Heartbreakid 6th Gear March 23, 2010 Share March 23, 2010 (edited) 1 - no need for that ... for VERY COLD early morning, after 30 secs on the engine, do quick 10-secs revs on 3k,4k,5k and 6k. -- I think it is best not to rev the car in cool morning. After start-up, we can drive off normally, that's no issue. Be it any engine, not related to whether factory already run-in or not, when an engine is parked over night, oil will set in the sump, some parts of the engine will be least lubricated. So if one rev even just a few seconds after start up, that will cause wear and tear, because optimum lubrication has yet to achieve. And oil is thick when cool, so only when an engine is warmed up, that's when oil is more fluid, parts with tight tolerance will be better lubricated. It is still good to rev the engine after it has fully warmed up. Edited March 23, 2010 by Heartbreakid ↡ Advertisement Link to post Share on other sites More sharing options...
Panhard 1st Gear March 23, 2010 Share March 23, 2010 there used to be a "cold start switch" which increases the rpm(1.5k-2.9k) at cold start--- maybe manufacturers have realised this is not a good way to warm-up the engine cos it causes premature wear on engine parts. so maybe thats why this temp lamp is used now. warm up at normal rpm speeds.... Link to post Share on other sites More sharing options...
Fussymi Neutral Newbie March 23, 2010 Share March 23, 2010 Hi, anyone encounter petrol smell in car occasionlly? I got this problem since day 1, informed Proton service centre many times, they checked and said nothing wrong . The smell is very strong especially when we are at a closure area like Woodlands Check point Link to post Share on other sites More sharing options...
Panhard 1st Gear March 23, 2010 Share March 23, 2010 Hi, anyone encounter petrol smell in car occasionlly? I got this problem since day 1, informed Proton service centre many times, they checked and said nothing wrong . The smell is very strong especially when we are at a closure area like Woodlands Check point could it be exhuast fumes getting in the car.... Link to post Share on other sites More sharing options...
Caaa Clutched March 23, 2010 Share March 23, 2010 Happened on my company car last time (Include Waja, Hyundai Accent and Toyota Vios), strong smell happen usually after refuelling.... Did u pump to its max? try not squeeze too much after auto stop at pump station and see how....was told its due to this reason, and not only on any particular brand actually Link to post Share on other sites More sharing options...
Panhard 1st Gear March 23, 2010 Share March 23, 2010 which make of fuel & octane will work better on the exora campro cps?? Link to post Share on other sites More sharing options...
Human Clutched March 23, 2010 Share March 23, 2010 I too have notice the smell after refueling,as for stuck in jams there is no exhaust fumes entering inside the car. Link to post Share on other sites More sharing options...
Heartbreakid 6th Gear March 23, 2010 Share March 23, 2010 (edited) I'm not sure about the campro engine, but I believed the warm up practise still exist in modern cars, such that, the rpm is higher during cold morning just after start up. Edited March 23, 2010 by Heartbreakid Link to post Share on other sites More sharing options...
Ynizam Neutral Newbie March 23, 2010 Share March 23, 2010 PROBLEM :: Exhaust @ gas fume smell in Exora RECTIFY :: Go to SC ... Report .. they will put something in-between the tank and body ... Note:: it is a weakness being experienced by most exora owners after re-fuelling or being at the back of a bus@lorry Link to post Share on other sites More sharing options...
SGXora Clutched March 23, 2010 Share March 23, 2010 PROBLEM :: Exhaust @ gas fume smell in Exora RECTIFY :: Go to SC ... Report .. they will put something in-between the tank and body ... Note:: it is a weakness being experienced by most exora owners after re-fuelling or being at the back of a bus@lorry thanks bro, i have a similar experience (petrol smell after refil), tot this is normal for MPV. after change thermo amp, air-con working so far so good. my ride going for 5K servicing, can i have your advise on my should look for , sound TAT;TAT;TAT from dashboard (on and off) should i report? Link to post Share on other sites More sharing options...
Panhard 1st Gear March 23, 2010 Share March 23, 2010 didnt actually notice the petrol smell after refilling...now that a few of you have experience it. will take note at next refill & open my nose bigger to sniff for petrol . Since car still under warranty better get it rectified.. Link to post Share on other sites More sharing options...
Fussymi Neutral Newbie March 24, 2010 Share March 24, 2010 PROBLEM :: Exhaust @ gas fume smell in Exora RECTIFY :: Go to SC ... Report .. they will put something in-between the tank and body ... Note:: it is a weakness being experienced by most exora owners after re-fuelling or being at the back of a bus@lorry Ynizam, I told them so many time already, yet they said nothing wrong . All my friemds, how to tell the SC so that they really look into this matter Any person that I can refer to in Singapore SC? Link to post Share on other sites More sharing options...
Kurty Supercharged March 24, 2010 Share March 24, 2010 escalate this matter to their manager, charles if i not wrong. though i not driving an exora but what happen to me was during the 3rd year 2 months of my ride, savvy. it had a major failures - ignition coil which cost around SGD$400 - speedometer sensor, cost around $300 - steering oil leakage, a replacement will cost around $300 i was quite upset and unhappy as only 2 mth of ownership, all these happen. lucky, i had an agreement with the car dealer, they gave me a warranty of 6mths upon purchase and agreed to cover for my ignition coil and sensor replacement. as for the steering oil pressure leakage, i had to foot myself. lucky, i wrote to Charles complaining about the quality of service and their rides. in the end, he managed to waive off but still had to foot a sum of $80 as their labour fee. I hope with this, it could help in solving your problem. Link to post Share on other sites More sharing options...
Human Clutched March 24, 2010 Share March 24, 2010 Hi Fussymi! when did this happen, i'am gng for the first 1K this friday.I'am also having the same fuel smell problem. Link to post Share on other sites More sharing options...
SGXora Clutched March 24, 2010 Share March 24, 2010 check with all Exorien, everytime first start the engine (morning) and move the car, everytime go thru the Hump (about 100M away from parking lot), can heard the "klok"sound and "Squeaky" sound when applied brake. but this only happen for a short period, after that when go thru second hump (another 100m), no more sound appear, is this normal??? Link to post Share on other sites More sharing options...
Panhard 1st Gear March 25, 2010 Share March 25, 2010 check with all Exorien, everytime first start the engine (morning) and move the car, everytime go thru the Hump (about 100M away from parking lot), can heard the "klok"sound and "Squeaky" sound when applied brake. but this only happen for a short period, after that when go thru second hump (another 100m), no more sound appear, is this normal??? squeaky sound from brakes when first applied (cold condition) likely due to brake disc has moisture( overnight dew) but if loud squeaky sound under all braking conditions then could mean brakes showing signs of wearing out-- do check it!- is your mileage high? Link to post Share on other sites More sharing options...
Panhard 1st Gear March 25, 2010 Share March 25, 2010 I too have notice the smell after refueling,as for stuck in jams there is no exhaust fumes entering inside the car. does it happen only when you fill it up to the top(really full) or just every refill regardless of amount??? does the smell disappear after a while or remains there till following day??? any signs of leakage when filling??? Link to post Share on other sites More sharing options...
Panhard 1st Gear March 25, 2010 Share March 25, 2010 Ynizam, I told them so many time already, yet they said nothing wrong . All my friemds, how to tell the SC so that they really look into this matter Any person that I can refer to in Singapore SC? may i suggest the next time when report the fault, refill the tank first then drive to the SC--this way they can detect the problem & make sure that it is recorded in your record file- keep a copy of it so in case, when the problem arise after warranty period you have something to say.... ↡ Advertisement Link to post Share on other sites More sharing options...
Vincar to distribute Proton’s first electric vehicle in Singapore
China’s Largest Car Service Chain is Quietly Taking Over Malaysia
Proton X50
Proton X50
Proton eMas 5 previewed – rebadged Geome Xingyuan, RWD, 250 to 325 km WLTP
Proton overseas
Proton overseas
New Proton Perdona.
New Proton Perdona.
Proton To Introduce smart Electric Vehicles In Malaysia
