What tyre pressure should I pump
Plexus
Hey all,
My ride comes with stock 205/55/16R Yoko A-drive tyres. Took a look at the sticker by the side of the door and realized that it was for 15" tyres with recommended pressure of 210kPa for both front and rear.
Any idea what kind of pressure should I be pumping for my 16" tyres? I noticed that at the side of the tyre, it states max pressure is 300kpa / 144psi.
Hey all,
There is no formula for this. Since the volume of air is less in your 16" tyre you probably add another 10Kpa to the manufacturer's recommended pressure. You can add 20Kpa if you feel it is not too hard for you.
Volume of air affects pressure??? :huh:
Hey all,
I always pump higher. I maintain at 35~36psi for my 225/45R17.
Regards,
10% per inch up
But what if its a 16-inch tyres that have a height of only 45 instead of 55? Does the tyre pressure need to be reduced in this case?
Is this the recommended tyre pressure for 45 profile tyres?
I used TPMS, so I need higher PSI as recommended by agent. In addition, I frequent NSHW so I needed a higher PSI too.
Regards,
Regards,
Do u need to have type specific rims for TPMS or regular wheels will do?
I don't think so. Just bring the money [laugh] . I've fitted them in 16" and now the current 17". The sensors are implanted to your tyre valves inside the tyres. Mine gives 2 simple and important on-the-fly readings, PSI and temperature.
Regards,
Regards,
OK, I fax my cash over [lipsrsealed] No interference of any sort, false reading or erratic reading?
Regards,
How much did u spend on purchase & installation of TPMS?
I'm on 195/45/R16 tyres...damn odd size. Also, my tyres seem to be leaking air faster than usual, 2 weeks it can drop as much as 20kpa each.
2 weeks drop 20kpa sounds norm to me....as my car park mostly under hot sun in during afternoon and only night time at home under shelter, i thought 20kpa lost in 1-2weeks time is normal.... no??... [sweatdrop]
Ah... so thats normal. Thx!
Hey all,
235-240 should be ok if you can tahan the bounciness .... [nod][nod][nod]
I'm pumping 250-260 for my 215/45R17 [flowerface]
Bro, u using ur own pressure guage or the petrol kiosk air pump guage?
I realised that more than half of the air pump guage at the petrol kiosks are 20-40kpa over or under actual..thus i got my own pressure guage.
