Typhoonz
Jaybee's Mobil Synergy Regular
4th Gear
Anyone knows what's the octane rating for the above? How about Synergy F1?
Just got back from Jaybee and this is my virgin pump of Synergy regular but suddenly I thought, what's the octane level for it?
Share this post
how abt the purple snergy f1? anyone knows wat ron rating?
Share this post
I think is 92 only right?
Mobil only 2 type of petrol. Synergy F1 and another type.
Synergy F1 is 97. The other type is 92.
I supposed the other type is the Synergy regular.
Share this post
2nd Gear
regular either 91 or 92 (not too sure)
F1 is 97
Malaysia oil is 91/92 and 97 in all stations
(Vpower different of course) [cool]
Share this post
4th Gear
I read from the MY mobil webbie and it says that it's RON92...
Share this post
4th Gear
Oops... Any impact now that I've pumped it as my car's minimum is RON95?
Share this post
Supersonic
If your car has a knock sensor, it will try to compensate for the ron92.
The safer option is to pump more 97 or 98 to balance it out.
Share this post
4th Gear
How about adding those octane booster? Will it work? What are the immediate impact should my car not have a knock sensor?
Share this post
4th Gear
And cheaper too? RM2.70 right? I was hesitant to pump that one as I thought it was on par with V Power...
Share this post
2nd Gear
It's doesn't matter what grade u use..juz follow the jeeepun people noted in ur car manual liao... [whip]
Share this post
4th Gear
Sigh... I pump liao then I realised that minimum is RON95...
Share this post
Supersonic
V power is also RON97. Juz more additives.
Share this post
Supersonic
It's more cost effective to just add 97/98 since you are paying for fuel also and not just additive.
Octane booster would be useful if you are staying in a place where higher octane is not available.
If your car does not have a knock sensor, then knocking may occur under high load, if your car requires 95.
If you don't find the engine knocking, then you could continue to use it by driving conservatively until you get the min. required 95.
Share this post
yea at the standard price. i had vpower and it never quite felt good, i mean if u were to compare Vpower in SG. by far i would say Petronas is the best (personally), and f1 follows quite keenly behind
Share this post
yap, agree, i also felt that petronas is the best. measured the FC and it is the best out of the 5 (mobil, caltex, shell & esso. However, that is based on 1 tank of fuel measurement. Maybe someone else can confirm?
Share this post
6th Gear
Petronas gives more milage for me too. [bounce2] Too bad its too far away from the customs. [:/]
Mobil is not too bad rah. [nod]
Share this post
