Kklee 6th Gear May 18, 2007 Share May 18, 2007 It was a genuine mistake due to recycling the battery water bottle! Tried a desulfator... didn't work for for my Chevrolet Optra/Conventional Battery combination. ↡ Advertisement Link to post Share on other sites More sharing options...
Genie47 1st Gear May 18, 2007 Share May 18, 2007 Hmm.... consider dishing out big bucks for the USA version or lower cost with the DIY version. Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie May 18, 2007 Share May 18, 2007 Genie47 .. Any recommendation for a good & value for money desulfator? I mean the off the shelf type. By the way, does desulfator works fine with a Voltage Stabilizer as I have one installed. Link to post Share on other sites More sharing options...
Kklee 6th Gear May 18, 2007 Share May 18, 2007 I might make the DIY version but a bit skeptical that it would work as my battery is at the ideal voltage of around 12.6volts. Maybe try on another battery. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 18, 2007 Share May 18, 2007 I think you will get what you pay for or if DIY, in effort. The good ones are the USA ones costing around USD100. Link to post Share on other sites More sharing options...
Yeobh 4th Gear May 18, 2007 Share May 18, 2007 Try this maker http://www.pulsegenetech.co.jp/en/what/index.html Link to post Share on other sites More sharing options...
Geogeo Neutral Newbie May 18, 2007 Share May 18, 2007 Don't seems to have local dealer leh. Link to post Share on other sites More sharing options...
Adawang 1st Gear May 18, 2007 Share May 18, 2007 those voltage stabiliser things are capacitors positive and negative plates so close to one another, sure might short circiut easily, fire hazard Link to post Share on other sites More sharing options...
Unklistic Neutral Newbie May 18, 2007 Share May 18, 2007 You'll never go wrong with conventional ones. Mine's still going strong. Woooot! Link to post Share on other sites More sharing options...
Acaj Neutral Newbie May 22, 2007 Share May 22, 2007 How long a new battery can keep ? I can't wait till the MF battery died then go JB buy battery to replace..... Link to post Share on other sites More sharing options...
Watwheels Supersonic May 22, 2007 Share May 22, 2007 Why wait? Link to post Share on other sites More sharing options...
Genie47 1st Gear May 22, 2007 Share May 22, 2007 If die already how to go JB to replace? Link to post Share on other sites More sharing options...
Watwheels Supersonic May 22, 2007 Share May 22, 2007 Got 3/4 tank full can already mah. Link to post Share on other sites More sharing options...
Genie47 1st Gear May 22, 2007 Share May 22, 2007 Dead battery how to start car? If manual car can push start but auto car how? Link to post Share on other sites More sharing options...
Boxster 2nd Gear May 22, 2007 Share May 22, 2007 Last time my G8 manual one owner's manual say cannot push start otherwise will damage catalytic convertor Link to post Share on other sites More sharing options...
Passion 5th Gear May 22, 2007 Share May 22, 2007 Yes.My uncle old Toyota Dyna battery lasted 6 years and still cracking the lorry without fail with just one crank.Until recently he change to a new Dyna,still wondering if the battery will last 6 years. Link to post Share on other sites More sharing options...
Boxster 2nd Gear May 22, 2007 Share May 22, 2007 (edited) Maybe he should have removed the old battery and install it into the new Dyna on as see if it will tahan until 12 yr. If can maybe I should by the battery Edited May 22, 2007 by Boxster Link to post Share on other sites More sharing options...
Garytkj Neutral Newbie May 22, 2007 Share May 22, 2007 this few days during idling my display lights& tail lights flicker, rev up to 2+k rpm then it no more flickers. battery is still charging at 14v, and normal at 12v the maintanence free battery is about 1 yr old, with a VS. is this sign that the battery need to change soon? If battery bloat up at the side, that means going to die liaozz ↡ Advertisement Link to post Share on other sites More sharing options...
Battery warranty , must we service with distributor?
Fatty Kim going crazy again
Town Council S&C Charges May Increase Soon!
My EV journey to the i4
