or only slight diff ? thinking of buying this instead of installing gauges .. ↡ Advertisement Link to post Share on other sites More sharing options...
Battery warranty , must we service with distributor?
Fatty Kim going crazy again
Town Council S&C Charges May Increase Soon!
My EV journey to the i4
