Galantspeedz Turbocharged December 21, 2007 Share December 21, 2007 i think mine are delphi lockheed pads. if good pads it is true but muz use correct one lar... dun later use the whisper or laurier brand ↡ Advertisement Link to post Share on other sites More sharing options...
Yuan 6th Gear December 22, 2007 Author Share December 22, 2007 Managed to resolve this whole issue. Thanks for your advice and help. Link to post Share on other sites More sharing options...
Garlic 1st Gear December 22, 2007 Share December 22, 2007 Glad its solved, what was the causing it? Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 22, 2007 Share December 22, 2007 care to provide us on what was done to resolve ? this would be a good info for other members that are going for Bendix Ultimate Link to post Share on other sites More sharing options...
Yuan 6th Gear December 22, 2007 Author Share December 22, 2007 I just went to change my brake fluid. For my case, I have not flushed my brake fluid for more than 1 year already....Oops.... Link to post Share on other sites More sharing options...
Yuan 6th Gear December 22, 2007 Author Share December 22, 2007 Another thing I learn is to change the brake fluid when u change to new brake pads. I change my brake pads without changing the brake fluid which is why it resulted in my above experience. Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 22, 2007 Share December 22, 2007 looks like water have gone into the brake fluid which is normally the case for soft pedal feel, glad you're problem is solved Link to post Share on other sites More sharing options...
Dsmnd Neutral Newbie December 22, 2007 Share December 22, 2007 Hi, was wondering if you had your brake hose changed to steel braided ones or it's the original rubber hose? Link to post Share on other sites More sharing options...
Yoshiki Neutral Newbie December 22, 2007 Share December 22, 2007 (edited) i am using bendix gold, the bite when cold is quite good. Wondering how much u got ur bendix ultimate for? The problem u described can also sometimes be due to condesation of moisture in the morning on the brake pads and rotors which will require you to pump the pedal to rid the water and get the bite, cause happen to me a few times on really cold rainy mornings. Edited December 22, 2007 by Yoshiki Link to post Share on other sites More sharing options...
Yuan 6th Gear December 22, 2007 Author Share December 22, 2007 (edited) I am using the original rubber hose. Why leh? I may consider changing to stainless steel braided hose, in particular Goodridge brand, in the future. Edited December 22, 2007 by Blacklancer224 Link to post Share on other sites More sharing options...
Yuan 6th Gear December 22, 2007 Author Share December 22, 2007 Thanks for your sharing. I heard from my mechanic that this also happen to original stock brake pads. Just that due to the different type of material used for original stock pads and aftermarket ones such Bendix, we do not feel it in the original pads but feel it in the aftermarket ones. Dunno true or not. Link to post Share on other sites More sharing options...
Yuan 6th Gear December 23, 2007 Author Share December 23, 2007 I was a bit kiasu lah. Had my mechanic to check my brake pump and master brake cylinder. This was because I have a brake stopper in my ride. Was suspecting whether the brake stopper damaged the brake pump and master brake cylinder even though I know the actual function of the brake stopper. Link to post Share on other sites More sharing options...
Vtim 3rd Gear December 23, 2007 Share December 23, 2007 ah, that's ok lah Link to post Share on other sites More sharing options...
Dsmnd Neutral Newbie December 24, 2007 Share December 24, 2007 (edited) Hi Blacklancer224, to my limited knowledge, if you do a lot of hard driving, or need to brake constantly, the original rubber hose may not be able to retain the hydraulic pressure for the brakes. Simply because, the hydraulic oil(aka brake fluid)will heat up thus expending the rubber hose. So the braking distance will definitely be longer and the brake may not seem to be as effective as when starting on a normal drive. Goodridge steel braided hose are good, they're suppose to last at least 100k kilometers, and it also have warranty against manufacturer defects. They'll not expand even though under constant abuse and will definitely maintain braking pressure. How I know? cause I'm using it (ps. I do not sell, promote or gain anything from recomending Goodridge steel braided hose.) Edited December 24, 2007 by Dsmnd Link to post Share on other sites More sharing options...
Yuan 6th Gear December 24, 2007 Author Share December 24, 2007 (edited) Yes. Fully agreed with you. I am actually very interested in Goodridge stainless steel braided hose. However, my only concern is to find the source of goodridge braided hose for my model in Singapore and a good installer. There has been some feedback from a few bros who had installed goodridge stainless steel braided hose and due to poor installation, the hose broke or crack at the caliper joint. Important thing for me is to find a good installer. If you have good sources or lobangs to recommend, do let me know. Thanks and merry christmas! Edited December 24, 2007 by Blacklancer224 Link to post Share on other sites More sharing options...
Koren Clutched November 26, 2008 Share November 26, 2008 sorry to dig out this old thread.. but anione knows the contact for bendix direct distributor? Link to post Share on other sites More sharing options...
Ahdi Neutral Newbie November 26, 2008 Share November 26, 2008 i'm not sure, but a FR for bendix untimate. my frnd vios is using it, and it is really v v v v v v dusty. he is using grey color superlegerra and can see the rim getting even more dark after 2 days of driving. i can say its even more dirty than conti cars which haf well-knows dirty pads. but feedback that braking is better than stock. Link to post Share on other sites More sharing options...
Yuan 6th Gear November 26, 2008 Author Share November 26, 2008 You can google the internet and it will lead you to their australian website. From there, you can email and ask for their contacts here. From what I know, they don't have direct distributor in Singapore. Heard for SEA, there have a distributor who is based in Malaysia and from that distributor he will give you the contacts in Singapore. ↡ Advertisement Link to post Share on other sites More sharing options...
IKEA shopping experience
S’pore Airshow - Worst transport experience’
Chemotherapy experience at NCC
Experience with kidney stones
Anyone remembers top mechanic Ah Siong from Hankook?
Audi Experience
Audi Experience
My experience working in civil service...
