Fteocs 2nd Gear March 17, 2019 Share March 17, 2019 (edited) Does your scuff plates go on the outer metal or inner plastic part of the door ? Iâm looking for the latter but unable to find so far.Don’t quite understand you. Let me share what I did. The car comes with black plastic "scuff plate" they are double side taped. I removed them and the surface is flat. I clean the surface with alcohol then stick the stainless steel scuff plates... Quite easy the tough part is remove the plastic ones. The plastic ones are flexible so once you get one side up and able to stick your fingers under it just pull, surface won't be damaged and no residual easy to clean for sticking the new one. If you zoom it the picture you will see it's directly on the body not on the default black plastic Hope that help I asked a local workshop they carry the scuff plate with black plastic backing with metal top, cost almost 90 with installation but I fine no plastic backing nicer so took the plunge and order from AliExpress... Like it much and its just a tab over 40 dollars less than 41 but with sweat.. Hahaha Edited March 17, 2019 by Fteocs ↡ Advertisement Link to post Share on other sites More sharing options...
Rkankc 1st Gear March 17, 2019 Share March 17, 2019 I tried a Samsung and a Sandisk SD card with the stock Blaupunkt dashcam and the dashcam hung after 2 days. Switched back to the stock 16GB SD card and everything’s fine. The aftermarket cards work well in my Marbella dashcam. Not sure what to make of this Also may I ask where you got the Cellink battery installed to the stock dashcam? I figured out why the BP dashcam hung with the aftermarket SD cards. After I use the Windows formatting tool on my desktop, the aftermarket 64GB SD cards show only 200MB memory space. So I downloaded this https://www.sdcard.org/downloads/formatter_4/index.html to reformat my cards again; they now show the correct memory space and work fine in the dashcam. Link to post Share on other sites More sharing options...
szekt 2nd Gear March 17, 2019 Share March 17, 2019 Hi Sze, Works out fine .. pls see photos. If wants swee swee and durable: - avoid primer cos will be too sticky and hard to align .. but do try and let me know cos I din managed too well .. fingercrossed these tiong 3M will hold up - get small and sharp scissor for trimming - do not remove tape entirely .. start top after trimming top to clear door when closing and slowly align seal along edge of door and tapping lightly to allow adjustment if not aligned nicely - have big long flat tipped for pressing tape down behind hinges cos not accessible - press down entire length when ready - trim bottom about <20mm from bottom edge of door .. dun get greedy cos it will jammed and loosen when too long as door closes 10 mins job and good luck ! Cheers. Richard Thanks... any links to getting the rubber seals? 1 Link to post Share on other sites More sharing options...
Bc777 Clutched March 17, 2019 Share March 17, 2019 Brox just sharing. My old Mazda 3 was knock by passer-by and bent outward since then when mirror retract it has kiak kiak kiak sound. Mechanic mentioned they don't fix the mirror, it's better that change the whole mirror. Was quoted by TEK close to 400 but after market is only 180. But because my car was too old at that time, so I chosen to deactivate the both side and my mirror will never fold back. But the mirror inside still can be adjusted. So, if you like to fix it, perhaps change a new mirror at outside workshop is better choice. In FB mazda group, ppl always recommend JDM Autocare, they do alot of mazda car. Get a quote and compare with TEK. Hope these help. Nice accessories. I like the antiscratch at the door step. Thanks Lawrance. Will check with JDM. Link to post Share on other sites More sharing options...
richard_crl032 6th Gear March 17, 2019 Share March 17, 2019 (edited) Thanks... any links to getting the rubber seals? ð ðSG$ 27.53 | lsrtw2017 car hood edge seal strip for subaru outback forester xv legacy brz impreza 2010-2019 2018 2017 2016 2014 2015 2013https://s.click.aliexpress.com/e/hKp3w96 Hi Sze, Current used from above aliexpress link. Also ordered and pending receipt for some forester kakis from amazon since cheaper and also hope to avoid tiong ones: https://www.amazon.com/Universal-Z-Shape-Adhesive-Weatherstrip-Protector/dp/B07MFJJR47 Cheers. Richard Edited March 17, 2019 by richard_crl032 Link to post Share on other sites More sharing options...
S2s1 3rd Gear March 17, 2019 Share March 17, 2019 Hi Sze, Works out fine .. pls see photos. If wants swee swee and durable: - avoid primer cos will be too sticky and hard to align .. but do try and let me know cos I din managed too well .. fingercrossed these tiong 3M will hold up - get small and sharp scissor for trimming - do not remove tape entirely .. start top after trimming top to clear door when closing and slowly align seal along edge of door and tapping lightly to allow adjustment if not aligned nicely - have big long flat tipped for pressing tape down behind hinges cos not accessible - press down entire length when ready - trim bottom about <20mm from bottom edge of door .. dun get greedy cos it will jammed and loosen when too long as door closes 10 mins job and good luck ! Cheers. Richard Effective? Link to post Share on other sites More sharing options...
szekt 2nd Gear March 17, 2019 Share March 17, 2019 SG$ 27.53 | lsrtw2017 car hood edge seal strip for subaru outback forester xv legacy brz impreza 2010-2019 2018 2017 2016 2014 2015 2013 https://s.click.aliexpress.com/e/hKp3w96 Hi Sze, Current used from above aliexpress link. Also ordered and pending receipt for some forester kakis from amazon since cheaper and also hope to avoid tiong ones: https://www.amazon.com/Universal-Z-Shape-Adhesive-Weatherstrip-Protector/dp/B07MFJJR47 Cheers. Richard Thank you Link to post Share on other sites More sharing options...
flashbang Turbocharged March 17, 2019 Share March 17, 2019 Bought a few accessories from lazada/aliexpress DIY. Just share some simple pics Where you got the car mat from? Heel plate is at the correct position. Usual ones always too far from the pedals... Link to post Share on other sites More sharing options...
S2s1 3rd Gear March 17, 2019 Share March 17, 2019 (edited) SG$ 27.53 | lsrtw2017 car hood edge seal strip for subaru outback forester xv legacy brz impreza 2010-2019 2018 2017 2016 2014 2015 2013 https://s.click.aliexpress.com/e/hKp3w96 Hi Sze, Current used from above aliexpress link. Also ordered and pending receipt for some forester kakis from amazon since cheaper and also hope to avoid tiong ones: https://www.amazon.com/Universal-Z-Shape-Adhesive-Weatherstrip-Protector/dp/B07MFJJR47 Cheers. Richard Seems Amon does not have similar Z-shape for A pillar. Only can get from China I guess. The Amazon I guess it is from China also. Maybe Amon 2650 seal whole door, so no need Z-shape seal. Edited March 17, 2019 by S2s1 Link to post Share on other sites More sharing options...
richard_crl032 6th Gear March 17, 2019 Share March 17, 2019 (edited) Seems Amon does not have similar Z-shape for A pillar. Only can get from China I guess. The Amazon I guess it is from China also. Hi S2s1, Indeed .. amazon guess so but aliexpress for sure .. cheaper also :) I have 2 pack of 2650 that I din try and more than willing to let you have one at cost. Cheers. Richard Effective?Hi S2s1, Din really try and wun be nite and day but every bit helps and not expensive to just do it. Also only done one side cos no more until new order arrives. Cheers. Richard Edited March 17, 2019 by richard_crl032 Link to post Share on other sites More sharing options...
Fteocs 2nd Gear March 17, 2019 Share March 17, 2019 (edited) Where you got the car mat from? Heel plate is at the correct position. Usual ones always too far from the pedals... I got from passorex, office at midview Bishan area. In the car is 19mm thickness , I got boot as well at thinner think it’s 13mm...total about 250, totally won’t slip out of position as the nonslip is the entire piece not just a small portion. Edited March 17, 2019 by Fteocs Link to post Share on other sites More sharing options...
Fteocs 2nd Gear March 17, 2019 Share March 17, 2019 (edited) I bought this, just received, recommended by colleague. https://www.aliexpress.com/item/For-Mazda-6-929-Atenza-Millenia-Car-Sealing-Seal-Strip-Kit-Rubber-Weatherstrip-Seal-Edging-Trim/32791936091.html?spm=a2g0s.9042311.0.0.12c14c4d104tCp Price $102..look ok but have not stick yet.... Edited March 17, 2019 by Fteocs 3 Link to post Share on other sites More sharing options...
cyee29 1st Gear March 18, 2019 Share March 18, 2019 Last sat ST ads shows Mazda 6 going for $99,800, is this real or has hidden costs ? 1 Link to post Share on other sites More sharing options...
sgsmith 1st Gear March 18, 2019 Share March 18, 2019 Last sat ST ads shows Mazda 6 going for $99,800, is this real or has hidden costs ?Actual price could be slightly lower than this figure 1 Link to post Share on other sites More sharing options...
Dna_engine 3rd Gear March 18, 2019 Share March 18, 2019 Anyone experiencing vibrating door panels with the Bose sound system? 1 Link to post Share on other sites More sharing options...
sgsmith 1st Gear March 18, 2019 Share March 18, 2019 Anyone experiencing vibrating door panels with the Bose sound system?Feel like resonance vibration Link to post Share on other sites More sharing options...
clarkkent 1st Gear March 18, 2019 Share March 18, 2019 Last sat ST ads shows Mazda 6 going for $99,800, is this real or has hidden costs ?Real. I was quoted 98800. Immediate registration 1 Link to post Share on other sites More sharing options...
S2s1 3rd Gear March 18, 2019 Share March 18, 2019 Hi S2s1, Indeed .. amazon guess so but aliexpress for sure .. cheaper also :) I have 2 pack of 2650 that I din try and more than willing to let you have one at cost. Cheers. Richard Hi S2s1, Din really try and wun be nite and day but every bit helps and not expensive to just do it. Also only done one side cos no more until new order arrives. Cheers. Richard Thanks to the 2650 offer! But I am lazy to seal whole frame. ↡ Advertisement 1 Link to post Share on other sites More sharing options...
Honda City 4th Gen
Honda City 4th Gen
2025 Mazda 6e
2025 Mazda 6e
2026 8th Generation Lexus ES
2026 Mazda EZ-60 / CX-6e
Camry, Accord, Teana which is more Luxurious?
